Author Topic: Traxxion Front Springs  (Read 2442 times)
Offline Doc
  • COG#: 12697
« on: September 02, 2018, 02:32:35 pm »
For those of you running traxxion springs upfront what spring rate do you use? I had mine rebuilt by Traxxion and they used 1.2 kg springs - when I sent the forks to them last year I weighed 265 but since then I’ve lost 45 pounds and I’m at 220.  The ride is a bit harsh up front and I’m wondering if 45 lbs could make a difference?  Should I go with a lighter spring?  I am a street/commuter rider and one-up only.
Offline Just Cliff
  • COG#: 9547
Re: Traxxion Front Springs
« Reply #1 on: September 02, 2018, 04:08:32 pm »
My paper work shows a spring rate of 1.15. I'm 175 lbs fully dressed with a pocket full of change! I mostly ride loaded, 2 up or both. I assume you've made adjustments & softened things up a bit?
Cliff   :beerchug:
Cliff
2014 1000 V Strom
Offline Staylo
  • COG#: 12548
« Reply #2 on: September 02, 2018, 04:27:03 pm »
If you’ve lost weight  you would need less preload to get the proper sag numbers. Here’s some basic info on spring rates:
When selecting a spring rate remember that a firm spring rate will not make a bike ride “Stiff”. In fact a firmer rate with less pre load gives a plusher ride than a softer rate with more preload. Spring rates and preload will determine the range of stroke that the bike uses. Soft rates allow the chassis to ride deeper into the suspension travel and therefore into the stiffer part of the stroke. (Leverage ratio curve for the geeks). If you are on the fringe of the spring rate range, don’t be afraid to select the firmer rate.
Having said that, you may have moved two spring rates and may actually be in need of a respring. Call and talk to Traxxion, they’ll help you determine where you’re at.
Lancaster County, PA
'11 C14
Offline Doc
  • COG#: 12697
« Reply #3 on: September 03, 2018, 03:12:27 pm »
Cliff   :beerchug:
Thanks Cliff.  I will experiment a bit but had things softened up to begin with.
Offline Doc
  • COG#: 12697
« Reply #4 on: September 03, 2018, 03:14:04 pm »
Thanks Staylo - good advice
Offline Douglas
  • COG#: 6426
« Reply #5 on: October 04, 2018, 02:39:16 am »
No. Ease off the compression damping.. better yet, do nothing til you learn what to do. Watch Dave moss videos on YouTube til you sound like him. Then try n do it.
ASE Certified mechanic.
Offline Douglas
  • COG#: 6426
« Reply #6 on: October 04, 2018, 02:49:11 am »
Offline Gixerhp
  • The Lighting Guy!
  • COG#: 12189
« Reply #7 on: October 10, 2018, 12:08:48 am »
Call and Speak to Dan in Service, you might be able to just change the oil and the level of the oil!
Offline Old Man on a Connie
  • COG#: 9932
« Reply #8 on: October 10, 2018, 02:22:23 am »
Agree. Springs hold the bike up and set sag. Oil and valving control damping and rebound. Traxxion has the answer.
Offline Gixerhp
  • The Lighting Guy!
  • COG#: 12189
« Reply #9 on: November 30, 2018, 04:08:49 am »
Well this post has come up before my posting!
I have to sell a set of Traxxion Dynamics AK20 kit, and a Penske rear shock.
I would need your forks in trade, and the shock would be a Purchase,
 $1500 TYD
I paid almost $2200 and they only have 3000 miles on them.
I will also pay for a re-spring set up for your weight!
Offline BadgerApaches
« Reply #10 on: December 11, 2018, 11:17:16 am »
SO, did you make some adjustments? Was there a particular platform of video that helped you more/most?
Legal Services for Manufacturers world wide.
« Reply #11 on: December 15, 2018, 05:44:02 pm »
Before watching the video's Doug posted, I watched "Suspension" and watched Chapter 1, Reality Check and several chapters that do basic explanations of the components. https://www.youtube.com/watch?v=ywkzj1x4YE8&list=PLe3ArNVOqr7vmicGVlmOd9bgjiP1xJNB_
I've now started watching the one Doug posted.   (now paused as I was in brain overload) {It's 1 hr-48 min. long...}
  https://youtu.be/f3xdM8E_q-I
It's all really interesting, and I think' I'm learning quite a bit.
I recommend these as Max does a good job of explaining things.
