Author Topic: Stuck left fork rebound adjuster  (Read 435 times)
Offline Doc
  • COG#: 12697
« on: April 23, 2018, 05:08:50 pm »
Guys, my left adjuser knob is stuck and won’t turn - thoughts?
Re: Stuck left fork rebound adjuster
« Reply #1 on: April 23, 2018, 10:28:45 pm »
Mark the position of the adjuster nut below, crank that adjuster back and forth a couple rotations, and then retry the knob...
Even during the nut rotations, they tend to stick, so adjusting the hex back and forth helps..
Don't force the plastic knob, using pliers.. it WILL break, and there are no replacements... just saying....
Go easy on it, and work the hex prior..
Offline Doc
  • COG#: 12697
« Reply #2 on: April 23, 2018, 11:07:04 pm »
Thanks that worked!
« Reply #3 on: April 23, 2018, 11:09:59 pm »
 :great: :beerchug: :great: :great:
Thanks that worked!
Offline AmphibSailor
  • Hooligan
  • COG#: 12210
« Reply #4 on: April 24, 2018, 02:51:35 am »
While not an oem replacement, Traxxion<--Click makes a super good looking machined replacement.  I picked them up when they first became available.
Offline Doc
  • COG#: 12697
« Reply #5 on: April 24, 2018, 09:06:50 am »
Yep - I got those when I did my Traxxion Axxion valve upgrade - much better than stock.
