Author Topic: rear swingarm torque check..  (Read 1001 times)
Offline tjhess74
  • COG#: 8406
« on: June 27, 2011, 02:26:53 pm »
im not near my manual and cant remember if there is an interval for checking the rear swingarm bolts, etc.  can someone confirm or deny and if so, list a quick n dirty procedure?  thanks in advance.
Tom Hess  North Charleston, South Carolina    COG #8406  IBA #30337  CDA #248 (C10)    97 c10 (former)  08 c14 (current), 2007 Honda VFR800 RWB
Offline C1xRider
  • I'm not monitoring this forum. PM me at zggtr.org
Re: rear swingarm torque check..
« Reply #1 on: June 28, 2011, 12:00:36 am »
Nothing in the periodic maintenance section specifically about the swing arm.  Didn't see anything while skimming the swing arm section either.  Pretty much everything involved with suspension is on a 1year/7,500 mile interval.  Looks mostly like basic common sense stuff, make sure the bolts are tight, no leaks, lube chassis parts, etc.
You don't have an electronic copy of the FSM for your bike?
2010 C14 ABS  :great:
2000 XT350
1998 C10
1983 V65 Magna
1978 SX250
Offline tjhess74
  • COG#: 8406
« Reply #2 on: July 02, 2011, 10:43:50 pm »
i do, i just didnt have access to it when i was searching for the answer!
