Author Topic: 120/90/18 Thoughts or opinions for front tire  (Read 1736 times)
Offline Herbie
  • COG#: 10384
« on: September 17, 2017, 11:33:22 pm »
I am looking at tire choices right now, and reading all kinds of opinions. I really like what I read on the Shinko 777. But I have a question, after searching through some retailers I have found out that the 777 for the front only comes in a 120/90/18. Now I know that the 90 will be a taller tire which is okay for me but what I'm concerned about is the tire flex with the taller side walls. Is/ Has anyone running the 120/90/18 front tire? If so can you tell me what you think about it and would you run that size tire again? Thanks
2002 C10
« Last Edit: September 17, 2017, 11:38:56 pm by Herbie »
Offline Boomer
  • Me dwarfing Vivian
    • Boomers GTR Site
Re: 120/90/18 Thoughts or opinions for front tire
« Reply #1 on: September 18, 2017, 09:41:52 pm »
Too tall IMHO. Gonna give you really weird handling.
You can fit the 110/80-18 to the later rim and it sharpens the handling slightly and nearly corrects the Speedo error.
George "Boomer" Garratt
Wickford, UK
CDA-007
Offline Herbie
  • COG#: 10384
« Reply #2 on: September 20, 2017, 03:56:08 am »
Thank you Boomer I appreciate the input. I kinda had the same feeling about the 90 giving it a funky feeling. I guess I may have to go to plan B, because I really like to have matching tires and I don't want wing tires on it. Plan B Is Avon Am26 tires. I have plenty of time to decide though. Thanks  :great:
Offline kevingore
  • Moderator
  • COG#: 12469
« Reply #3 on: January 01, 2018, 05:08:34 pm »
I am running one one mine dont like it . it rubbed on my finder and melted the front and back of my finder so now im going to put the stock tire back on
« Reply #4 on: January 01, 2018, 05:19:03 pm »
Herbie, I'll ping Jim S. and see if he'll join the discussion.
I think he ran the AM-26 with good results.
Offline Jim Snyder
  • COG#: 7055
« Reply #5 on: January 01, 2018, 09:08:35 pm »
Yes I did have good results with the Avon AM-26's. I always love the threads that say it's hard to find the stock sizes for the C-10. The AM-26 tire has been available for both pre 94 and newer C-10 for years. And  I hate to sound like a broken record but unless you have followed my old C-10 through the twisties on these tires or tried them yourself, don't judge them until you do.
Offline Herbie
  • COG#: 10384
« Reply #6 on: January 01, 2018, 10:15:50 pm »
Thanks Kevin, that just confirms it, I'm not even going to try that size.
Thanks Ted for the assistance, I'm sure it will help others as well
Thanks Jim, I read a lot of tire threads and I'm pretty sure it was your post that swayed me towards the AM- 26 tires. I have read of your aggressive riding style  :great: and if it is a good tire for that then it will be a great tire for me. I'm more concerned with grip over mileage, so these tires are on the top of my list.
 Thanks all
Offline Jim Snyder
  • COG#: 7055
« Reply #7 on: January 01, 2018, 11:55:46 pm »
 Thanks all
I ran my tire pressure 38 front 40 rear. Even though the AM-26 is a bias ply tire you would never know it as it rides and handles very well.
Offline Herbie
  • COG#: 10384
« Reply #8 on: January 02, 2018, 01:49:47 am »
A Bias ply tire is fine with me. On my last connie I ran Bridgestone Battlax BT45 V rated bias ply tires and I was very impressed with them. I thought the grip on those tires were great and they did a good job of not following lines or tar snakes. Truthfully I am probably going to buy either the AM-26 or BT 45v tires as soon as the Metzlers run down a little more. Never been much of a fan of the Metzlers but they came on the bike. I'll keep the tire pressures you mentioned in mind. Thanks
Offline AmphibSailor
  • Hooligan
  • COG#: 12210
« Reply #9 on: January 02, 2018, 12:03:47 pm »
Oops.
Offline m in sc
« Reply #10 on: May 19, 2018, 02:56:08 pm »
I just installd tha avon am26's .. took it out for a ride yesterday. i have the later c10 that is specced at a 120 front. went with the 110. holy crap the difference is night and day. nimble, smooth. I highly recommend it.
took a long ride last night and had the GF on the back. before, if i took my hands off the bars i got the dreaded head shake under 45 mph. was sketchy. NOW, i can take them off at 60 and coast down to 20 no issues. and this is with a passenger (and without, i tried). while the answer a lot is 'dont take your hands off the bars', the point being is that there's a resonance that is removed by going this way tire wise (in my situation). nothing else was changed. the 120 is def too wide for the rim .
for the record, i also did the back tire 1st (avon 150) and it still had the low speed weave. next day did the front, and then it was gone.  :beerchug:
big thanks to jim for replying to my messages.
« Reply #11 on: May 19, 2018, 03:02:24 pm »
Geez, don't tell Jim he did good. His head will swell up. {again}   :-\
Glad it worked out for you.
See ya on the road..
Offline Jim Snyder
  • COG#: 7055
« Reply #12 on: May 19, 2018, 03:24:59 pm »
I heard that. I was sitting here at work and my ears were burning. Hey m in sc, Glad the AM-26's worked for you. I ran those things as hard as I ever ran a radial tire and they stuck like glue. They are probably one of the most overlooked C-10 tire choices out there.
