Author Topic: Has Anybody used a Metzeler Roadtec Z8 Interact Tire?  (Read 967 times)
« on: October 28, 2018, 05:52:09 pm »
Anybody used a Metzeler Roadtec Z8 Interact Tire on their C-10?  {Or even their C-14}
I am NOT trying to start a big tire discussion about which tire is best.
I'm planning to buy one in a 110/80-18 size, and wondering if others have tried it?
Found it on Bikebandit.
https://www.bikebandit.com/tires-tubes/motorcycle-tires/metzeler-roadtec-z8-interact-motorcycle-tire/p/30568
« Last Edit: November 01, 2018, 04:08:13 pm by connie_rider »
Offline CRocker
  • '02 C10 CDA # 416
Re: Anybody used a Metzeler Roadtec Z8 Interact Tire
« Reply #1 on: October 31, 2018, 08:36:35 pm »
Wow...crickets...
« Reply #2 on: October 31, 2018, 09:29:48 pm »
Crickets??
Ted
Offline CRocker
  • '02 C10 CDA # 416
« Reply #3 on: October 31, 2018, 09:52:49 pm »
Yeah...no response at all...crickets...
Looks like a good deal. too...
« Reply #4 on: November 01, 2018, 04:07:12 pm »
Ahh, now I follow you.   Apparently I'll be the first to use the Metzeler Roadtec Z8 Interact Tire.
I currently have a ME-888 (bias ply) on the rear and a Avon Storm (radial) on the front.
The Storm is worn out and need a replacement.
Decided to put the Metzler on the front.
   Like the look's of the tread, advertising sounds good, and decided to go Metzeler front/rear.
Haven't ordered the tire yet. Was hoping to hear comments about it from others..
Offline Jim Snyder
  • COG#: 7055
Re: Has Anybody used a Metzeler Roadtec Z8 Interact Tire?
« Reply #5 on: November 01, 2018, 07:01:15 pm »
Ted, I ran the Metzler Z6's on my C-10 when I did the 17" conversion and they handled great. I would see no problem with the Z8 but I would definitely consider putting on a set and getting rid of that 880.
Offline Daboo
  • COG#: 12797
« Reply #6 on: November 01, 2018, 07:10:06 pm »
They seem to be a good tire, and in my experience, they are better than the Roadtec 01.  The only really big negative that has come up in other forums, is the wear down the center.  In the morning, you think you're good.  In the afternoon, you're not sure your can make it home.
This picture shows a little of what I'm talking about.
Chris
John 14:6
Offline Fix ur Critter
« Reply #7 on: November 02, 2018, 12:12:41 am »
Hello
I bought a 190/55 rear Z8 for my C14 to replace a Mich PR4 that was squared off in 1500 miles. I immediately felt a great difference,but again was coming off a bad tire. Still running the mich front
I only have about 1000 miles on the Z8 and have nothing but good things to say. Overall like it better than the PR3 and PR4.. I will never go back to Mich- too many mediocre to negative experiences for an expensive tire.
The Z8 was on super discount because it was 4 years old. But I needed a new tire before leaving on a trip. I am trying Dunlop Q3+ next
because i wanted to previously. If they are not great , I will go back to Z8
Bottom line - I like the Z8 better than the multiple Michelin and Bridgestones i have run in the past
Be Kind, especially to the innocent
Spay/Neuter always
Show interest to a kid, they will remember it for life
« Reply #8 on: November 02, 2018, 03:08:26 am »
Thanks for the replies.
  Jim; They don't make a tire for the rear of my C-10.
          Just about given up finding a radial rear as the few available all seem to have problems.
  Daboo: "OMG",,,, that tire still has tread near the wear area..
               Does not seem to be ready to have cord showing in the middle.
                   Hopefully a front does better.
  Fix ur critter; The Z8 you had was 4 yrs old when you got it? I'll let you know how this one does...
Offline Jim Snyder
  • COG#: 7055
« Reply #9 on: November 02, 2018, 11:14:44 am »
Ted, if you want a good handling C-10 tire go with the Avon AM-26's. They are bias ply but you would never think so. You have followed me thru many a twisty when I ran those on the silverbullet.
