Author Topic: Pilot Road 4 or Road 4 GT?  (Read 624 times)
Offline Eric
« on: September 04, 2018, 01:48:05 pm »
Due to a tiny staple, and local dealers that won't fix my tire because of "liability issues", I'm getting a new rear tire on my 2012.  The dealer has the Road 4 in stock at $179 + install, but now I'm wondering if I should get the GT since the Connie is pretty heavy.  Thoughts, experiences, anyone?
Thanks!
2012 Concours - My new baby!
1981 KL250 - ridden to death
Offline kv5e
  • Roll miles, Keep smiles
  • TARKUS - Texas Bad Boy
    • SPIN Weather Centre
  • COG#: 5063
Re: Pilot Road 4 or Road 4 GT?
« Reply #1 on: September 04, 2018, 02:23:16 pm »
Thanks!
 I have run both, if you are one up the the PR4 is ok, two up I prefer the GT.
The GT is about 1/2 inch taller so the turn in is a little quicker.
Craig
« Reply #2 on: September 04, 2018, 02:39:08 pm »
Eric; Which size will you be installing? 190/50 or 190/55?
I was aware the 190/55 is taller than the 190/50.
Wasn't aware the GT itself was taller than the other.
New learning..
  :great:
Was a little confusion. The GT is the same size as std.
Difference is 190/55 vs 190/50.
« Last Edit: September 04, 2018, 03:10:33 pm by connie_rider »
Offline kv5e
  • COG#: 5063
« Reply #3 on: September 04, 2018, 02:47:57 pm »
Good point.....I buy the 55 GT and that was what i was referring too.
Offline Eric
« Reply #4 on: September 04, 2018, 03:01:12 pm »
I was planning on staying with the stock size.  Is there any real advantage to going with the bigger tire?  I live in Nebraska (straight roads) and don't try to see how fast I can take on ramps before crashing, so extra lean angle isn't a selling point!   :)
« Reply #5 on: September 04, 2018, 03:16:36 pm »
Sounds like the 190/50 will be fine for you.
The 190/55 handles slightly different and that extra 1/2" also raises the seat height.
  (Which is a negative for short folks like me).
Unless your riding 2 up or the bike is heavily loaded for trips, the std will probably be ok too.
  (and it's cheaper)
Offline Eric
« Reply #6 on: September 07, 2018, 02:12:15 pm »
PR4GT installed last night.  Now I have the less than great battleaxe in the front and a good tire on the rear!
