Author Topic: New 190/55/17 vs. old 190/50/17  (Read 1888 times)
Offline Nottacop
  • I have a passion for riding my C14...
  • COG#: 12909
« on: February 04, 2018, 02:41:11 pm »
In case you wanted to see the difference in the two. Happy Riding!
Andre "Nottacop" Grande'
~84' VF1100S (out)
~03' K1200RS (out)
~02' VTX1800C (out)
~12' C14
Offline rrsperry
  • Senior Moment Member
  • COG#: 12503
Re: New 190/55/17 vs. old 190/50/17
« Reply #1 on: February 04, 2018, 03:22:54 pm »
I looks more impressive next to an old tire. It’s what 0.5” taller?
Offline Nottacop
  • COG#: 12909
« Reply #2 on: February 04, 2018, 03:25:06 pm »
Tall enough to start worrying about the traction control system. The guys told me it would be ok though. Yea, about 1/2” I’d say.
~84' VF1100S (out)
~03' K1200RS (out)
~02' VTX1800C (out)
~12' C14
Offline rrsperry
  • COG#: 12503
« Reply #3 on: February 04, 2018, 03:50:28 pm »
Nope, no worries there. The only issue is for the vertically challenged.
« Reply #4 on: February 04, 2018, 04:47:32 pm »
Great example. This is why so many are impressed with a 55 over a 50. They all feel the difference from a worn out 50 and a brand new 55.
When you raise the rear of any bike by the difference of those two tires your gonna say: Wow! The bike turns in so much better!" so the 55 must be better.
No, its just the big  change in ride height. You can do the same thing by adjusting the rear preload  higher and accomplish the same thing.
2000 Red C10 1052 kit
Offline rrsperry
  • COG#: 12503
« Reply #5 on: February 04, 2018, 07:24:50 pm »
Maybe... crank in too much preload, you screw the sag...  ideally you had rear shock height adjustment, ala Penske, or other good shock.
Offline Dragunslayer
  • " An APEX is a Terrible thing to Waste!!"
« Reply #6 on: February 04, 2018, 08:24:08 pm »
Exactly, people that think you can just turn up the preload have no clue how suspension works. Yes it will turn fast but be unridable due to it being so stiff every noock and cranny will bounce you off line.
Kevin Reinhold
Robertsville, MO
15' Kawasaki Concour 14
16' Susuki GSX-S1000F
Offline Egodriver71
  • I'm in here somewhere
  • COG#: 8321
« Reply #7 on: February 05, 2018, 11:39:45 am »
3/8"
Thomas Mann
Jacksonville, FL
COG #8321
Offline Egodriver71
  • COG#: 8321
« Reply #8 on: February 05, 2018, 11:46:32 am »
Nope, system self calibrates to the tires on it once you start riding
Thomas Mann
Jacksonville, FL
COG #8321
« Reply #9 on: February 07, 2018, 03:38:28 pm »
That would be an incorrect statement.
Preload CANNOT make a spring more stiff or less stiff. Preload can only raise and lower the ride height or SAG setting.
« Last Edit: February 07, 2018, 03:41:52 pm by Daytona_Mike »
Offline JDSCO
  • 2016 C14
« Reply #10 on: February 07, 2018, 06:04:25 pm »
Speaking of 50's vs 55's...
Does anyone have a rear-hugger, inner rear fender with a 190/55?
I'm curious if there is clearance, mounting a 55.
Gen James Mattis
Offline Nottacop
  • COG#: 12909
« Reply #11 on: February 07, 2018, 06:06:38 pm »
Do you have one of the 50 size? If so got a pic of it? That would be cool to have.
~84' VF1100S (out)
~03' K1200RS (out)
~02' VTX1800C (out)
~12' C14
« Reply #12 on: February 07, 2018, 07:12:30 pm »
I do and I did and it fits fine but obviously  I went back to and have stayed with  a 50 ever since trying the 55 but I had to have a pro set up my suspension and sag settings for me to get proper handling and turn in.. I run an Ohlins and AK20's
« Last Edit: February 07, 2018, 07:16:53 pm by Daytona_Mike »
Offline JDSCO
  • 2016 C14
« Reply #13 on: February 07, 2018, 09:37:11 pm »
I don't know if you are directing this "50 size" question to me...
Murph's has Skidmarx Inner rear fender's on his website.
Gen James Mattis
Offline Egodriver71
  • COG#: 8321
« Reply #14 on: February 08, 2018, 11:14:55 am »
I do
Thomas Mann
Jacksonville, FL
COG #8321
Offline Deepsea
« Reply #15 on: February 15, 2018, 02:36:53 pm »
As to the question of Ride Height. While many have lowered the rear with longer shock links I went the other way and raised the rear 44mm by changing the links. Along with a 55 series tire the handling is now significantly lighter without any high speed degradation. I also run Ohlins front and rear.
Retired Navy Saturation Diver
