Author Topic: Shinko 016 Verge 2x impressions.  (Read 4547 times)
Offline RoadKillHeaven
  • How hard can it be? 。◕‿◕。
Re: Shinko 016 Verge 2x impressions.
« Reply #25 on: August 27, 2018, 11:03:04 am »
400 more miles and I hit 8K.!
« Reply #26 on: August 27, 2018, 01:01:41 pm »
"8K Miles"!!!
That's amazing!
I don't get near that, even with a PR-4..
I spooned another Shinko rear on recently.
  {Had a flat on the last one and decided to replace it.}
Will see how this one does.
« Last Edit: August 27, 2018, 06:19:16 pm by connie_rider »
Offline Undertaker
« Reply #27 on: August 27, 2018, 02:32:49 pm »
I can't say one bad thing about Shinko tires.
 :)Great savings in money over others brands, and they stick in the turns and give me good mileage.
"I ride up front, all others ride in the back!" Undertaker
« Reply #28 on: September 05, 2018, 11:02:18 pm »
Crossed the 8K mark. I've noticed left side of rear tire is more worn than right side. I attribute that to road crown.
There still 1/32 left. I'll wait until "normal" Seattle weather resumes before I put new rubber on.
I am impressed by these cheap-O-tires many dismiss as a bad juju.
Cheers...
« Reply #29 on: September 28, 2018, 05:02:34 am »
@ about 8200 miles rear tire, all of the sudden, has shown cords. I'd gone for a ride, came back home, checked tires and saw it. :o
New tires are on.   :great: :motonoises:
Cheers...
« Reply #30 on: September 28, 2018, 01:46:32 pm »
"8K Miles"!!!
That's amazing!
I don't get anywhere near that, even with a PR-4..
Update; I rode 300 miles of twisties in Arkansas last weekend.
After I got home, I was amazed by the amount of wear I had on the new rear tire.
As I sed in an earlier post I'm very doubtful if I'll get 2500 out of these, (Particularly if I keep doing Arkansas twisties with Cliff)  :great: but I have to admit,,, they stuck like glue...
« Reply #31 on: September 28, 2018, 02:25:13 pm »
It seems pavement is not as abrasive here in Pacific NW as it is down south.
Offline SATXRIDER
  • COG#: 12274
« Reply #32 on: September 28, 2018, 06:47:02 pm »
I think I am going to give the Shinko rear tire a try.  Low expectation, but should get me thru the winter riding season hopefully and I get get a better tire in the Spring.
Steve
2013 C-14
2006 ZX-14
1982 GS1100
Offline Just Cliff
  • COG#: 9547
« Reply #33 on: September 28, 2018, 11:19:06 pm »
Don't blame me. You just keep coming up here to see my smiling face!   :nananana:
Cliff
2014 1000 V Strom
« Reply #34 on: September 29, 2018, 03:09:52 am »
It seems like I got a defective rear tire. At about 35-40 mph handbars shimmy. At higher speeds rear end bobbing. When on center stand, gear engaged, with engine running, I can see a low spot on the left side of rear tire. It is as if bias ply tires develop flat spot after sitting a while.
Bummer...
Online CRocker
  • '02 C10 CDA # 416
« Reply #35 on: September 29, 2018, 11:59:27 am »
Verge 2x is a radial...
What tire are you referring to...?
« Reply #36 on: September 29, 2018, 12:07:33 pm »
Yes, I agree. Mine is a radial.
 Maybe that explains the difference in mileage that we're seeing?
PAS: Cliff I don't blame you, and it sure ain't the smiling face..
         Arkansas roads are sorta like an addiction.
            Gotta have "MORE"...   :motonoises:
Offline Douglas
  • COG#: 8649
« Reply #37 on: October 01, 2018, 01:03:41 am »
Here's me dragging a knee with Shinkos
YouTube video: https://youtu.be/98bWb6ciZT4
ASE Certified mechanic.
Offline Douglas
  • COG#: 8649
« Reply #38 on: October 02, 2018, 02:57:53 pm »
Is it stepping into turns too easy it's probably because the front forks are too soft low or sag adjustment is inadequate. tires have little to do with the way of bike dips into turns unless the profile the tire changed the height of the bike.
Offline PeteTN_zgtr
« Reply #39 on: October 07, 2018, 01:17:06 am »
Douglas, more than once a change of front tires significantly changed how my bike dips into the corners.  I don't believe the tire heights varied that much. Maybe but they were all 120/70's.  I think it's more tire shape and construction.  Hek Angel GT's (non A-spec) with 2k miles had much different dip-in than when they were new.
