Author Topic: 320 MM rotors for 17" wheels  (Read 4528 times)
Offline AirMonger
  • COG#: 10838
« on: January 12, 2014, 10:41:16 pm »
After installing 2Fast's brake upgrade on my previous C10, the one thing I missed about my new to me 06, were the AWESOME brakes. I can't say enough about Brian's efforts to provide modern brakes for the mid evil, I mean pre 93 bikes. With that in mind, I set out to recapture the feel of the old set up. I secured a set of Racer Boy Chinese ZZR1200 rotors and two different sets of calipers.  First pic is the rotors installed along with the six piston calipers that I really wanted to install. Way too much juggling and the caliper would have to be positioned lower than need be. I settled on the four pot Tokico. Since I already know how well they work I was not really disappointed, I simply liked the visual appeal of the six pots. The second pick is the four pots mounted to the hand fabricated bracket. A simple block of 3/8 flat bar shaped to position the calipers where they need to be. Because of the diameter of the rotors I could not use the SV Racing mounts. No big deal as these are pretty easy to fab using a piece of scrap plastic for a template. These are the pads that came with the calipers and appear to be OEM. They were in excellent shape and I did not . I have a pair of Caltric sintered pads ordered but these are doing a stand up job for now. I installed a set of braided lines at the same time and am very pleased with the end result. The weather was beautiful on Saturday and I was able to get in a good ride although I stayed within the confines of Corpus Christi to take advantage of the stop and go situation to help with run in. Happy, happy, happy.
"It usually takes 20 years before people begin to appreciate a good design." Kevin Cameron
Re: 320 MM rotors for 17" wheels
« Reply #1 on: January 12, 2014, 11:06:25 pm »
Air Monger, looks good. Will the 320's fit a std 18 Connie wheel?
Did you buy them new? If so, where?
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #2 on: January 12, 2014, 11:14:07 pm »
No Ted.  The ZZR bolt number and pattern are different.  I think they'll fit many of the ZX wheels though.  I've been running stock ZZR1200 rotors for about 7 years on my ZX14 forks/ZZR1200 front wheel combo.  They do give you more whoa than you can effectively use.  I can lock the wheel at any speed.   :-[
But the best part is one finger braking too.
Fortis non Ferox
 Shafties Can't Wheelie
Offline GF-in-CA
« Reply #3 on: January 12, 2014, 11:54:55 pm »
Actually, the ZZR1200 rotors will bolt right on the stock late model C10 wheel.  Airmonger is using the 17" conversion wheel that has the same bolt pattern as the late model C10, which is a 5 bolt pattern.  The ZZR rotors are the same as the ZX7, ZX9 and ZX11 rotors that are used for the 320 mm rotor upgrade.
Looks great Airmonger  :great:
BTW, I think you're better off with the 4 pots over the 6 pots.  The Tokicos you have actually have slightly more total piston area than the 6 pots, and the 6 pots are known to have more issues with uneven pad wear than the 4 pots.  Some of the ZRX owners switch out their OEM 6 pots in favor of Tokico 4 pots.
« Last Edit: January 13, 2014, 12:06:15 am by GF-in-CA »
Gary F.
1998 ZGX1100
Central Valley California
Offline RodWpg
« Reply #4 on: January 13, 2014, 03:39:42 am »
nice!
« Reply #5 on: January 15, 2014, 02:06:45 pm »
Air Monger, looking at your photo it appears that you installed your brake brackets inboard of the Fork and Caliper Tabs.
I like your install, as it gives the wheel a cleaner appearance than installing Outboard Brackets.
Well done!!!!!
But I have a question.
I measured the 4 pot calipers pretty carefully and I think (to center the calipers on the rotor) you need the calipers to be .030" closer to the Rotors than a flat bracket allows.
Can you look at yours and see if the calipers are centered on your hub?
(Look for the seam line on the calipers to find center)...
Thanks in advance.
NOTE: since your using a 17" wheel, your (Rotor location)  may not be the same as a (STOCK) 18" wheel.
« Reply #6 on: January 16, 2014, 12:21:39 am »
I don't think the caliper being off center by .030 would make any difference.
