Author Topic: New shinko tire disapontment  (Read 1402 times)
Offline RoadKillHeaven
  • How hard can it be? 。◕‿◕。
« on: September 29, 2018, 03:14:09 am »
It seems like I got a defective new rear tire. At about 35-40 mph handlebars shimmy. At higher speeds rear end seems like it is bobbing/shaking. When on center stand, gear engaged with engine running, I can see a low spot on the center-left side of rear tire. It is as if a bias ply tires developed flat spot after sitting for a while.
Front seem to be true, no high or low spots when spun by hand/foot.
Sorta disappointed ...
We'll see what the guys at the shop say...
Offline SteveJ.
  • COG#: 5603
Re: New shinko tire disapontment
« Reply #1 on: September 29, 2018, 09:51:09 am »
If no joy at the shop you may want to ping Western Powersports. They were quite helpful and cooperative when I had issues with the Journey radial on my c-10
Tick Tock, baby (Ironbuttal)
Offline CRocker
  • '02 C10 CDA # 416
« Reply #2 on: September 29, 2018, 06:43:32 pm »
Not sure which tire you are referring to...pretty sure Shinko doesn’t offer a bias ply tire for the C-14...
« Last Edit: September 30, 2018, 02:59:33 am by CRocker »
« Reply #3 on: September 30, 2018, 02:13:45 am »
When bias ply tire sits laden for a while it develops a flat spot. New rear tire on my bike has something like a flat spot when rotated. Another word is out of round.
Don't worry, noone here is trying to confuse you... :beerchug:
« Reply #4 on: September 30, 2018, 02:16:40 am »
I've read a post on here that someone had similar wobble 35-45 mph or so. It turned out, in his case, wheel weights were no symmetrically installed upon balancing a tire.
I've spotted that rear tire has 2 1/4oz weights on one size and 5 1/4oz weight on the other.
I'd prefer center ridge clamp-on weights. I guess shop I'd gone to doesn't use such wheel weights.
I will investigate further.
Offline Douglas
  • COG#: 8649
« Reply #5 on: September 30, 2018, 08:27:46 pm »
There is no more politically correct way to say this: I suspect you didn't seat the bead. Have you been trained on how to do this?
« Last Edit: September 30, 2018, 08:38:22 pm by Douglas »
ASE Certified mechanic.
« Reply #6 on: October 01, 2018, 01:16:15 am »
I didn't M+B tires. Shop did.
I am investigating all aspects. So far I haven't found the culprit.
Thanks.
Offline lather
  • COG#: 10690
« Reply #7 on: October 01, 2018, 03:27:58 pm »
Just to clarify what I beleive is a typo: reading your sentence correctly as written your saying two 1/4oz weights on one side and five and a quarter oz  weight on the other.
You actually mean 2 weights on one side and 5 on the other for a total of 1 and 2/4 oz, correct?
Offline Just Cliff
  • COG#: 9547
« Reply #8 on: October 01, 2018, 04:08:54 pm »
If I'm reading this right he's missing Brad's question.
That's the way I see it. 7 total, 2 on 1 side 5 on the other which is 1 3/4 oz.
Cliff
2014 1000 V Strom
« Reply #9 on: October 01, 2018, 06:25:41 pm »
yes, correct
Offline Douglas
  • COG#: 8649
« Reply #10 on: October 01, 2018, 09:57:48 pm »
Hey if you got to find a shop that knows more than I do.. they're all a bunch of dipshitz learning as they go. I'm not going to pay them money to learn on my bike when I already know how to do it correctly . You're going to have to find somebody who knows how to do it correctly already. I think the shop is the problem not the tire
« Reply #11 on: October 02, 2018, 01:23:26 am »
Ted guy who I normally go to is in the process of changing shop location. He wasn't able to help me. He refereed me to this new shop.
So, here I am.
I got the tire balancer, I'll remove wheels and re-check.
If this fails, I'll find a shop with dynamic balancer.
I know it ain't head bearings as it wobbles all the time, not just under deceleration.
Cheers...
Offline lather
  • COG#: 10690
« Reply #12 on: October 02, 2018, 11:29:27 am »
Using static balance technique I usually cut a 1/4 oz weight to get my final balance. Every wheel that has been balanced by a shop uising a spin balance has be out of balance when I check with my static balancer. Wether that is due to shop tech incompetence or the machine, I can't say but in my opinion static balancing is more accurate. Yamaha service manual has the static balance technique I use.