« Reply #40 on: November 14, 2018, 03:01:04 pm »
All, (after looking at RoadKillHeaven's photo's), I looked at my rear Shinko again and the wear was not as bad as I thought.
  ie; It has a bit of a flat center, and my rear tire looks worse at 2000 miles than RoadKillHeaven's look at 4000 miles.
            But the deeper/larger grooves appear ok.
Unfortunately,,, it has a flat from a puncture.   :-[
{Plugged twice at the National due to a flat; with poor result}
I will admit I was pretty impressed by the way the bike handled with the Shinko's.
  So, I just ordered another rear Shinko to use as I finish the front Shinko.
Will see what mileage it gives me this time...
Update on mileage; Since the installation of the new Shinko on the rear I made 2 trips to Arkansas.
                                  I kept the used Shinko on the front to finish it out.
                             The new rear is pretty badly worn after 733 miles of Arkansas riding and the front is also worn badly. No flat spots. Worn uniformly...
                                 (I think the front has less than 3000 miles on it).
                              Neither has cord showing, but their too far gone to try another trip/long ride.
                             NOTE: I trailered the bike to Ark so there are no road miles...  All the miles on the rear were done while playing.
                              On the plus side; They handled/stuck really well...  :great:
NOTE: I've been doing some local rides as it's not actually showing tread yet.. <grin>
          Now at 1153 miles on the tire and still handling well..
« Last Edit: December 07, 2018, 08:19:41 pm by connie_rider »
Offline BiggusDekkus
  • COG#: 11944
« Reply #41 on: December 07, 2018, 07:38:05 pm »
Hi RoadKill;
Saw that you are also using Andrew for mounting your tires.  He does a great job at a reasonable price, about half of what most shops would charge.
I have about 9,500 miles on my current set of Pirelli Angel GT A-spec tires.  They still have some mileage left in them, but I ordered another set of Pirelli's yesterday and will have Andrew install them sometime during the next couple months.  Best tires ever!
2016 Gray C14
Jet Ski Ultra 300X & ST-15F
Lake Stevens, WA
Offline Douglas
  • COG#: 8649
« Reply #42 on: December 17, 2018, 03:22:50 am »
If you like that you should try a 110 front next time. It'll amaze you. Save the 120 for the track
Offline Big Brian
« Reply #43 on: January 05, 2019, 01:56:30 pm »
I just picked up my 08 last weekend.
The dealer put on brand new Shinko Verge tires on front and back.
Since then, ive put on about 350mi. About 100 of those was riding on hard twisty corners normally reserved for my Ducati.
I am very pleased with their performance with gripping the road.
I cannot comment on longevity at this point until I put on more miles.
My Pirelli's on my Ducati seem to struggle to get to 5K so if these make it to 8K I will be pleased.
1975 Honda Goldwing GL1000
1996 Honda Shadow ACE 1100
2001 Suzuki SV650N
2008 Kawasaki Concours ABS
2013 Ducati Monster 796 Anniversary Edition #35/200
Online CRocker
  • '02 C10 CDA # 416
« Reply #44 on: January 05, 2019, 05:47:14 pm »
Verge?  Or Verge 2X?  Shinko makes both...
Offline Big Brian
« Reply #45 on: January 20, 2019, 01:48:03 pm »
The Verge not the Verge 2x
2001 Suzuki SV650N
Offline Tundra
  • 2012 Candy Arabian Red
  • "SPORT" tourer
  • COG#: 12916
« Reply #46 on: March 21, 2019, 09:23:59 am »
As if you all don't already know...here's some reviews that seem to be in line with yours. These will be my next tire and for this price I don't care if I don't like them. I can't find anyone that has used them say anything negative about them...yet
https://www.motosport.com/shinko-016-verge-2x-tire-combo
« Reply #47 on: March 22, 2019, 04:00:42 am »
I will refrain form saying negative things about F016 Shinko. After all, it is/was my subjective experience with these tires. Second set did not fair well as I had to claim warranty twice. Each time front tire under-performed, exhibiting the same shimmy.
Since then I've replaced front tire (I know mix-n-match is not the best solution) with BT016 and my shimmy issue is completely gone!
I do not think I will ever go back to Shinko tires.
« Last Edit: March 22, 2019, 04:09:35 am by RoadKillHeaven »
Offline MtnRider
  • COG#: 12840
« Reply #48 on: March 28, 2019, 03:12:27 pm »
I just ordered a set as the front tire is all but bald & the rear is close behind. With a 55 series rear they were $212 shipped to CO from Amazon. That was the best price I could find.
2015 Black C14
