Author Topic: Rattling front end on my 12 C14  (Read 1031 times)
Offline ANTHONY
« on: July 05, 2018, 07:20:05 pm »
Cant figure out why my 12 Connie rattles so damn much. I have ripped this damn bike down to nothing and checked plastics, steering, brakes, forks and damn thing still is clunky; it is driving me nuts. The handling is fine and I have no wobbling or stability issues at high speeds, its just this damn rattle/clunky sound over the firm bumps here in good old Michigan where the roads are like speed bumps. Anybody have this issue and find the culprit?
Tony Johnston(TJRIPPER)
Offline AmphibSailor
  • Hooligan
  • COG#: 12210
Re: Rattling front end on my 12 C14
« Reply #1 on: July 05, 2018, 08:15:30 pm »
I had a similar issue on a different bike.  Ended up as a loose front fender.
Offline SWOJO95
  • COG#: 190
« Reply #2 on: July 05, 2018, 08:24:07 pm »
I don't know if the rattle your having is the same as what I had or not, but worth mentioning nonetheless? My noise was more of a loud buzz, like plastic rattling against frame?  Mine was driving me nuts and took forever to figure out, turned out to be the plastic cowling directly above the headlight, more specific, the point or narrow part just above the center of the headlight. If yours is like mine was, if you tap on the cowl, just above the headlight center, you will hear an audible "CLACK".  I put a bit of adhesive backed foam on the underside of the plastic, and I have never heard the rattle or buzz again.
Offline ANTHONY
« Reply #3 on: July 09, 2018, 07:05:13 pm »
I can't figure it out!!! >:( I put foam underneath the nose, I have put foam in other places, checked all the bolts and pins. I lined the front fender with foam underneath to deaden that and nothing will take the rattle away. I keep thinking its the suspension but it handles great. it is clunky sounding though.  I
Offline Fred_Wa2gzw
  • COG#: 10400
« Reply #4 on: July 09, 2018, 11:48:52 pm »
I have a fender extender on my bike that was not mounted quite right and when I went over large bumps the bottom of the fender extender would just catch the front push pins of the belly pan.  It took me a week to figure it out as it was not obvious to me.  Repositioned the fender extender and all good for the next 52k miles.
Offline Deanc
  • COG#: 10429
« Reply #5 on: July 10, 2018, 07:22:24 pm »
Do you have Canyon Cages on your C14?
2011 C14 Silver, Canyon Cages, Leo Vince SBK exhaust, Sargent seat, SISF Evolution Flash, etc.
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #6 on: July 10, 2018, 10:38:37 pm »
Maybe it’s not the bike. Maybe you are rattling.  :))
Offline gPink
  • MMVIII C XIV
  • COG#: 9403
« Reply #7 on: July 10, 2018, 11:50:06 pm »
Have you checked your front fairing mounting bolts?
Offline ANTHONY
« Reply #8 on: July 11, 2018, 03:15:58 pm »
That is a given!
Offline ANTHONY
« Reply #9 on: July 11, 2018, 03:16:51 pm »
No cages!
Offline ANTHONY
« Reply #10 on: July 11, 2018, 03:19:55 pm »
I have checked every bolt possible, tore the whole damn thing apart. I thing Im gonna rip the fender off and ride it with out it on and see if that does anything different.
Offline lather
  • COG#: 10690
« Reply #11 on: July 11, 2018, 03:35:12 pm »
Have you checked your steering head bearings?
Offline BigK
  • COG#: 3642
« Reply #12 on: July 11, 2018, 11:48:15 pm »
if not steering head bearing check the engine mount bolts.
Kevin
Indy AAD
Offline ANTHONY
« Reply #13 on: August 01, 2018, 02:49:51 pm »
Got it figured out, it was an inner cage that came with my highway pegs! I bought the bike used so I had no idea that there was a mounting system inside the body work like there was and it was loose and rattling off my exhaust and front part of the motor. Now she is smooth as glass after I went through changing head bearings, wheel bearings, fork oil change and pulling faring's apart, putting foam tape everywhere. Bike does make a sound over bumps, rides like she is brand spanking new. FINALLY
« Reply #14 on: August 01, 2018, 05:33:21 pm »
Glad you got it figured out! :great:
