Author Topic: Never throw anything away  (Read 1163 times)
Offline Bill
« on: February 09, 2012, 09:10:34 pm »
Removed the forks today for cleaning and new seals. Didn't have a damper rod holding tool, so started digging through my "gonna get rid of this stuff someday" boxes and came up with a bronze pipe fitting with a 15/16" hex end (23.8mm) and an old 1/2 inch extension that I had battered up using it for a drift. The 1/2" square end fit pretty snugly into the fitting, so I put a gob of JB on the end of the extension and drove into the fitting with a hammer.  The thing works like a champ, got the rods out in a jiffy.
Once you go over the hill, you start picking up speed.
'98 Concours
'92 Honda 750 Nighthawk
'85 Honda VF500F Interceptor
'96 Honda XR400R
Offline Bill
Re: Never throw anything away
« Reply #1 on: February 10, 2012, 12:07:20 am »
I agree.  I have a couple of "possible" boxes.  Stuff that I might possibly need in the future.
I have an air compressor and air driven ratchet and that was effective in removing that bottom bolt on my 1985 Kawasaki ZN700.  You need some sort of tool like you used if you don't have an air wrench that spins the bolt fast.
I've read on another forum that you could use a wooden mop or broom handle.
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
« Reply #2 on: February 10, 2012, 12:15:45 am »
A brrom handle is the only tool I've ever used to hold the inners in. But I do use an impact wrench to spin that puppy right off. So there is no problem loosening up the bolt.
  • COG#: 13095
« Reply #3 on: February 10, 2012, 11:47:55 pm »
Ditto, I did mine the last time this same way. Works like a charm
Offline JProbst
  • COG#: 9698
« Reply #4 on: April 06, 2012, 12:00:24 am »
Wish I'd read this before I replaced my fork springs. Spent time trying to figure out what the special Kawasaki tool actually did, staring down the fork tube guessing at what size the hex might be, finding a socket (24mm) that would fit inside the fork tube (thin wall), jammed a 24mm nut into the socket with a paper shop towel, and attached to a very long half inch extension to my rachet. Could not use my impact as it was 2am and daylight people don't understand when you light an impact wrench off in the garage at that hour. My method worked great and no one lost any sleep, I just gained a few more gray hairs  :)
1995 Connie: 7th gear mod, torque cams, Progressive.....
1992 Suzuki Bandit: Set up for sport touring, lost to a deer
1985 Suzuki Madura: Took it apart, sold it in a box
1977 Honda 550 4K: Hit a truck @ 70MPH