You say you can see a flat spot on the tire, I suggest that is the most likey cause of the wobble - a defective tire.
I used to like the Shinko Verge  but quit using them due to what I thought was poor quality control.
Offline Douglas
  • COG#: 8649
« Reply #13 on: October 02, 2018, 02:55:41 pm »
This seems unrelated at first but I need to check. You're sure the bike is not pitched forwards by a suspension adjustment you made at the same time that you changed the tire? These are the same symptoms you get when you jack up the rear shock...
« Reply #14 on: October 02, 2018, 09:18:46 pm »
Based on experience with other things, the last thing that was altered(changed) is the root cause of new problems.
The only thing I changed was tires.
I've set up suspension sometime ago to where it feels the best for me.
P.S How does out of balance rear tire feels on a bike? How does rear out of balance tire transmit to the front?
More or less like a wiggle or ?
Cheers...
Offline lather
  • COG#: 10690
« Reply #15 on: October 02, 2018, 10:08:46 pm »
Since the front tire was also replaced the problem could be a misalligned front axle. The service manual has a a procedure for preventing this in the whell installation section, if the tire mounter did not follow this could be your problem.
"Before tightening the axle clamp bolts on the right front
fork leg, pump the front fork up and down [A] 4 or 5 times
to all on the right front fork leg to seat on the front axle.
NOTE
○Put a block in front of the front wheel to stop moving.
•Tighten the axle clamp bolts on the right fork leg first.
Next, tighten the left axle clamp bolts.
Torque - Front Axle Clamp Bolts: 20 N·m(2.0 kgf·m, 15 ft·lb)
Offline Buzzard
« Reply #16 on: October 03, 2018, 01:19:18 pm »
In reply to the OP, yes, there are out of round tires out there, brand new. I am on my fifth or sixth set of Shinko Ravens. This latest set has an out of round rear. While annoying, I have decided to wear it down a while, but I doubt I will keep it till it is worn out. I am annoyed enough that my next set of tires will be another brand.
« Reply #17 on: October 04, 2018, 12:55:56 am »
Thanks for the suggestion.
These people from Western Power Sports are absolutely AWESOME.
Rep I've contacted is ready to ship new tire upon a proof of destruction of the old.
Cheers...
Offline Douglas
  • COG#: 8649
« Reply #18 on: October 04, 2018, 02:18:30 am »
To answer your question you need someone to look at it with you. There are too many variables to explain all of them here. I wish it were that easy.
Offline Red Fox
  • COG#: 11691
« Reply #19 on: October 07, 2018, 02:45:33 pm »
Unlikely a rear tire issue causing action in the handlebars; gotta be a front tire / suspension issue.  A cheap experiment: try pumping up the front to 45# cold pressure.  Burst a tire concern? nope, I normally run my front at 44-45# cold, BTW.
My last set of tires, mounted 3000 miles ago using a friends house/equipment, we didn't balance the rear because of other issue specific to my friend.  Did put balancing 'DynaBeads' in front tire only - my first time using this little bead approach to balancing.  Bike feels good - even with rear unbalanced.  Avon Storm 3's for the record.
« Reply #20 on: October 07, 2018, 10:34:36 pm »
Waiting for new tire to show up. M+B then we shall see if she is smooth again.
Cheers...
Offline Douglas
  • COG#: 8649
« Reply #21 on: October 08, 2018, 10:21:08 pm »
Yes please keep us posted on the finale. That is where I learn the most. The fix for this is where the education happens for me  :beerchug:
« Reply #22 on: October 12, 2018, 10:12:55 am »
I got new tire M+B. There was minimal (short video will follow) axial run-out on new tire.
Busy doing other things to ride.
When opportunity presents itself, I'll ride and report my findings.
Cheers...
« Reply #23 on: October 20, 2018, 04:37:55 am »
Front still wobbles.
Offline Dragunslayer
  • " An APEX is a Terrible thing to Waste!!"
« Reply #24 on: October 20, 2018, 07:35:13 pm »
I know shinko has supposedly gotten better but honestly I would never run one. Is your life truly worth saving a few dollars. I am sure this will rub some the wrong way, but I have a nack for that I guess.
« Last Edit: October 20, 2018, 07:46:30 pm by Dragunslayer »
Kevin Reinhold
Robertsville, MO
15' Kawasaki Concour 14
16' Susuki GSX-S1000F