« Last Edit: December 17, 2018, 02:16:38 pm by connie_rider »
« Reply #12 on: December 25, 2018, 02:52:58 am »
TY!!
« Reply #13 on: December 25, 2018, 01:06:16 pm »
After watching the video's, I decided to experiment with what I learned.
Set sag and damping on my original but modifed C-10 front/rear suspension.
{also} Currently installing Race Tech Emulator {copies}.
Pretty slow progress because of the holidays, but finally completed.
« Last Edit: December 28, 2018, 08:35:14 pm by connie_rider »
« Reply #14 on: December 28, 2018, 05:45:03 pm »
Can anybody confirm if Traxxion offers COG members a discount??
Is Ron lurking out there??  :motonoises:
thanks,
My Horns have Horns.
Offline JDSCO
  • 2016 C14
« Reply #15 on: December 28, 2018, 11:12:09 pm »
Yes, Traxxion did give a COG discount, FEB2018
Gen James Mattis
« Reply #16 on: December 29, 2018, 01:16:11 pm »
THanks, but that was a cryptic answer.
Assume the discount CODE was FEB2018, but how much was it, and is it still valid?
I was truly asking (not very succinctly) if they are a participating vendor, and give a perpetual discount to COG members??
Offline JDSCO
  • 2016 C14
« Reply #17 on: December 29, 2018, 03:39:03 pm »
I purchased the entire suspension package in FEB2018
Listed is the COG discount, 2 places on invoice
Of course, you could always call Dan
I'm just being helpful
You're a smart-a**, Nate!
Gen James Mattis
« Reply #18 on: December 30, 2018, 11:51:31 am »
Oh, I've NEVER heard THAT before....  :nananana:
I Do appreciate you posting that, and confirming the discount, however.
Looks like a solid 10%, and I'm down for that!
Traxxion's been closed over the holidays, hence - no call.  ::)
I'll give Dan a "jingle" after the holidays, and see what's to be done with this wonky-a**, 5 year old suspension of mine!
« Last Edit: December 30, 2018, 11:59:13 am by ghostrider990 »
« Reply #19 on: January 04, 2019, 11:43:52 am »
I spoke to Dan, and he's easily convinced me to relinquish a substantial amount of Quatloos and let Traxxion do their magic on my Forks!
Question for all of you:
Do the Fork "feet" come off the lower fork tubes without removing the internals??
Of course I mean the lower stanchion with brake caliper mounts, and axle guides.
I'm 95% certain they don't, but just want to be sure, as shipping would be Much easier if they did.
Thanks,
« Reply #20 on: January 26, 2019, 06:01:04 pm »
How did it work out?
« Reply #21 on: January 27, 2019, 12:10:33 pm »
So, far - everything good, until I have to pay my CC bill this month!!!  :-[
To answer my own question: NO - the fork "feet" do not have to come off the bottom of the forks for shipping.
I have the forks reinstalled - and awaiting some warmer weather to get the rear Penske mounted.  No ride yet.  :'(
 Had alot of little projects running concurrently on the bike, and one sometimes can't precede another.
Can''t say enough about Traxxion (Dan) and their excellent customer service and quick turn-around!  I shipped the forks to them and paid to have a pro setup an install the Ak20's in my forks.  Money well spent.  :great:
Only took a week for them to do the work.  ROCKSTAR! :whoo:
I did receive the forks back, better packed then I sent them, but one of the plastic thumb adjusters was broken in transit.  Emailed Dan, and without question, he mailed me a brand new set of Billet Adj. knobs.
GREAT c/s!
At $25 a pair, i'd say just go ahead and buy them if you're even thinking you MIGHT break your plastic knobs off....because you will - it's just a matter of time!
I'll post impression of the suspension once I get her back together, and a few (hundred) miles on her.  ;D
Offline IBAJIM
  • COG#: 12891
« Reply #22 on: March 07, 2019, 01:42:45 am »
For your weight, RaceTech recommends a 1.35 Kg/mm rate spring,  which is unavailable.  The stiffest they have is 1.2 Kg/mm.
So, I would say you are doing as best you can with the springs you have.   Maybe you could go a little less on the damping .....
They also recommend 5W fork oil.
« Last Edit: March 07, 2019, 12:51:53 pm by IBAJIM »
IBA # 35372  BBG (5-2014)
Other SS1K's x8  (2009-2017)
