Author Topic: WHAT TIRE PRESSURE WHEN TRIES ARE HOT?  (Read 222 times)
Offline WFL
  • Still kicking, HARD, TOO!
  • COG#: 13006
« on: July 31, 2020, 01:28:32 am »
The other day i headed out for a ride and after i left the house I saw my tire pressures were 36 ft and 38 rear. By the time i made it to a gas station to pump them up i was at 39 ft and 40 rear. So i over filled them and figured i let some air out once they warmed up fully. Then got thinking I don't know or didn't remember what the hot tire pressure would be on a 85* day after the tires have warmed up. :??:  Anyone know off hand what the warmed up temps would be at say, on a 75, 80, 85, 90 or 95 degree day? Thanks :) :beerchug: :beerchug:
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." ~ Thomas Paine
Offline Pittsburgh_Clem
  • COG#: 11340
Re: WHAT TIRE PRESSURE WHEN TRIES ARE HOT?
« Reply #1 on: July 31, 2020, 01:38:56 am »
42 psi when cold
Twenty years from now you will be more disappointed by the things that you didn’t do than by the ones you did do. So throw off the bowlines. Catch the trade winds in your sails. Explore. Dream. Discover – Mark Twain.
Offline Boomer
  • Wickford, UK
    • Boomers GTR Site
« Reply #2 on: July 31, 2020, 09:47:08 am »
I set 42 psi at cold. Throughout the year that "cold" varies from 5C (41F) to 30C (86F).
Out on a ride, once I get the tyres fully "warmed up" that rises to 44 or 45 psi on the dash.
So, if I were you I'd top up fully warmed tyres to 45psi, and then ride it for a mile or 2 and see what the dash shows.
If it's close to 45 psi yer good.  :great:
If it's well over 45 psi then let some out.
George "Boomer" Garratt
Wickford, UK
CDA-007
« Reply #3 on: July 31, 2020, 12:50:23 pm »
I seldom add air when the tires re hot.
   Normally add air before a ride.
 That said; In Houston, Cold is normally about 90-100*.
I set mine at 40 PSIG cold.
    Riding, the temp goes up to about 42.
Offline Red Fox
  • COG#: 11691
« Reply #4 on: August 01, 2020, 02:30:32 am »
Rule of thumb is that hot tires measure 3 psi above normal cold tire pressure.
Offline Phil
« Reply #5 on: August 01, 2020, 03:39:43 pm »
If I have to ride somewhere to get air, I check the tires cold, and see how many pounds I need. I then ride to where I am getting air, and put the required air in. If the tire is at 39 psi cold, I add 3 pounds once I get to the station. So, if it reads 40 psi at the station, I fill it to 43 psi. It works well. It is generally spot on 42 psi the next morning after it has sat overnight.
I rarely have to do that though since I have multiple means with which to add air in the garage. I have done it on trips though, when I don't want to use the mini compressor.