« Reply #10 on: November 02, 2018, 02:00:50 pm »
I'll do that eventually. Hate to chunk an almost new tire.
  NOTE: This is a ME-888, not an 880.
             The 888 supposedly has better/softer rubber than a 880.
The C-10 is my spare bike that I *tinker with & lend to folks to ride occasionally. {It mostly sets}...
  ** This year I've installed a C-14 rear shock & lowering rocker, stiffened the front end {by cutting the springs},
                     raised the fluid level, and set spring sag on both ends.
                            Thinking on installing Emulators next.
Nephew rode it last and did a good job in the twisties.
   Front tire is now worn out, rear is nicely scuffed.
    If he continues to ride it, I'll also do the rear.
The reason I picked this front, is I want to see how it improves the handling.
Assuming it does: I'll then be able to see any improvement from a better a rear tire.
« Last Edit: November 02, 2018, 03:30:41 pm by connie_rider »
« Reply #11 on: November 19, 2018, 08:29:25 pm »
I finally decided to purchase the Metzeler Roadtec Z8 Interact front Tire in a 110/80-18 size.
Before I purchased it, I realized that it is not shown on Bike bandit's site to be a radial so I did some more research.
Further reading shows it on their site as a multi-compound (Bias/Radial)??
See their advertisement; https://www.bikebandit.com/tires-tubes/motorcycle-tires/metzeler-roadtec-z8-interact-motorcycle-tire/p/30568
Other Suppliers show it as a 110/80ZR -18 and clearly say it is a radial.
But, I want it all: What I'm hoping for is a tire with radial handling that gets the mileage of a Bias Ply.
Will see what happens.  >:D
As I mentioned before, I have  Metzeler ME-888 on the rear.
« Last Edit: November 19, 2018, 10:10:22 pm by connie_rider »
« Reply #12 on: November 22, 2018, 02:56:27 pm »
The tire arrived VERY quickly.
Thought it might take awhile due to Thanksgiving time frame.
Got here 2 days after I ordered.  Well done Bike Bandit!
It is a 110/80ZR-18.
I sent Metzler a note asking if it is also a dual compound. No reply.
Online SteveJ.
  • COG#: 5603
« Reply #13 on: November 23, 2018, 12:26:20 am »
Hiya Ted. A tire that has dual compound is referring to the tread, not the carcass construction. A dual compound tire will have a softer, grippyer tread on the edges and a longer wearing strip in the middle.
 :beerchug:
Tick Tock, baby (Ironbuttal)
« Reply #14 on: November 23, 2018, 01:03:17 am »
Thanks Steve. I agree...
On the Bike bandit site it specifies that the O and M spec tires are bi-compound.
It does not say that the other sizes are also bi-compound.
Metzler's site also seems to say this....
We're trying to determine if the other sizes are also bi-compound. So, I sent a note to Metz and asked..
Features
•MAW (Metzeler Advanced Winding) technology
•The profile shape, inspired by the Greek letter "Pi", maximizes the flexibility of the profile, thus ensuring an optimum tire footprint under in all conditions
•The 3-zone-tension Interact ™ Technology gives outstanding mileage and sporty cornering grip
•Multi Zone Tension technology, new updated tread profiles and functional tread pattern place the Z8 Roadtec Interact at the top of the sport touring tire class
•M-Spec and O-Spec tires feature a bi-compound design
« Last Edit: November 23, 2018, 01:18:15 am by connie_rider »
Offline who me?
  • COG#: 11932
« Reply #15 on: November 23, 2018, 06:11:26 am »
 :popcorncouple:
Im looking at new shoes before riding season next year The Z8 is on the list
95 C10 The Mule
02 C10 parts are parts
« Reply #16 on: November 23, 2018, 04:06:42 pm »
Hopefully I'll get the tire on and tested in the coming weeks.
They now offer a new tire. Think it's a M1.
I preferred the Tread pattern of the Z8.
Update: I just got off the phone with Bike Bandit.
            They say this tire "is" dual compound.
« Last Edit: November 23, 2018, 04:36:33 pm by connie_rider »
