Author Topic: front end wobble  (Read 1419 times)
Offline GIant81
  • COG#: 12285
front end wobble
« on: October 03, 2017, 10:58:25 am »
I definitely have a front end wobble going on with the C14.  It only happens when I brake.  I plan to order new pads and tire this week, but could it be the rotors?
I've heard that the stock pads can sort of deposit material on the rotors and make it feel like a warped rotor.  This would be what it feels like, it's a vibration that's directly proportional to the speed I'm going when I brake.  If that's the case, how do you clean the rotors to get rid of that material?  If I need new rotors, should I look at something better than stock?
Any suggestions on what else I should look at?
Thanks!
Offline Freddy
Re: front end wobble
« Reply #1 on: October 03, 2017, 11:26:59 am »
Yes & yes.  I've found that the only way to successfully remove pad material is to have the discs bead-blasted at an eng recon shop.
Offline gPink
  • MMVIII C XIV
« Reply #2 on: October 03, 2017, 12:05:57 pm »
year and miles?
Offline Zarticus
  • COG#: 10785
« Reply #3 on: October 03, 2017, 01:40:10 pm »
Brake cleaner & a scotch bright pad will clean the rotors  :beerchug:
1986 Honda V65 Magna, Black
1984 Honda V65 Magna, Black
1983 Honda V45 Sabre, Red
Offline GIant81
  • COG#: 12285
« Reply #4 on: October 03, 2017, 03:45:37 pm »
year and miles?
sorry
'09, 40,200mi  I put about 600/week on so expect that to climb.  I currently have a Metzler roadtech 01 on the rear with about 1600mi on it, and the shinko x16 front with about 7600 on it.  I plan to replace the front tire and brake pads here in the next week or so.
When I do the tire, I'll try to check the rotor for being true, and clean it with a scotch bright red + brake cleaner.  I don't have a gauge to test true, but is that something you could see with the naked eye while balancing?
Offline gPink
  • MMVIII C XIV
« Reply #5 on: October 03, 2017, 07:40:23 pm »
Might check steering neck bearings.
Offline Freddy
« Reply #6 on: October 03, 2017, 10:05:46 pm »
year and miles?
sorry
Absolutely not.  You need a dial gauge and have the bars tied to a full lock position with the gauge mounted on a piece of rail iron (that's what I use) to get a precise reading, plus a micrometer to measure thickness variation, which can also be the cause.
Hope you've been bleeding/flushing the fluid to prolong ABS life if it has it.
Offline GIant81
  • COG#: 12285
« Reply #7 on: October 07, 2017, 12:56:20 pm »
I do have the ABS and I have flushed everything once, I do wonder though how to know if I've actually gotten enough through the ABS to give it a good flush.
I can say with certainty that the ABS still works perfectly on dry pavement   :o had a teen on lunch break pulling out of a DQ without looking help me test them out.  Normally when I test the abs, I take it to my parents house.  They have a long gravel driveway, you can safely test abs at lower speeds.
I'm curious about the steering head bearing.  While I now this is something tire related, how do I know if the steering bearing is going out?
« Last Edit: October 07, 2017, 11:34:39 pm by GIant81, Reason: Iy Kant Spel »
Offline Deepsea
« Reply #8 on: October 07, 2017, 11:14:32 pm »
At 40k miles unless you routinely pull wheelies and drop back down hard your neck bearings are probably fine. Put the bike on the center stand and have someone push down on the back. Grab the forks near the bottom and pull forward. If there is ANY movement have the bearings checked and greased. If you do it yourself be careful, most people get them to tight. Overtightened neck bearings can cause a high speed weave. To loose and it just feels wonky.
Retired Navy Saturation Diver
