Author Topic: Rim bent  (Read 573 times)
Offline Ed
Rim bent
« on: December 23, 2018, 10:45:33 pm »
Anyone know if a zx1400 front rim will fit the zg1400 .
08 zg1400
12 Tuono V4
04 Tuono
09 sm610ie Husq
83 R100RT , 84 R100RS BMW
Re: Rim bent
« Reply #1 on: December 23, 2018, 10:54:46 pm »
generically yes... but year is significant...
difference in part numbers is due to colors of rim.
also, ABS ring differs at a certain point also, not specifically relating to rim/ring interface, but slot count in the actual sensor rings.
Offline gpd323
Re: Rim bent
« Reply #2 on: December 24, 2018, 02:31:17 pm »
My 2006 ZX14 rim is exactly like my 2013 C14. Even the spacers are same. All you need to do is swap over the ABS ring to the ZX14 rim and rotors if you need to and off you go.
I bought a pair of over-sized rotors from Brake-Tech for a ZX14 and slapped them on my C14.  My stock ZX14 rims are bronze color, my spare wheels are black like my C14.
Offline Ed
Re: Rim bent
« Reply #3 on: December 24, 2018, 09:20:59 pm »
That's good to hear . Hit a rock with my 08 and bent it on one side . Found a 2016 front rim for less than it would cost to fix the bent one . Its black but I don't care about color . So sounds like this rim will fit ? I don't have ABS, so would it matter if the bike it came off of had ABS ?
 Thanks for the replies .
« Last Edit: December 24, 2018, 09:36:05 pm by Ed »
08 zg1400
12 Tuono V4
04 Tuono
09 sm610ie Husq
Re: Rim bent
« Reply #4 on: December 24, 2018, 10:26:36 pm »
good to go, won't matter, all the rims are the same...
Offline BillyJ
Re: Rim bent
« Reply #5 on: December 26, 2018, 08:52:37 am »
I need a front wheel for my 2014 Concours.  Mine is leaking air at about five pounds a week.  Any suggestions.  Thanks, BillyJ  423 877 0505  Hixson Tn.
Offline Freddy
Re: Rim bent
« Reply #6 on: December 26, 2018, 10:54:31 am »
Pin-point the leak with soapy water.  A wheel consists of a rim, a tyre and a valve.  It's unlikely to be the rim.
Online robertv
  • Go Hawks!
Re: Rim bent
« Reply #7 on: December 26, 2018, 03:00:33 pm »
+1, check to see if there's leak. Also if you're in a cold climate area its normal to lose PSI for a bit but not weekly like you're experiencing.
What's the mileage on your front tire? I notice when I push the limits on certain tire brands air doesn't hold like when its new.
2008 C14, silver [current]
2000 C10, red [sold]
Offline gpd323
Re: Rim bent
« Reply #8 on: December 26, 2018, 08:09:10 pm »
The valve stems schrader valves can leak. Check to see thats it tight in the valve stem. I have a small tool that I use to loosen and re-tighten.
The soap suggestion is a good one.
Re: Rim bent
« Reply #9 on: December 26, 2018, 11:03:09 pm »
that ^^^^^^
I don't think I've ever had a bike tire rim leak, ever...
but I've seen many a bad schrader valve... I change them every tire change, they are cheap... Like $4 a dozen or so...
I also goober a bit of "spit" on my fingertip, and swipe it across the end of the valve stem, whenever I top a tire up with air... if a valve is leaking you will see it quite easily. You'll get a goober bubble... :rotflmao:
Offline Diz
  • COG#: 12056
Re: Rim bent
« Reply #10 on: December 27, 2018, 08:32:15 am »
Were you riding where roofers were working? Small nails will sometimes stay in the rubber and the tire will lose air at the rate you describe
Offline gpd323
Re: Rim bent
« Reply #11 on: December 27, 2018, 05:42:29 pm »
One time my tire was losing air slowly like you describe, I looked the tire over and over until my finger got cut on a piece of staple (the home size) and when I pulled it out bingo. Visually it was near impossible to see.
Offline Just Cliff
  • COG#: 9547
Re: Rim bent
« Reply #12 on: December 28, 2018, 11:24:18 pm »
I always use a scotch brite pad to clean the inside of the rims well, were the bead seats. Any little debri or corrosion will keep the bead from seating well. Just another reason to mount your own tires.
A shop sure want take the time!
Cliff
2014 1000 V Strom
Re: Rim bent
« Reply #13 on: December 29, 2018, 08:31:33 pm »
I agree with the others and doubt you have a leaking wheel. The first PR-2 rear I had put on seemed to loose air all the time. 2-3 pounds over night. The TPS worked and I never aired tires so often in my life. Soapy water would not show any leaks on that tire, wheel or valve stem. And I squirted the heck out of it with that soapy water.
 I have not had a leaky tire since that PR2 which had no apparent reason. Every tire I have had installed since that first PR2 have all held air without loosing any over night. Maybe after a week I might have to add air. Good luck, Tim
