Author Topic: Rear Angel GT A Spec removal.......ideas?  (Read 3008 times)
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« on: November 16, 2017, 06:41:13 pm »
 :truce: :truce:
I have the rear tire half way off with the no mar changer.
However....Maybe i need some pushups or something, but I can not get it up over the bar/tool to remove it.
I've removed sport bike tires like this off 17 inch wheels with tire-irons but I can NOT get the no mar tire bar to grab the edge of the tire.
https://www.youtube.com/watch?v=id55qaFPNpI
In the above video, I am at 6:11 in the process.  But, I can NOT get that tool to grab the tire edge no matter how much I lift it. You see how much light you can see on that tire in that video when the camera moves at 6:16,  I don't have that kind of room.
I'm POOPED!
Any suggestions?  This is an A Spec tire, and I'm wondering if the carcas is that much more stiff that this may be a two person job :)
« Last Edit: December 03, 2017, 10:51:43 pm by JTX »
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
Re: Rear Amgel GT A Spec removal.......ideas?
« Reply #1 on: November 16, 2017, 06:49:36 pm »
DISREGARD !
I did not have the tip of the tool in far enough to grab the edge of the tire.
I Pushed it in just a little further and I grabbed the edge and got it done.
PHEW!
« Reply #2 on: November 16, 2017, 07:26:54 pm »
Yep, and always be sure the far side is in the valley of the rim.  Nothing works if it is not.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #3 on: November 16, 2017, 07:36:22 pm »
I was watching this as closely as I could. My mistake was keeping the notch of the tip in the edge of the rim.  There was no  way to lift the tire since it was already as far as it would go.
Then I realized after watching the video that the man in the video actually had the tip about half way up the black part. Then, it hooked the edge.
....I watched a GIRL do this in their other video and I said to myself....boy either I'm a big WIMP or I'm doing it wrong!.
I'm glad I Found out I'm not a wimp.....but instead I didnt have the tip in far enough!  ;D ;D ;D ;D ;D    ( I wont say any more about that..... )
Tomorrow, I install the new one and I will assume I wont have much trouble.  I DID however order two of thei XTRA HAND clamps.  I had the yellow thing on it, and I still needed to dig up a C-Clamp and squeeze the tire a bit in order to get the tire off the first part.  Once I clamped it a bit, it came up and over the edge of the rim.
First time I've removed a tire without the use of tire-irons, and a second person.  I'm very happy.
« Reply #4 on: November 16, 2017, 08:16:26 pm »
I don't know.  The hardest part for me was the last 6 inches of the second bead install.   I had to extend my bar and get where I could push with my back against a wall before it popped on.  I was worried the rubber would rip from the bead.
Offline lather
  • COG#: 10690
« Reply #5 on: November 17, 2017, 12:25:29 pm »
I have given up on using GT or A spec tires because they are too hard to mount. I have managed to do 3 or 4 but each time I was afraid something or someone would get hurt.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #6 on: November 17, 2017, 12:42:10 pm »
I noticed when I used the correct techniques the rear a spec came off without much effort on the nomar.
Replament comes today so ill follow up here. I have been using a harbor freight changer and irons for years.  Finally i can do it alone and no tire irons so far
Offline roy826
« Reply #7 on: November 17, 2017, 03:09:50 pm »
Two people worked best on my A spec tires. Even with a No Mar they were stiff to pry on. Having an extra heavy hand or two made it much easier.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #8 on: November 17, 2017, 07:21:18 pm »
I have the yellow thing, and two hand clamps.
Which ends up being THREE hands.
« Last Edit: November 17, 2017, 07:33:38 pm by JTX »
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #9 on: November 17, 2017, 10:58:29 pm »
I wont lie and say it was EASY.
But I got it. I think next time I'll have a better plan of attack and it wont take as long.  I started in the wrong section of the tire and had to release it and turn the tire once.
But I got it done without help and a single yellow-thing from nomar.
I found on the GT with this technique and no tire irons that lube is the key, even when you put the tire over the rim on the first side.
Offline Bigfoot_16
« Reply #10 on: November 18, 2017, 12:58:40 am »
Yep. Lots of lube gets tires on and off much easier.
Have you watched the video of a Goldwing tire change with the No-Mar? That thing is a beast and you have to use tire irons, too.
Jim
2015 Concours 14
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #11 on: November 18, 2017, 01:06:20 am »
Yeah. I Did.  Special rim clamps, too.
Those run-flat tires are stiff MoFos
Glad I dont have a goldwing.
Will see how it goes on the front tire next. But these A spec tires are pretty stiff puppies.  I was afraid to use TOO much lube,  so I probably didnt use as much as I should. I used a harbor freight changer and tire irons.  So this is new.
