Author Topic: Check Upper Triple Treee Bolts  (Read 870 times)
Offline currenv
  • COG#: 11913
« on: November 19, 2017, 02:01:24 am »
Friends,
Probably a one-off but I thought I'd pass this along.
Poking around the front end of my bike this afternoon, the bracket that holds the left side wiring harness at the upper triple tree was moving.  That's not right -- I took a closer look.
Turns out that the upper left side pinch bolt was loose.  Not loose as in not quite torqued down enough, but loose as in I could unscrew it by hand.  Pretty surprising to me since I haven't been in there in the two years I've owned the bike and the previous owner is quite capable in working on these bikes.  I'm not a very aggressive rider, either.  The right side upper was fine, by the way.  I haven't checked the lowers yet, but I will.
So... it might be worth taking a minute and making sure that yours are still tight.
Vinnie
Offline gsun
  • CDA #560
  • COG#: 9127
Re: Check Upper Triple Treee Bolts
« Reply #1 on: November 19, 2017, 02:34:52 am »
Those have been known to loosen. Thanks for the reminder. Haven't looked at mine for a couple of years.
Offline Skiee
  • COG#: 11459
« Reply #2 on: November 19, 2017, 04:03:42 pm »
Gonna have to check mine. Didn't notice while replacing brake lines yesterday.
Also, do check your saddlebag bolts inside of the bags. Mine had 2 literally on the bottom of the right bag...
2009 Concours 14 (Francis)
AMA# 3044870
CDA# 510
Offline gpd323
« Reply #3 on: November 19, 2017, 07:16:10 pm »
mine are all tight, no loose bag screws either. Thanks for the post though. Others may find the same as you?
Offline 4Bikes
« Reply #4 on: November 19, 2017, 08:57:45 pm »
I had my shocks out for the Traxxion AK-20 upgrade less than a year ago. They were torqued to spec. Are we saying this is an assembly issue, or they can loosen up on their own?   I guess the service manual rules all since it says to routinely check bolts.  ::)
Offline currenv
  • COG#: 11913
« Reply #5 on: November 20, 2017, 01:35:18 am »
4 Bikes,
I think mine loosened up on its own.  I pulled the bolt and it looked fine, although no sign of threadlocker.  I added some and torqued it back down.  The other side was fine, although I pulled it and added threadlocker on it, too.
I haven't gotten to the lower pinch bolts yet.
Vinnie
