Author Topic: Cut up tire comparison  (Read 794 times)
Offline Just Cliff
  • COG#: 9547
« on: April 08, 2019, 12:35:00 am »
Saw a post where gilbysan cut apart a tire, I was bored, weather was bad & I had tires. Sooooo I got out the sawzall & went to cutting. Measured the rubber thickness at the center & noted the mileage. Labeled the tires for comparison sake.
For what it's worth here are the results. The 3D-XM had the highest mileage & was the second thickest in the center. The Angel had 3,400 miles on it. The Roadtec sucked, I couldn't wait to get that tire off. So it's not as worn as I normally run them too.
This was the only 4 brands I had on hand or I'd done some more.
« Last Edit: April 08, 2019, 12:52:43 am by Just Cliff »
Cliff
2014 1000 V Strom
Offline Diz
  • COG#: 12056
Re: Cut up tire comparison
« Reply #1 on: April 08, 2019, 08:42:36 am »
Thanks for doing this but I'm unsure of the lesson. Almost all of the tires were on their wear bars. Thickness of center did not seem to translate into superior mileage. My bike can be a bit squirrelly when my tires wear down to a certain point. Was the ride that much different from thicker tires as the tread wore down?
Offline Just Cliff
  • COG#: 9547
« Reply #2 on: April 08, 2019, 11:41:02 am »
There was no lesson to speak of.  :-\  I said it in the 1st line of post, boredom & bad weather.  Just something different than the same ole tire & oil crap.
If you need a lesson though. It shows the most worn tire (ST) still has the most rubber left. Center has a trace of tread & the sides are slick.  :motonoises: The highest mileage tire has the second most rubber left. The least worn tire has the less rubber left.
Pretty much all tires are ill handling when there that worn.
Cliff
2014 1000 V Strom
Offline Jim Snyder
  • COG#: 7055
« Reply #3 on: April 08, 2019, 01:35:45 pm »
The lesson for me is, when it comes to tires I would take any advice Cliff gave me. Cliff puts ALOT of miles on every year and has probably gone through more tires than 98% of us have. And I'm sure he has tested more brands also.
Offline gilbysan
  • Ride Like the Wind!
  • COG#: 12764
« Reply #4 on: April 08, 2019, 02:37:24 pm »
Ditto all,
I could only handle cutting up one set of tires, Cliff did a bunch and I like to see the innards of things so Thanks Cliff!
It is all good stuff.
Gilbysan
gilbysan
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #5 on: April 09, 2019, 02:43:58 am »
My only question is why was he hanging on to a bunch of tire carcasses?  :nananana:
Offline Just Cliff
  • COG#: 9547
« Reply #6 on: April 09, 2019, 11:15:34 am »
Best advice I can give you, is DON'T take any advice from me!  :nananana:
They're like rabbits, they multiply quickly. Time to haul them off again, the pile has grown.
It has occurred to me, my tire cost has surpassed what I paid for the bike new. Bike cost $11,100 new, approx. 45 sets of tires at $250.00 = $11,250.  :'( >:(
Cliff
2014 1000 V Strom
Offline gilbysan
  • COG#: 12764
« Reply #7 on: April 09, 2019, 02:01:38 pm »
Cliff is the man!  Anyone who knows how many sets of tires he has put on his bike(s) is awesome, IMO!
Ride On Cliff!
Gilbysan
gilbysan
Offline MtnRider
  • COG#: 12840
« Reply #8 on: April 09, 2019, 02:18:43 pm »
But just think, the bike cost is down to 5 1/2 cents per mile! Amazing.   :great: :great: :beerchug:
2015 Black C14
Offline Jim Snyder
  • COG#: 7055
« Reply #9 on: April 09, 2019, 02:23:53 pm »
Cliff, did you ever get another set of wheels so you could have the next set ready to swap out at a moments notice?
« Reply #10 on: April 09, 2019, 05:59:57 pm »
My take away is when your tires are worn you have little resistance to a puncture.  Only 4-7mm.  I can shove my keys through that almost.  I am always surprised how thin and weak it feels when I am looking an old tire over.
Offline gilbysan
  • COG#: 12764
« Reply #11 on: April 09, 2019, 07:43:32 pm »
Jim,
You could be right.  In my case I don't think it would have mattered how much was left.  I picked up a small sliver of steel that looked like a little toothpick about 15mm long and 1 mm thick, and it went right through the tread, belts and all. I noticed that my TPMS was registering a decrease in pressure for the front, where normally the pressure is extremely consistent so that was my cue to check it out.
I hate FoD problems!
Gilbysan
gilbysan
Offline SteveJ.
  • COG#: 5603
« Reply #12 on: April 09, 2019, 09:20:32 pm »
You could almost qualify as a group buy on your own.  :rotflmao:
My itty bitty six fiddy is keeping pace. Rear tire number 10 will be done when I get out your way, probably around 57k miles at that point. I plan on going to that dealer I have used before out that way.
Tick Tock, baby (Ironbuttal)
Offline Just Cliff
  • COG#: 9547
« Reply #13 on: April 09, 2019, 10:59:43 pm »
Ride On Cliff!
Gilbysan
Approx. + or - 2, I'd have to go through book & count to be exact.  :motonoises:
Maybe a group buy together!  :) 57K already? You ride to much.  :nananana: I need to be retired too, then I could ride more.
Steve order some tires & have them sent here. Mount them here, plenty others have. Dealer you're referring to is a 2 hour round trip from here & not very good one.
Cliff
2014 1000 V Strom
Offline SteveJ.
  • COG#: 5603
« Reply #14 on: April 10, 2019, 06:07:11 pm »
Ride On Cliff!
Gilbysan
Riding too much, is that like having too much money?
I didn't wanna be in the way with everything going on. Thanks for the offer and will most likely take advantage. I was kinda thinking about getting there a day or two early to help. I'm d*mned good at holding a clipboard.  :)
I'll shoot a PM when I order to let you know. I'll have a fresh front when leaving out of here so that should be good 2 go, just need the rear.  I'd best take a good look at my chain and sprockets, it's been a while.
Offline gpd323
« Reply #15 on: April 16, 2019, 08:58:02 pm »
Jim,
Gilbysan
I had a slow leak and it turned out to be a staple like the one in an office stapler. Only way I found it was as I was rubbing my hand across the tire slowly looking for a leak the staple cut my finger as it was just a mm or so sticking out.
Hey Cliff!!!! Thanks for doing this experiment. I enjoyed it!
Offline Old Man on a Connie
  • COG#: 9932
« Reply #16 on: April 16, 2019, 11:42:25 pm »
I cut up a PR3 for a puncture plug demo once for Cortez. Failed to take measurement tho'. Just cleaned the garagio out in prep for another skin change. Threw away 3 set's of case tires. Just in case I might need 'em. Funny thing about those tho'. You might need 'em but you just go buy another set. Damn things are like bunnies.
