Author Topic: Winter tire pressure  (Read 344 times)
Offline MtnRider
  • COG#: 12840
« on: January 31, 2019, 03:04:39 pm »
I'm doing some riding during this cold season, even commuting (Denver area). In the morning the air temps are in the 30s and road temp sub-freezing and not quite that cold heading home. I've had a couple instances where the traction control kicked in when being a bit exuberant on the throttle that wouldn't happen when warmer. I run 41-42 PSI when it's warm. I'm wondering if traction would be improved if I ran 38-39 PSI while it's colder. My thinking; the tire & tread would be a little more flexible and a slightly larger contact patch with the cold rubber which I don't believe is getting near summer operating temps.   BTW, the concern for traction isn't for acceleration but cornering & stopping.
Your thought?
Thanks.
Leo
« Last Edit: January 31, 2019, 03:08:59 pm by MtnRider »
2015 Black C14
Offline 4Bikes
Re: Winter tire pressure
« Reply #1 on: January 31, 2019, 03:46:01 pm »
You will find that your TPMS will show higher pressures during the colder weather.  This thread explains why, and has a chart that relates pressure with temperature.  I don't adjust my pressures for cold weather, but since I think the rubber compound gets hard and slicker in the cold, it would probably be a good idea to have less pressure.
http://forum.cog-online.org/tires-suspension-c14/consistent-tire-filling-finally
Offline Charliedog
« Reply #2 on: January 31, 2019, 08:19:31 pm »
Really?  I always thought pressure increased with higher temperature and decreased with lower temperature.  If one sets tire pressures in the heat of the afternoon and checks them the next morning when it's cooler, they normally read lower.  Just my $.02.
Offline 4Bikes
« Reply #3 on: January 31, 2019, 08:24:25 pm »
It has to do with what the temperature is while you are filling the tires.  Filling to 42 lbs when it's cold will yield a higher pressure in the tire.  We all know tire pressures increase at the tire warms up.  If you want the tires to be an exact pressure, the chart allows you to make adjustments while filling depending on the temperature.
Offline lather
  • COG#: 10690
« Reply #4 on: January 31, 2019, 08:43:11 pm »
In typical riding weather 40 to 95 or so I think thhe tires warm up to a certain running temp more or less, affected mre by the flexing than by ambient temp. But I think this may change a bit in really cold temps - say below freezing. At these temps I wonder if a normally inflated tire gets up to normal running temp. So, thinking that lower psi causes the tire to flex more, it heats up better and gives better traction in sub freezing weather. Just my thoughts, nothing to back it up.
Offline BadgerApaches
« Reply #5 on: February 05, 2019, 04:14:37 pm »
Your thought?
Thanks.
Leo
Yes, bigger contact patch and will give a little more traction. Of course if your tires were almost bald to start with......?  :great:
Legal Services for Manufacturers world wide.
Offline Fred_Wa2gzw
  • COG#: 10400
« Reply #6 on: February 05, 2019, 11:57:25 pm »
If I remember correctly the 42PSI is at 60-65 degrees. As the temp drops so does the air pressure.
Fred
Wa2gzw
Offline Fred_Wa2gzw
  • COG#: 10400
« Reply #7 on: February 06, 2019, 12:09:48 am »
I just read the link that 4 Bikes referenced up above and that is a great explanation.