« Last Edit: November 18, 2017, 01:33:23 am by JTX »
Offline RodneyW
« Reply #12 on: November 18, 2017, 02:27:07 pm »
I did the A-specs with tire irons, but it was a bear.  I like the tires, but may go without the A-spec next tire change to avoid the process.  I used every trick in the book, but the sidewalls are just too stiff.  I wonder if I even need air...
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #13 on: November 18, 2017, 02:32:43 pm »
I didnt have an A spec front last time.  Didnt know there was for front.  So this time I'll be curious how they last and will keep other set for comparison when time to remove.
Offline roy826
« Reply #14 on: November 20, 2017, 03:04:37 pm »
I have that to but I am not heavy enough alone or strong enough to push or pry the last bit down. Big friends are a plus.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #15 on: November 20, 2017, 07:27:12 pm »
I hear ya. I had to jump on the tire to push it over the rim.  But I still think its because I Didnt use enough lube on the rim.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
Re: Rear Angel GT A Spec removal.......ideas?
« Reply #16 on: December 03, 2017, 10:27:33 pm »
So the front tire went on a couple days ago. Just now getting to a follow up post.
The front actually went on easier than the rear. A spec as well.  I think a lot had to do with better technique and the hand clamps and I put more of the lube on the tire edge.  A few stills.
No help, no tire irons.  Just the clamps and yellow thing.
off
on
It took longer to put all the bolts, calipers fender axle, torque, jump up and down on it, pinch clamps.
than it did to remove/mount the tire.
« Last Edit: December 03, 2017, 10:52:04 pm by JTX »
Offline RodneyW
« Reply #17 on: December 04, 2017, 12:21:43 am »
Nice write up!
Offline Throttle 8
  • COG#: 12220
« Reply #18 on: December 05, 2017, 03:33:31 am »
Yellow thing is the best tool I have ever bought for tire changes, followed closely by No Mar lube. (easy boys!) :D
2000 ZX12R Ninja
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #19 on: December 05, 2017, 10:02:25 am »
 :-X
It really works well. As well as using it on the right surface for install.
ETA
The funny part is, about the whole process of changing my tires by myself this time, I was under the false impression that applying FRONT brake pedal activated the rear caliper in linked braking on my C14.
I read in the book where it said when doing the rear tire to zip tie the front brake while removing the rear wheel.  I though, well how the hell do I get the caliper off if its squeezing the disc.
Well, it wasn't.  All this time I thought grabbing front brake lever was activating the rear brake too...
I know it says it does this in the book, so I guess it means when the bike is in MOTION, the front/rear activates.....   But I was always under impression it was regardless.... :-[
« Last Edit: December 05, 2017, 10:43:08 am by JTX »
Offline Tree
  • Too many deployments to count. SUBPAC & SUBLANT.
« Reply #20 on: December 05, 2017, 03:22:35 pm »
This lube advice is better late than never I would think.  I use liberal amounts of Goop on the rim and tire.  You can get a tub of it at Advanced Auto.  Don't be shy with it.  Just remember to wipe your hands and tools down before you start.
(Goop also works great at removing road grime from any windshield.  You know, that film that develops after months of driving.  Smear it on and let it sit for a spell then rinse it off after a brief scrub.)
Submarines Once! Submarines Twice! Holy jumping . . . <edit> !
A Sport Bike With Bags.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #21 on: December 05, 2017, 07:19:50 pm »
Yeah I've used a mild soap too that worked.
Whatever nomar is using in their cans of lube is pretty well done.  I'll likely keep buying it from them as It will likely last a while.
Offline Dragunslayer
  • " An APEX is a Terrible thing to Waste!!"
« Reply #22 on: December 13, 2017, 09:49:24 am »
LOL The Tire Lube from No-Mar can also double as a hand cleaner and the yellow thing as a weapon.
Kevin Reinhold
Robertsville, MO
15' Kawasaki Concour 14
16' Susuki GSX-S1000F
Offline Gitbox
« Reply #23 on: January 09, 2018, 03:42:43 pm »
JTX, that changer will work MUCH better if it's bolted to the concrete floor. You'll even find it takes less effort too.
2008 Yamaha FJR1300A
2004 Yamaha FJR1300 (sold)
2000 Concours ZG-1000 (sold)
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #24 on: January 09, 2018, 03:56:45 pm »
I was skeptical when i tried this idea but it worked perfect.  The only reason i had trouble was technique and not enough lube.... It moves only very slightly.
Though i will admit there would be a little more torque available if it was bolted.  For now I'm going to try it this way and if it becomes an issue i will bolt it.  Problem is my two stall garage is on the small side.  1960s era house.  If I hard mount it, It will be in the way for other tasks and I would have to un-bolt it and then cover up the studs.  It will be a hassle.  I won't put studs in the floor where vehicle tires will be.
« Last Edit: January 10, 2018, 11:34:17 am by JTX »
