Author Topic: front fork seals  (Read 610 times)
Offline DUMB A$$
front fork seals
« on: June 20, 2020, 10:00:42 pm »
I dont think I have 2 oil changes sence replacing front fork seals and one is leaking again. WTF.
Offline Freddy
  • West Aus
Re: front fork seals
« Reply #1 on: June 21, 2020, 12:09:34 am »
Who did the work and what parts were used - oem or...?
Offline DUMB A$$
« Reply #2 on: June 21, 2020, 03:24:38 pm »
I did the work and parts came from partzilla. If those are not factory parts then that's where I failed.
Offline DUMB A$$
« Reply #3 on: June 21, 2020, 03:27:30 pm »
1702 miles on the new seals installed December 2018.
Offline Rexter
« Reply #4 on: June 21, 2020, 04:11:47 pm »
There it is........dry rot. 😄
Have you checked for anything that may have gotten under the seal?
Did you check for burrs or nicks on the fork tube when you did the job?
Offline lather
  • COG#: 10690
« Reply #5 on: June 21, 2020, 04:52:38 pm »
Just spent 270 on the 2nd set in a year. The first was was done for 100 by the guy that rents track bikes at my local track. This last job was done by an independent  shop whose owner I have known for 30 years and has always done good for me. The left fork was a quarter inch longer than the right after the cheap job and I asked them to fix that. They found the cause was a stripped thread on the damper rod. I am now running Skock Soxs.
https://www.amazon.com/Shock-Sox-37-50mm-Fork-Black/dp/B0041CC4N4
Offline TireguyfromMA
  • COG#: 12669
« Reply #6 on: June 22, 2020, 01:33:37 am »
You may just have some dried up bug guts, or dirt, that got stuck on the lip of the seal. I have these seal doctors from Risk Racing.  They work great at cleaning dirt out of the oil and dust seals on the forks.  The smaller 35-45mm fits tight to the C14 fork tube, the larger one 45-55 is loose, you have to squeeze it a bit to make it get under the seal...get the smaller one.
https://riskracing.com/pages/seal-doctor
2002 Honda ST1100
Offline Nickrides
  • Nickrides
  • Nickrides
« Reply #7 on: June 22, 2020, 02:56:32 pm »
A guy brings his snowmachine into the shop in Northern Canada for some work.
The Mechanic looks at it and says " I think you blew a seal"
The guys reply's, No, that's just a little frost on my mustache.
Sorry had too.
Offline ursharkfuel
  • God got one thing wrong: Stupid should be PAINFUL!
  • COG#: 13146
« Reply #8 on: June 22, 2020, 06:56:25 pm »
Sorry had too.
That one never get old!  :rotflmao:
Enjoy the ride,
Jon
2011 Connie 14, 2008 KLR 650, 87 Kawasaki Ninja 1000, 82 Kawasaki GPZ 750, 87 Honda Hurricane 1000, 84 Yamaha FJ 1100, 76 Honda CB 750K, 73 Kawasaki KZ 900 Z1 based drag bike (not street legal), 82 Honda Aspencade 1100, 1 new and 2 used Harley mistakes, 76 Triumph Bonneville 750
Offline DUMB A$$
« Reply #9 on: June 26, 2020, 05:12:46 pm »
I now remember seeing the seal cleaner when I was researching the seal replacement and I will give it a go this weekend.
Offline DUMB A$$
« Reply #11 on: June 27, 2020, 08:19:55 pm »
Did the cleaning trick today, drove to store and back. Now I wait and see.
Will drive longer when temps get out of 100.
DUMBA$$
Offline gpd323
Offline DUMB A$$
« Reply #13 on: July 18, 2020, 02:18:42 pm »
So far so good. I dont have a wet spot under my fork anymore.I am moving from Ca. to ID. this friday and will eventually have to ride it there and that will be the true test.
DUMBA$$
Offline ursharkfuel
  • COG#: 13146
« Reply #14 on: July 18, 2020, 09:36:25 pm »
Sorry had too.
 :D :rotflmao: ;D That one never gets old!  ;D :rotflmao: :D
Jon
  • COG#: 12669
« Reply #15 on: July 19, 2020, 12:16:24 am »
Curious...Did you use the Sealmate cleaners from Motion Pro or the Seal Doctor from Risk Racing?
2002 Honda ST1100
Offline DUMB A$$
« Reply #16 on: July 19, 2020, 05:35:19 pm »
DIY my own from a clear plastic strawberry container and just copied the hook design from seal master.
