Author Topic: Paint versus Powder Coating  (Read 1635 times)
Offline Pbfoot
  • COG#: 10807
« on: October 07, 2014, 06:35:09 am »
So I am waiting on the arrival of a MeanStreak rear wheel and a ZR7 front wheel.  I have had good success with painting and I like the idea that the surface can be easily repaired. Wanted opinions on painting the wheels or powder coating.
Offline Flat-spot
  • COG#: 11111
Re: Paint versus Powder Coating
« Reply #1 on: October 07, 2014, 07:20:15 am »
I can tell you from personally sandblasting off powder coating that it is unbelievably stubborn, tough, and durable.  Chances are you will never need to repair its surface.  The hard, smooth surface is also easy to keep clean.
'08 C14
Offline Jwh360
  • COG#: 10578
« Reply #2 on: October 07, 2014, 01:09:23 pm »
+1 on that.  Did my MS/ZR7 combo over a year ago and they still look like new.
SW-AAD SoCal - 1986 Concours 1000 "OGSD", 1979 RD400F Daytona Special, 2013 Suzuki GSX-R 750 "Money Pit", 2012 Concours 14 "Big Red" DOA
Offline J.R.
« Reply #3 on: October 07, 2014, 10:51:26 pm »
Powder coating holds up well on things that don't flex.
Offline Pbfoot
  • COG#: 10807
« Reply #4 on: October 07, 2014, 11:50:05 pm »
Thanks, looks like it will run $100 per wheel.
Offline GF-in-CA
« Reply #5 on: October 08, 2014, 02:35:20 am »
I painted mine.  I was a bit of work, but I like the way they came out.  They are holding up pretty well, but powder coating would definitely be more durable.
Gary F.
1998 ZGX1100
Central Valley California
Offline Pbfoot
  • COG#: 10807
« Reply #6 on: October 08, 2014, 09:16:48 pm »
Looks good GF.
Offline tdbru
  • COG#: 10824
« Reply #7 on: October 09, 2014, 02:15:08 am »
leadfoot,
I powder coated my ms/zr7 wheel set.  or rather I had them powder coated.  I didn't do the work.  it is a very durable finish that's easy to clean.  and since my painting skills usually results in not so good results, it was another reason I turned it over to someone who did it for a living.  you may be a better painter than I, but if you can swing it I'd still recommend powder coating to painting.
-Brian
Offline Pbfoot
  • COG#: 10807
« Reply #8 on: October 10, 2014, 09:01:43 am »
Thanks for the replies.
Offline goatmar
  • COG#: 7957
« Reply #9 on: October 13, 2014, 04:52:07 pm »
GF nice paint scheme.  :great:
