Author Topic: TPMS warranty...  (Read 817 times)
Offline olie
TPMS warranty...
« on: July 11, 2019, 08:09:29 pm »
...my current TPMS valves are 4 1/2 yo... and the bike will be 6 yo  in less than 4 weeks and the extended warranty will be over.
So far they working ok, although taking a little longer to display the pressures. Dealer says that probably the second warranty extension may not cover those pressure transmitters.
What is the life expectancy of these sealed pressure transmitter batteries???
2013 C14, blue
2016 V1K, green
Re: TPMS warranty...
« Reply #1 on: July 11, 2019, 08:20:11 pm »
If it's the Kaw warranty, it should be covered.  You just need them to fail before it runs out.
2013 Kawasaki Concours 14
« Reply #2 on: July 11, 2019, 09:53:01 pm »
The sensors are covered fully whenever a current KPP is in effect, and until it expires.
If you have only purchased the first of 2 possible KPP extensions, go to that link I provided, and "re-up" again, before the first extension expires.... the new extension will "roll in" at the expiration date of the first one, and continue for another 3 years.. then you are done with the extensions..
if the "dealer" said "it may not be covered".. he was wrong, as it will be honored.. I had mine done on my extensions...
so; don't wait, get the renewal. It will pay for itself, for sure...
Offline 4Bikes
« Reply #3 on: July 11, 2019, 11:50:08 pm »
I had the front TPMS go bad and not a dead battery which I would have replaced to keep the old style.  Kawasaki covered it with no questions asked at 8 years and 2/3 through my second extension. So yes it’s covered.
Offline olie
« Reply #4 on: July 12, 2019, 03:41:29 pm »
...just sent the information to UltimateCycle for the 2nd extension... first extension still good to 8/8/19.
let's see what the dealer says after I get the second extension... meanwhile TPMS is running fine although with a slightly lower initial response, so I cannot complain.
2013 C14, blue
2016 V1K, green
« Reply #5 on: July 12, 2019, 05:58:36 pm »
 :great: :great: :great: :great:
WISE MOVE....
 :) ;) :motonoises:
Offline patatty
« Reply #6 on: July 08, 2020, 12:45:03 am »
Mine wet in today for replacement.  My second extension expired June 18th, but I set up the appointment prior to that, so they are covered.
