Author Topic: mis match tires  (Read 1395 times)
Offline Jim
mis match tires
« on: May 23, 2019, 07:24:11 pm »
hi guys, i have a pr4 on the front(2015 connie). i have prolly 2000 miles on it. i want to put a dunlop RS3 on the back. local bike shop says thats a no-no with such a heavy bike. he also wants to sell me a new TPMS sensor. says they go in 4 years (250$?) for the part :-\ says i should do it while tire is off save labor $160. sheesh, jim
Offline gpd323
Re: mis match tires
« Reply #1 on: May 23, 2019, 08:31:17 pm »
Mix and match the tires at will, there are no negative issues concerning that. I am throwing a RS3 new front where the rear is a worn Avon Spirit ST. I have mixed tires all the time. No negatives, I think I typed that twice.
Offline gpd323
Re: mis match tires
« Reply #2 on: May 23, 2019, 08:32:18 pm »
TPMS sensor battery will last 7 years or more. Partzilla when the time comes.
Re: mis match tires
« Reply #3 on: May 23, 2019, 09:39:54 pm »
Jeepers... I hopr you aren't buying the actual tire from that guy, he seems a bit greedy....
as for tire selection, no big deal...
with regard to the TPMS sensor, tell him to "pound salt"... we never change them until they stop working, which in some cases goes up to 8 years.. you have the "newer" style sensors, and the battery capacity is far greater on those than the original ones that came out when the bike intro'd in '07....
Mine were replaced in late 2012, under Kaw's extended warranty... so depending on when you bought your bike, (if it was in 2016, even tho a 2015 model) it may be covered if they did "die"... and if they didn't, and you are still under the original OEM warranty, take a trip to the thread about extended GTPP/KPP warranty... the price you pay for that alone, will cover the replacement on them... worth the investment as long as your original warranty has not expired.
http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/gtpp-36-month-extension-for-$339-updated-2232013/
make a call, and ask them what the status of your protection plan is, and if it's close to expiration, do it over the phone right then and there...
Offline Daboo
  • COG#: 12797
Re: mis match tires
« Reply #4 on: May 24, 2019, 01:56:26 pm »
My first tire replacement was a mis-match.  The bike came with Bridgestone tires and the dealer installed a new Pirelli.  They didn't have any qualms about it, and in fact, it worked great.
I had a similar experience to what you encountered.  For several years, I went to an independent repair shop.  They had no problems mixing tires in those days.  Then a new manager came in and when I wanted to replace just one tire, they said they couldn't do it.  That it was unsafe.  Same mechanic.
As the saying goes, "follow the money".
Chris
John 14:6
Offline Red Fox
  • COG#: 11691
Re: mis match tires
« Reply #5 on: May 24, 2019, 05:55:12 pm »
Agree
Re: mis match tires
« Reply #6 on: May 24, 2019, 07:21:26 pm »
Chris
I always did my own "mechanics", but had an occasion of a front wheel bearing go bad on one front side of my truck, about 12 years ago.. it happened on the way to work, and I knew what happened in route, as the bearing caused the disc to be sloppy, and ate the pads off that tires brakes down to metal to metal right before I got to work... luckily the place I had been buying tires from, was walking distance from my job... I dropped the truck off, told them to replace the rotor, and bearings, and pads on that tire, and call me when it was done...
I got a call from the "mechanic" (not the shop manager that I dropped the truck off to), about 4:00, and he told me it was ready, and the price....
When I got there, and asked the manager about what happened, he said "I dunno, lets go talk to the guy doing the fix"...
The mechanic insisted on replacing both rotors, new bearings in both, and both sets of brake pads...   >:( >:(
I hit the roof, and looked at the manager, and he even asked the "mek-nik" were both sides bad? ... then the kid went on and on about how you can't just replace one side... they both have to be replaced.... I said show me the all the parts you took off.. we examined the "undamaged side" which was virtually pristine, even the rotor and pads, and the bearings... were almost perfect, even then, the rotor had enough stock it could have been surfaced at least 2 times, and still be in spec...
The manager/owner grabbed me and we walked in his office, and he removed the labor charges for the job, but I still needed to pay for the parts used...and said see me again next time you need tires, and I'll take care of this in a better manner.
I agreed, not holding him responsible, and 6 months later I got a free set of 80k tires mounted up on my other truck.... good business man... he told me he fired that mechanic the next day after the "arguing with a customer who is a mechanic also" incident.
 :)) >:D :))
Offline HeavyRotation
Re: mis match tires
« Reply #7 on: May 25, 2019, 05:17:46 am »
I like to stick to the same brand on both ends but frequently run a softer front than rear, so like a pr4 front and pr3 rear or Power 2 front and pr4 rear etc. I wouldn't run a harder front and softer rear if you push the bike hard, i'm far more comfortable stepping the rear out on corner exit than pushing the front tire on corner entrance. Either way, the mechanic is full of crap.
I like sheds and ninjas.
Online TimR
Re: mis match tires
« Reply #8 on: May 30, 2019, 05:38:50 am »
Having the same manufacturer tires on the front and back is nice BUT. What do you do when out in back woods Montana and you have to replace a rear tire like I did. I had a set of fairly fresh Michelin PR 3's. Nice tires. But I took a thin piece of copper wire in the back tire. I still can't figure just how it poked a hole but it did. TPS alarmed and let me know tire pressure was below 36psi and the I watched it dropping. Saw a Harley sign with a shop 2 miles away. Whew! I stooped in and was treated OK but they would not get me a new tire. I did get air. They did direct me to a metric shop where I picked up the only tire in stock the Connie size. Plugging was out of the question because a plug would have been impossible to get in. It was a Conti something. Got me home and I rode that tire till it was worn out with a PR3 on the front. Now I have a set of RS3's front and rear and these are nice tires.
Re: mis match tires
« Reply #9 on: June 05, 2019, 01:16:44 am »
That's why plug kits come with a jab file to hog out the hole. You spent new tire money instead of 35$ on a quality plug kit. I have used mushroom plugs on sport bike tires under severe use with good results, don't be afraid to plug your tire!
Online TimR
Re: mis match tires
« Reply #10 on: June 05, 2019, 08:49:31 pm »
There was no way one was going to get  the round file in that little hole....it was the size of a pin your mother had for sewing. I have plugged a hole from a nail and a screw but not a pin.
Offline Diz
  • COG#: 12056
Re: mis match tires
« Reply #11 on: June 05, 2019, 11:43:42 pm »
Wouldn't you need to mark, then pull the pin in order to get an area to ream out? Hard to find the actual hole I would think after pulling the offending object. Escaping air through soapy water would indicate the area, still need the actual hole.... A fine touch?
Online TimR
Re: mis match tires
« Reply #12 on: June 06, 2019, 04:34:36 pm »
What caused the hole was a single strand piece of copper wire about the diameter of a pin. The wire was pulled out. There was no way to get a plug file in that tiny hole. I would have patched on the inside had I known were to find a tire shop. Best option at the time was replace the tire. I was in the middle of Montana with few options. I found no adverse issues with a Continental on the back with a PR3 on the front. I ran it this way till both tires were worn out.  The RS3's now that is a set of tires. Tim
« Last Edit: July 04, 2019, 06:34:34 pm by TimR »
Offline gpd323
Re: mis match tires
« Reply #13 on: July 03, 2019, 08:46:11 pm »
Z900RS came with Dunlop GPR 300 tires as new OEM. I picked up a nail in the rear and even with a tire repair it was leaking 4-5 psi every 200 miles on my trip. So a new Pirelli Super Sport rear and the stock OEM GPR on the front for now. Handles great!