« Reply #7 on: January 16, 2014, 07:46:12 pm »
.030" probably won't make a big diference as the opposing pistons will locate at the rotor (wherever it is).
I asked because I was checking the Dimensions I used when I machined mine.
 (Since I machined the surface, it was no big deal to cut off that .030" and center it exactly).
Was hoping I didn't goof....
« Last Edit: January 20, 2014, 02:10:49 pm by connie_rider »
Offline turbojoe78_MA
  • COG#: 8645
« Reply #8 on: January 16, 2014, 09:15:04 pm »
Any one know if there's a list of bikes with 320mm rotors that will bolt on to 94 - 06 connie rims?
I've got a 17" ZR7 front wheel I'll be installing some time this spring and am now thinking of up-grading to 320mm front rotors.
Offline GF-in-CA
« Reply #9 on: January 16, 2014, 11:23:37 pm »
Joe, you can use the list I made for compatible rotors for the ZX9 front end (go to the end of the article):
http://forum.cog-online.org/index.php/topic,30446.0.html
You can obviously also include the 1994 to 1997 ZX9.  These are all 320 mm rotors that will bolt on the 1994-2006 C10 front wheel.
HTH,
Gary F.
1998 ZGX1100
« Reply #10 on: January 20, 2014, 02:23:21 pm »
Thanks Gary, Air Monger.
  (AM,, I'll gage mine and see if I goofed).
I'm trying to work out dimensions so that I can have 10 sets of the Brackets machined for others.
(Need dimensions to be exact before I spend the $$).
See if I have this right??
Will bolt on the 1994-2006 C10 front wheel and can be adapted to forks.
4 Piston Tokico Calipers;
Kawasaki:
  ZX-7            91-95       x4 - 10 mm bolts
  ZX-9            94-97       x4 - 10 mm bolts
  ZX-11           93-01       x4 - 10 mm bolts
  ZZR-1200     02-05        x2 - 8 mm & x2 - 10 mm bolts
Suzuki:
 GSXR 600      00-04        x2 - 8 mm & x2 - 10 mm bolts
 GSXR 750      00-04        x2 - 8 mm & x2 - 10 mm bolts
320 mm Rotors;
Kawasaki:
  ZX-7              91-03
  ZX-9              94-97
  ZX-11            93-01
  ZZR-1200       02-05
  Mean Streak   02-08
Suzuki:
  VZ1600 Marauder  ??
310 mm Rotors;
ZX 750 H1/H2 (ZX7) 89-90
ZX 9R (ZX 900 E1/E2) 00-01
ZR 1100 A1-A4 Zephyr 92-95
ZR 1100 B1 Zephyr 96
ZX 1100 C1-C4 (ZX11) Ninja 90-93
ZRX 1100/ 1200  any year
« Last Edit: January 21, 2014, 01:54:54 pm by connie_rider »
Offline GF-in-CA
« Reply #11 on: January 20, 2014, 03:40:33 pm »
  ZX-7    91-95
  ZX-9    94-97
  ZX-11  93-01
  Others? (ZZR-1100)?
 (And some Suzuki's)?
320 Rotors;
  ZX-7              91-03
  ZX-9              94-97
  ZX-11            93-01
  ZZR-1200       02-05
  Mean Streak   02-08
Ted, the calipers on my list that you show will work, but they use larger mounting bolts, so there will be more clearance with the bolts that you are using on your brackets.  They use a 10 mm bolt vs. your 8 mm bolt.  The calipers you show in your pictures are a later design Tokicos that were used on the Kawasaki ZZR1200 and 2000 to 2004 Suzuki GSXR 600 and 750, among others.  Also, the only Suzuki that I know of that used the same 320 mm rotors was the VZ1600 Marauder, which was just a re-branded Mean Streak.
HTH,
Gary F.
1998 ZGX1100
« Reply #12 on: January 20, 2014, 04:29:29 pm »
Thanks Gary.    I corrected my list. (See if I got it right this time.)
Like many others, the endless combinations confuse me.
Some have asked, so I was trying to get a complete list.
