I called my local Kawasaki shop today to order a new TPMS for the front and make sure they have Michelin Pilot Road 4 GT front and rear in stock.
2 things to discuss: They only have Road 5 now, and Kawasaki discontinued the TPMS for my 2011 and are saying the new one for the newer C14 will work. He said it operates in the same 315 hz frequency. I have the extended warranty is why I'm going for a new sensor.
Has anyone tried the new sensor on an older bike, and has anyone rode the Road 5 yet?
Vader , I installed the new style sensors on both front & rear , did the work myself & dealer charged me $25.00 to program them. that was on my 2010 and about 4 years ago.
Spidey, you must have had the new ones installed at that period, I have to presume...
good price tho on the programming...
the "new" sensors are all that are available now, for current bikes... if you have a pre '13 bike, and had a KPP extension updates, that provided covereage under KPP for replacement, they will "keep" the sensors they pull out (and send them back to Kaw, to verify the replacement), unfortunatly the new style are made to prevent replacing a battery.. (yes, I know people are "saying they can do them"... but I am not positive they are able to "correctly"... in other words, until I see a dozen, I ain't agreeing they can be done reliably)... Hold on to your old sensors, and have the battery replaced... loosing an old sensor for a new style, is tossing away money..
I do suggest going back, and reading this whole discussion, from the beginning, and decide on your desires to try it...
We already know how the success ratio on the old sensors replacements went (very good success ratio), the new one... so far, just the reported posting Freddy found, from an Aussie website, and kindly posted here... personally, I'd give it a go, after seeing the pictures... but then, I'm cheap, so if I hosed an already dead sensor... meh...
jmho
I had my "old style" ones replaced under warranty in fall of '12, and luckily I got some of the last "old style ones" in the replacement... next time I need them done, I'll do my own battery replacements... and I tried to get my old ones, but they wouldn't let me have them...(as I wanted to replace those batteries when the ones I got, needed replacing... and then both sets were already programmed into my ECU, so I could swap...)
just for a refresher on the progression;
pre '13 models
21176-0107 SENSOR,TPMS 315MHZ
superseded by
SENSOR,TPMS 315MHZ
21176-0125 ..... no longer available... neither number
post changeover '14 to current...
21176-0748 SENSOR,TPMS 315MHZ
$213.02 each...
