Author Topic: Front Forks Service  (Read 1073 times)
Offline mike
Front Forks Service
« on: June 18, 2019, 12:16:48 am »
Last month my riding group held an event where a guy who runs a motorcycle suspension shop performed a suspension clinic.  Once he completed the work on my 2014 with 34K miles, he stated the front forks needed servicing as they were reaching the limit of what the adjustments could do.  He suggested just the oil be serviced - for  $280.  First, is this a typical maintenance item I should expect, second is this a warranty item, and third is the price in the right ballpark?  BTW: Handling was much improved following the clinic.
Offline Syxxphive
  • COG#: 12672
Re: Front Forks Service
« Reply #1 on: June 18, 2019, 01:48:27 am »
Even though Kaw doesn’t spec a replacement interval for fork oil, I highly recommend a minimum interval of 20k miles for commuting, or 15k miles if you’re a hard rider. Price is about right to just change the oil. It’s fairly simply to just change the oil. Couple hours and a couple special tools is all it takes. If you’re a paying member, Old Man On a Connie owns a traveling set of tools for paid members. Send him a message to see where they’re at right now lol.
Offline lather
  • COG#: 10690
« Reply #2 on: June 18, 2019, 11:53:44 am »
I had my fork seals replaced ealier this year by an independant mechanic for 175, including oil and seals.
« Reply #3 on: June 19, 2019, 02:01:54 pm »
I would not do oil only.  I did oil only at 45k and then they leaked at 55k.  I had to have seals and oil done on the road in Portland.  I think it was $550 but not sure.
When I did the oil myself I bought the tools and figured it out but would have been simple to do the seals too while in there.(Kick Self Again)  I would have then but I did not know how bad it was to have inverted shocks leak.   It will get on your brakes fast.   I am use to being able to wipe off oil for a year till I get around to it.
Offline mike
« Reply #4 on: June 19, 2019, 05:43:32 pm »
Thanks for all the great feedback. I'm going to plan for oil & seals.
« Reply #5 on: June 19, 2019, 09:43:22 pm »
personally I would just change oil.  34K, with no incidence of leakage (and frankly they shouldn't be leaking) does not warrant seals. That requires complete dis-assembly, and rebuild... at that mile point.. I have a hard time swallowing that service..
but...
if you are going full Monty, and insisting on doing the seals.... PLEASE buy the OEM seals, do not buy e-bay marketplace seals.. buy the OEM's.
I have no shoe in this, but every time I read about failed seal installs, both for C10, and C14... they went with E-Bay vendors, or non OEM.
It's your time, and money... the time, and tools.. well, decide based on your experience and expertise in doing it.
best of luck, ride safe.