I'll add to it if anyone else knows of others?
Offline GF-in-CA
« Reply #13 on: January 20, 2014, 06:52:48 pm »
Ted, will your brackets accept 10 mm bolts for the caliper?  If I remember correctly, your brackets have the caliper bolts going through the caliper into threaded holes in the rear bracket.  If that's true, it seems like any  of the calipers would require 2 8 mm bolst and 2 10 mm bolts.  Am I correct?
Gary F.
1998 ZGX1100
« Reply #14 on: January 20, 2014, 08:39:04 pm »
No,,,, hole thru the Caliper and brackets would have to be 2 mm (.08") larger.
8 MM Threaded holes in the Caliper were drilled out to 8 mm (.316") as I had to rotate the bole because the Inboard Bracket is threaded..
If that's true, it seems like any  of the calipers would require 2 - 8 mm bolts and 2 - 10 mm bolts.  Am I correct?
That is what I had assumed prior to your note earlier.
I'd like to see a caliper with 10 mm bolts as I assume they have larger tabs to accept the 10 mm bolts. I don't think the brackets I built would work with 10 mm bolts as there is not sufficient material for the larger hole.
AirMonger, on your set-up do you use 4 - 10 mm bolts on each caliper?
Mine has 2 - 8 mm bolts and 2 - 10 mm bolts.
  • COG#: 8645
« Reply #15 on: January 20, 2014, 09:00:18 pm »
HTH,
Gary,  thanks a bunch for the link ... now you've got me wanting a whole new front end.  Joe
Offline AirMonger
  • COG#: 10838
« Reply #16 on: January 20, 2014, 10:11:51 pm »
Ted, I used the stock 10MM bolts on the lowers to bracket and drilled the calipers to accept the 8MM bolts. I used a piece of 3/8 flat stock for the bracket, counting on using hardened 8MM cap bolts. I am very confident in the strength of the set up. Short of doing a stoppie, I am impressed with the increased brake performance. It stops harder than I recall the 18" 2Fast set up, simply because of the increased contact patch, and the 18 stopped plenty hard.  I have double checked the hardware after practically every ride and nothing is amiss. I ordered my Race Tech emulators yesterday, so the quest goes on.........
« Reply #17 on: January 20, 2014, 10:36:32 pm »
Thanks AirMonger.
Your set up definitely looks good.
I forgot to ask, what did your Calipers originally come off of?
Mine came of of a ZZR-1200.
Gary thinks some of the Tokico Calipers used 10 mm bolts instead of the 8 mm bolts (that your and mine have)..
PS: Will I see you at Big Bend or Wildflower?
Offline GF-in-CA
« Reply #18 on: January 21, 2014, 02:21:49 am »
OK, that's what I thought.  My point was that I think you want to stick with recommending the GSXR and ZZR calipers for your setup, since that is what you used and the others on the list would not fit as well because of the larger holes.  Sorry if I caused any confusion.
Gary F.
1998 ZGX1100
« Reply #19 on: January 21, 2014, 01:20:35 pm »
Thanks Gary. I thought you were unsure about the older models having 8 or 10 mm bolts.
When/if I get some built to sell to others, I will make that suggestion.
I assume that my brackets would fit onto a Caliper that uses 10 mm bolts.
(I could easily build bushings to put in the 10 mm holes). I'm just not absolutely sure the hole locations would be the same.
AirMonger I sent you a PM.
I looked at Ebay yesterday. Your bike is making me start considering 17" wheel and 320 rotors.
« Last Edit: January 21, 2014, 08:44:34 pm by connie_rider »
Offline GF-in-CA
« Reply #20 on: January 21, 2014, 07:27:54 pm »
Ted, the hole locations are the same.  I am using the same calipers as you on my ZX9 forks, which were originally designed for the earlier Tokicos that use 10 mm bolts.  I have bushings in the holes to eliminate the extra clearance and they fit perfectly relative to the diameter of the rotor.  I did have to space them inboard slightly, so I think the earlier models have a slightly different offset, but the hole locations are the same.
HTH,
Gary F.
1998 ZGX1100
