Author Topic: Tire storage  (Read 683 times)
Offline strum
  • COG#: 12307
Tire storage
« on: December 01, 2018, 04:22:47 pm »
 A friend come by yesterday and we were in my shop  when he noticed my new set of Pilot 4 Gts sitting on a bench he says "dont store them laying flat stacked"
 I dont expect them to be there much longer but this is the first time i have ever heard such a statement. personally I dont think it matters . Just curios what you guys think
2008 C-14
Offline works4me
  • COG#: 10594
Re: Tire storage
« Reply #1 on: December 01, 2018, 05:00:41 pm »
I think some people worry too much.
Keep them away from chemicals ( solvents )
and sources of ozone. ( electric motors )
and you’ll be fine at least for a couple of years.
Offline CRocker
  • '02 C10 CDA # 416
Re: Tire storage
« Reply #2 on: December 01, 2018, 07:00:37 pm »
Oh...you mean the tires...yeah...either way...
Re: Tire storage
« Reply #3 on: December 01, 2018, 09:40:30 pm »
 :)) :rotflmao:
I guess if I had to "create a reason" for not doing that, It would only be based on having the same airflow around the 99% of the tire carcass when its sitting vertical.. vs having the sidewall on one side in contact with some surface, which makes the tire a "big bowl"...
Just kidding, I store tires in a double trash bag, sealed, and hanging form the wall on a peg... but I'm sure that's wrong also, as gravity will make them Egg shaped...
but at least they don't end up as "Mouse Hotels"...
I just sent 4 tires back to a place, and as i had to attache a return authorization note to them, I ended up using a roll of Syran Wrap, to wrap the tire holding the paperwork on the treaads... that worked good, maybe take it a step further and do the whole tire, like a shrink wrap rolled on...
« Last Edit: December 01, 2018, 09:44:41 pm by MAN OF BLUES »
Offline RWulf
  • COG#: 7122
Re: Tire storage
« Reply #4 on: December 02, 2018, 04:39:13 pm »
He must be thinking that the weight of tires laying on top of each other will
cause the beads to compress. That makes it harder to seat the beads on the rim.
Tires I have gotten lately have a peace of cardboard inside holding the beads apart.
Leads me to think they are stacked laying on each other at some warehouse.
Re: Tire storage
« Reply #5 on: December 02, 2018, 09:00:34 pm »
its more about consistent clean dry air flow, inside and out. ;) ;)
Offline strum
  • COG#: 12307
Re: Tire storage
« Reply #6 on: December 03, 2018, 12:48:47 pm »
Im thinking unless we are talking months or even years its a non issue.
2008 C-14
Offline JDSCO
  • 2016 C14
Re: Tire storage
« Reply #7 on: December 03, 2018, 08:37:21 pm »
I think you're right!
Gen James Mattis
