Author Topic: Ohlins fork spring for GTR 1400  (Read 2195 times)
Offline chinese
« on: November 21, 2017, 11:09:22 am »
Dear forumer
i am think of getting an Zx 1400 FGRT207 Ohlins Fork for my GTR 1400 2016 model  . Before i Click to buy on the web . Can anyone advise what spring should i use for my GTR 1400. i am about 95kg with 175cm height.
Ohlins seller advise me 13Nnm but my bikeshop advise 10Nnm. (Abit confusing)( Please advise )
Thanks alot guy.
Offline Rico
  • COG#: 12496
Re: Ohlins fork spring for GTR 1400
« Reply #1 on: November 21, 2017, 11:12:05 am »
Contact Ohlins directly and ask them.
« Reply #2 on: November 21, 2017, 03:24:47 pm »
Chinese, I sent a note to ZG to ask him.
I think he had the Ohlins on his bike.
Not sure whom else has them.
Watch and see if he replies..
« Last Edit: November 22, 2017, 12:26:35 am by connie_rider »
« Reply #3 on: November 21, 2017, 06:17:57 pm »
I know I would take Ohlins suggestion over any shop unless they taught Ohlins how to build the things.
Offline seagiant1
  • COG#: 11323
« Reply #4 on: November 22, 2017, 02:14:22 am »
Hi,
      Listen, call Ohlins and talk to the nice Techs, they know what they are doing!!!
As you know you can buy a REAR shock made for the C14....
Not so on the front forks, those are made for the ZX-14 and when used on the C14, that has to be taken into account!
Just sayin, talk to OHLIN"S! :great:
Offline ZG
  • COG#: 9735
« Reply #5 on: November 22, 2017, 01:36:26 pm »
Sorry Ted, I don't recall what springs I ran in the forks, been too long ago for this old memory...  :truce:
Good luck to the OP, enjoy that new gold!  :great: :great:
Offline The Pope
  • North Carolina AAD
  • COG#: 9994
« Reply #6 on: November 27, 2017, 09:01:09 pm »
When I got mine, the Ohlins shop that I worked with, installed a 10Nnm in one and a 10.5Nnm in the other. This was for a rider w/gear at a weight of 260 lbs.
« Last Edit: November 27, 2017, 09:38:21 pm by The Pope »
The Pope
Offline chinese
« Reply #7 on: November 29, 2017, 06:50:04 am »
Thanks Pope.
yesterday just receive my ohlins fork. its been install with 13Nmm spring . ( Recommended by Kyle Racing USA )
Next step is installation & tuning .
« Last Edit: November 29, 2017, 07:02:23 am by chinese »
« Reply #8 on: November 29, 2017, 12:36:22 pm »
Those look great!
Good luck on the install...
Offline chinese
« Reply #9 on: December 06, 2017, 05:33:49 am »
Hi Guys
My Ohlins fork ABS mounting is different from the drawing you send me . Maybe is due to my fork is a newer version type. Need to Fabricate a C bracket for ABS mounting . Everything Plug & Play . Only Sag adjustment abit . That all.
Currently My GTR is install with the following .
Ohlins Fork
Ohlins Shock
Rapidbike Race Module
Rapidbike Quickshifter
Rapidbike Youtune
Galfer Front Rotor
Titanium front Caliper
Bearing Masterpump
Bearing Clutch Masterpump
Oberon Slave Clutch Pump
Full System Akrapovic
C14 Sportscreen
Intelligent LED head light
Launch control
Please advise if any other upgrade require.
i am think of installing Ohlins steering Damper. But till now , cannot find  information on web for  the mounting Bracket .
« Last Edit: December 06, 2017, 05:38:07 am by chinese »
Offline The Pope
  • COG#: 9994
« Reply #10 on: December 06, 2017, 10:01:11 am »
Hummmm....... please post a photo of the ABS mounting location and I'll find or take another photo of mine so that we can compare. I'll add mine to this post.
« Last Edit: December 06, 2017, 10:07:01 am by The Pope »
The Pope
Offline chinese
« Reply #11 on: December 07, 2017, 01:26:11 am »
Hi  Pope
Below is the Photo of the abs hole & Mounting of abs sensor . i have not gone down to bikeshop to look yet . will update with bracket when i fetch her back.
The picture green colour is not bracket. Its the abs sensor secure on the red C bracket . Need to shave abit plastic on the sensor to fit into the hole
« Last Edit: December 07, 2017, 01:30:35 am by chinese »
Offline The Pope
  • COG#: 9994
« Reply #12 on: December 07, 2017, 10:38:26 am »
That's the same as on my Ohlins fork, so the bracket design that I sent you will work. As I've stated (in other threads, but you may not have seen those comments), you will need to modify the ABS Sensor by cutting off it's mounting tab and the clocking features it has. I used a Deimel with a sanding disk to clean up the ABS Sensor so it will slide into the large hole in the bracket (until the sensor is fully inserted) and use the set screw to secure it. It only takes something like a 1/2 turn or less once the set screw makes contact to secure the sensor. Then mount the Sensor & Bracket Assembly to the fork.
I had a lot going on yesterday afternoon, so I wasn't able to take photos of my setup. I'll try to get them this afternoon when I get home from work.
The Pope
Offline The Pope
  • COG#: 9994
« Reply #13 on: December 08, 2017, 12:55:10 pm »
Here are some photos of the bracket and ABS Sensor on my Ohlins Fork.
« Last Edit: December 08, 2017, 12:58:46 pm by The Pope »
The Pope
Offline The Pope
  • COG#: 9994
« Reply #14 on: December 08, 2017, 12:56:43 pm »
two more....
The Pope
Offline The Pope
  • COG#: 9994
« Reply #15 on: December 08, 2017, 12:58:17 pm »
and one last one......
The Pope
Offline chinese
« Reply #16 on: December 09, 2017, 01:48:30 am »
hi Guys ,
You shave away the mounting on the abs sensor . While i remain mine . i yesterday went to view my bike. its not yet ready . so i did not take any photo. latest update from my bikeship  , they don't intend to use any bracket. Just shave abit of the abs mounting Tab & use back the ABS mounting .
« Last Edit: December 11, 2017, 12:50:02 am by chinese »
Offline chinese
« Reply #17 on: December 11, 2017, 12:59:11 am »
Hi . Guys
Ohlins Fork is fully install . Its Plug & Play + Sag adjustment . Just Need to Shave abit of the ABS sensor Tabs will do & install back like stock fork . Tested the abs system . Everything works fine .
13Nnm Spring ( Compression 3 Clicks & Rebound 4 Clicks just for start ) ( May need to adjust abit when hit highway & Corner ).
1 fork is rebound & 1 fork is Compression ( very easy tuning fork )
Refer to Photo for ABS sensor installation .
Offline chinese
« Reply #18 on: December 11, 2017, 02:40:13 am »
more photo of the GTR
Offline chinese
« Reply #19 on: December 11, 2017, 02:41:12 am »
More photo....
Offline ZG
  • COG#: 9735
« Reply #20 on: December 24, 2017, 09:01:32 pm »
Looking good Chinese, I like how you roll, nice ride!  :great: :great:
