Concours 14 Discussion (C14 / ZG1400 / 1400GTR) => Tires/Suspension C14 => Topic started by: Wolverine on June 04, 2018, 06:55:18 pm
Title: Lowered 2009 (rear) should I do Front
Post by: Wolverine on June 04, 2018, 06:55:18 pm
So I lowered with TRex links, before and after measurements put me at 1.25 inch lowered from stock.
Rode for about 30-40 miles afterwards on some TN twisties where I live and handled fine...
So the question is should I correspondly lower the front any?
Title: Re: Lowered 2009 (rear) should I do Front
Post by: GrantE on June 04, 2018, 07:22:51 pm
As long as it hasn't adversely affected the handling, I would say that's a personal preference thing.
Post by: Wolverine on June 04, 2018, 07:30:01 pm
Good point.... The way I ride I doubt if I would feel/know a difference
Post by: gsun on June 05, 2018, 02:32:21 am
If you have risers, you may as well lower the front. I believe it is less than the rear - about 7/8"-1".
Post by: Wolverine on June 05, 2018, 02:33:01 am
Yes, I have risers..
Post by: Steiny on June 05, 2018, 09:18:39 pm
https://www.amazon.com/Techs-Motorcycle-Suspension-Motorbooks-Workshop/dp/0760331405 (https://www.amazon.com/Techs-Motorcycle-Suspension-Motorbooks-Workshop/dp/0760331405)
 Get this book and read it ,
 I would not just lower one end of a bike .   It will effect the handling
 If your going to lower it I would lower the front the same amount .
Post by: connie_rider on June 05, 2018, 11:12:09 pm
Also lowering the front, will keep the bike closer to the original geometry.
Post by: Wolverine on June 06, 2018, 01:16:33 am
Lowered the front 7/8 inch.
Now I have to move my newly installed dual horns to another location
Post by: gsun on June 06, 2018, 02:51:25 am
If the horns don't take up anymore room than the OEM (i.e. closer to the fender) you don't have to worry. There is enough clearance. I didn't move mine.
Post by: Wolverine on June 06, 2018, 10:12:49 am
These are aftermarket PIAA horns, dual horns.. they take up a lot more room. I removed them and think I found a place for them
Post by: Deepsea on June 12, 2018, 01:30:01 am
Changing the OEM geometry isn't always a bad thing. As long as you understand what effect the change will have and you adequately test the effect things should be ok. I raised the rear 44mm and lowered the front 35mm. I've been building race chassis for lots of years so this wasn't a random experiment but had a very specific purpose. Changing either end will effect both rake and trail but not by much. Grabbing a hand full of front brake changes the geometry by lots more than raising or lowering the back end. Even with it's a** up, nose down this bike is still very stable a high (150+) speeds and it's quicker-lighter in the twisties.
Post by: cuda on June 13, 2018, 01:29:23 am
I had the front and rear lowered , then went back to stock in the rear , front is lowered .
Did not like the feel with lowered rear , made the ride rougher.
