Author Topic: Traxxion and a Penske  (Read 1806 times)
Offline rrsperry
  • Senior Moment Member
  • COG#: 12503
« on: January 10, 2018, 02:33:17 am »
Ok, so I ordered a Penske from Dan at 5he end of November.  It showed up before Christmas. But no bracket to mount the remote res. No problem, Mike gets it out ASAP. I got it yesterday. So the shock is mounted, no problem. Take a look at the bracket and WTF?
Ok, I get you have to use just one hole, but they provide a bolt that doesn’t fit. They send a M10-1.5 x40 bolt. Trouble is the stock bolt and its subsequent hole is fine thread or M10-1.25...
So what are you supposed to do? Drill out the existing hole and thus make returning to stock impossible?
Ok, here’s my plan. I ordered a M10-1.25x40 cap bolt from McMaster Carr, and a slim self locking nut. (Actually 10 ea) I’ll be able to use it and not have to drill anything out.
So my question is why not just sent a correct bolt? Yes, I’ll be calling them and asking. I’ll probably just send the the other 9 bolts I don’t need...lol
Re: Traxxion and a Penske
« Reply #1 on: January 10, 2018, 11:10:31 am »
check with them and see if they sent the correct bracket. When I got mine, the bracket didn't work with my '12 model. The bracket was built for earlier models. I contacted traxxion, and after they came to the realization that I was correct, they built another "proper " bracket. Well, it's my understanding that they did, they never sent me one, and I modded my bracket to fit on my own. Good luck, Steve
Offline rrsperry
  • COG#: 12503
« Reply #2 on: January 10, 2018, 11:28:39 am »
Oh, the bracket will will work jus fine. It's the way they tell you to attach it and the hardware they sent. I mean, it may be possible that they sent the wrong bolt, but, I've never really seen a place that stores new nuts on the bolts as a pair. They picked a M10-1.5 nut and bolt to send.
It's possible that eariler bikes (<2016) actually used a M10-1.5 there, and they are unaware.
Anyway, me being the dumb mechanical engineer that I am, I'll be designing a new bracket, and have my nephew, a genius fabracator make a few up. (I just don't like the idea that the thing is held by only one bolt, and the fact that you have to ruin the original bolt hole)
It's also temping to eventually use a Ti bolts there...lol (every little gram counts...), Maybe even make the bracket out of Ti. :))
Offline Syxxphive
  • COG#: 12672
« Reply #3 on: January 13, 2018, 02:11:50 pm »
Can’t drill out an M10 thread to make a different M10 thread. The major diameter of the bolts ate the same. Hence the M10
Offline rrsperry
  • COG#: 12503
« Reply #4 on: January 13, 2018, 02:29:55 pm »
What's your point? That's why I said you'd have to ruin the bolt hole in the frame.. As in drill out the M10-1.25 theads and use a M10-1.5 bolt and NUT...
Offline SW ROADRUNNER
« Reply #5 on: January 14, 2018, 01:17:07 am »
rrsperry
If you design and make a few I would be very interested in buying one if you would be interested in selling.
Offline rrsperry
  • COG#: 12503
« Reply #6 on: January 14, 2018, 11:51:49 am »
Not sure that's allowed? Anyway, it shouldn't be much, it's a laser cut bracket with a 30 deg bend, using a press break. I'll let you know.  It's too bad the factory tab in in such an awkward place..lol I'd be much happier if it were captured by the frame and footpeg, rather than hanging in back.
Offline JDSCO
  • 2016 C14
« Reply #7 on: January 14, 2018, 06:06:16 pm »
You CAN if you install a threaded insert kit by Helicoil and many other suppliers.
« Last Edit: January 14, 2018, 07:35:40 pm by JDSCO »
Gen James Mattis
Offline JDSCO
  • 2016 C14
« Reply #8 on: January 14, 2018, 06:17:14 pm »
Your "Subject" say Traxxion...
I'm going Traxxion/Penske real soon!
Do you have the Traxxion AK20 fork cartridges or just their spring setup?
Any input?
Gen James Mattis
Offline rrsperry
  • COG#: 12503
« Reply #9 on: January 14, 2018, 06:25:15 pm »
Yes I have the AK20 waiting to go in.
Yes you can do many things, but you shouldn’t have too.. I mean you are ordering a bolt on kit, it should work without having to drill new holes, or use thread inserts. It just required the correct bolt and nut.
Offline JDSCO
  • 2016 C14
« Reply #10 on: January 14, 2018, 07:43:16 pm »
M10x1.25 and M10x1.5 are confused frequently by the those inexperienced with metric hardware.
Gen James Mattis
Offline Syxxphive
  • COG#: 12672
« Reply #11 on: January 15, 2018, 08:10:53 pm »
Missed using the nut on there. My guess is they just put the wrong bolt in the package. If it were me, I’d do what you did. Just go buy a bolt the right size and call it a day.
Offline rrsperry
  • COG#: 12503
« Reply #12 on: January 27, 2018, 12:57:54 pm »
I did, and you have to use a nut.
Offline JDSCO
  • 2016 C14
« Reply #13 on: February 21, 2018, 08:35:22 pm »
Spring is 26 days away
Gen James Mattis
Offline Gixerhp
  • The Lighting Guy!
  • COG#: 12189
« Reply #14 on: March 10, 2018, 11:31:40 am »
Who is installing the Ak's for you.
Offline JDSCO
  • 2016 C14
« Reply #15 on: March 13, 2018, 10:49:29 pm »
Today was the first 150 mile trip with the Ak20/Penske suspension and the SISF MR Flash
WOW! That is a lot to absorb. Very Impressive!
Traxxion shipped the same, incorrect m10x1.5 bolt and nut for the reservoir mount bracket
Excellent Customer Service from Kathy and Dan, I have to say!
Fortunately, I am not a fan of that supplied "bracket" and didn't use it
I decided to affix the reservoir body behind the passenger foot peg
Easy access to the compression knob
It's a clean setup
Gen James Mattis
Offline Gixerhp
  • The Lighting Guy!
  • COG#: 12189
« Reply #16 on: March 14, 2018, 12:48:50 am »
It's a clean setup
Very Nice,,
I just order my set up the other week, and ill have it Thurs and Monday.
Does any one have a pic of the bracket mounted up!
Offline Douglas
  • COG#: 8649
« Reply #17 on: August 06, 2018, 02:47:39 am »
Can't believe all the years gone by. Dan set up my 'back then' racebike back in 2010 or so. Didn't know anybody stayed at a job that long anymore....
ASE Certified mechanic.
