Author Topic: What were they thinking (part 2, front axel bolt)  (Read 8962 times)
Offline jwh20
Re: What were they thinking (part 2, front axel bolt)
« Reply #50 on: March 25, 2017, 01:19:35 am »
What year they off of?
The ones I replaced previously were off a '09 and did not have any flaking evidence and there was a deep groove worn into each one probably over .040 deep on each one. They were also quite heavy. This was last year when I replaced them.
2009 with 26,000 miles.  I suppose it's possible that there is more than one type used.
2012 Concours 14 Arabian Red
Offline roy826
« Reply #51 on: June 23, 2017, 05:45:47 pm »
Motion Pro  ;D
Offline cappyg
« Reply #52 on: June 28, 2017, 11:19:38 am »
400 series stainless steel is non-magnetic.  WE use it at work for that purpose.  Most softer steels and aluminum used for rubbing seal journals are typically hard coated (aluminum anodized) or ceramic spray coated and ground to size.  I would suspect if the spacers are aluminum or dead soft they were treated with a hard coating of some sort.
Greg in Cincinnati
GTR1400 08' "Holy Kaw" Shoodaben EVO Flashed
T500 75' Suzuki Titan
XR400 98' Honda "Tractor"
Offline Bruiser
  • Bruiser
  • COG#: 10410
« Reply #53 on: August 14, 2017, 08:12:49 pm »
Yep, the size is a dilemma fer sure. I got the hex tool offered on ebay a few years ago, and use it on the left as you are looking at the bike, loosen those clamp bolts, and keep the double clamp bolts tight on the right. works every time.
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline OKC14
  • COG Facebook Babysitter
  • Ride it like you stole it
  • COG#: 12819
« Reply #54 on: August 16, 2017, 07:31:56 pm »
Spark plug socket for the win. $5
Offline JDSCO
  • 2016 C14
« Reply #55 on: August 16, 2017, 08:14:01 pm »
It's called a coupling nut
5/8-11 coupling nut specifically
available in steel or stainless 18-8
5/8-11 internal thread and 7/8 hex x 2" length
7/8=.875
22mm=.866
works great, fits the axle nicely and it's very affordable
Under $3.00 US at Ace Hardware or True Value or your participating hardware store
buy an extra for your friends
I installed mine in a 1/2" drive 22mm socket as shown
« Last Edit: August 16, 2017, 08:19:56 pm by JDSCO »
Gen James Mattis
Online MAN OF BLUES
« Reply #56 on: August 16, 2017, 08:22:21 pm »
7/8=.875
22mm=.866
works great and it's very affordable
 :beerchug: :beerchug: :great: :great: :great:
WINNER, WINNER, ..CHICKEN DINNER......SWEET.
dummy me.. and after all the years I told people how the make the "custom" wrench out of nuts, washers, and all thread rod, for removing the guts inside the C10 forks... never even entered my mind... DOHHHH.
Somebody make this a STCKY in the tool section please....
« Reply #57 on: August 16, 2017, 09:16:25 pm »
7/8=.875
22mm=.866
Now why didn't I think of that?.......wait a minute......don't answer that! :))
Offline strum
  • COG#: 12307
« Reply #58 on: September 22, 2017, 06:19:12 pm »
Our local Home depot did not sell that size coupling nut so I ended up borrowing a motion pro tool from a local shop.
 And I ordered one for my self. 18 bucks and ends all problems.
 Tried the spark plug socket thing. Non of mine will except an extension from the inside.
2008 C-14
« Reply #59 on: September 26, 2017, 03:07:46 pm »
Most have a rubber insert that helps hold the plug into the socket for easy removal but in all mine that just pushed right out.  But only 1 of my 3 plug sockets worked.  It did work and I used it...   Then after the job was done I found that I had ordered the one Murph has months before when I was planning ahead :/
Offline strum
  • COG#: 12307
« Reply #60 on: September 26, 2017, 11:04:42 pm »
Yeah I understand about the rubber but none of mine will except an extension from the inside. Im sure some works but I was just saying the Pro Motion tool or Murphs just makes this work out great. You can put a good 1/2" Drive socket (cant remmember the size from here) on the rear of the the tool and use a pull handle.
2008 C-14
Offline Deepsea
« Reply #61 on: September 27, 2017, 01:33:12 am »
By "Pull handle" do you mean breaker bar or ratchet?
Retired Navy Saturation Diver
Offline strum
  • COG#: 12307
« Reply #62 on: September 27, 2017, 02:30:36 pm »
I aways call it a pull handle but yes a breaker bar.
2008 C-14
