Author Topic: Azaro rear tire failure  (Read 9515 times)
Re: Azaro rear tire failure
« Reply #50 on: July 02, 2014, 04:21:25 pm »
Take a 800lb loaded bike with two 220lb people and pull a wheelie or a big hill and what is the load on that back tire?   I think the C10 is only rated to carry like 480lb but I can't find that anywhere.  700+480=1180.  How much of that is on the back when you take off?  Lots!
Offline hlh1
  • COG#: 548
« Reply #51 on: July 02, 2014, 04:46:03 pm »
This is especially true when I hold that wheelie for several hours...    :)
Offline GeorgeRYoung
« Reply #52 on: July 02, 2014, 05:12:25 pm »
. . . I think the C10 is only rated to carry like 480lb but I can't find that anywhere. . .
Per this blurb,
http://www.mcnews.com/mcnews/articles/kwstats.htm
GVWR=1118 lbs, wet weight 618 lbs (seems low), carrying capacity 500 lbs. My other reading says the wet weight is more like 670 porky pounds, making the carrying capacity 448 lbs.
Offline Eddie-SC
  • COG#: 7073
« Reply #53 on: July 02, 2014, 05:46:43 pm »
Per this blurb,
According to the owner manual, the carrying capacity is 200kg (441 lbs). I've also seen the wet weight listed as 670 lbs, George. So, a total of 1,111 lbs.
Anderson, SC
1969 Triumph Bonneville
  • Stayin' for the people....
« Reply #54 on: July 02, 2014, 11:28:53 pm »
On my 3rd Azaro.  Second bit it early with a big old screw.  The current one has fared well with about 1k
miles on it so far.  So I haven't the 'time' most have on the tyre, but I haven't seen any the failures listed.
I'm on the fence...  I love the tyre's performance...  maybe another beer will help.  ???
Offline hlh1
  • COG#: 548
« Reply #55 on: July 03, 2014, 12:09:57 am »
I'm beginning to wonder if all of the failures are only on two up, and loaded, C10s.  It may be that the Azaro just can't handle the load.
Offline AirMonger
  • COG#: 10838
« Reply #56 on: July 03, 2014, 01:59:33 am »
Solo rider, well maintained. Would love to see a different result. Loved the radial feel and ride. Did the 17" conversion and run PR3's. When I ride my 90 with BT 45's, they feel like wooden rim protectors. I still have confidence in the 45's and would not trade the ride and response of the Michelins for any other tire.
"It usually takes 20 years before people begin to appreciate a good design." Kevin Cameron"
06 C10  03 KLR650  02 G L1800  04 Heritage  74 R60/6  Always one step away from another bike.
Offline Boomer
  • Wickford, UK
    • Boomers GTR Site
« Reply #57 on: July 04, 2014, 01:58:20 pm »
Well I weigh 360lbs and my better half ain't no lightweight either.
With luggage we must be well over that 500lb limit.
Our biggest problem on the C10 was the centrestand grounding but fixed that with a ZZR1200 rear shock.
Those who have had these failures, do you all live in hotter parts, or colder parts?
George "Boomer" Garratt
Wickford, UK
CDA-007
Offline Jack_Provda_CA
  • COG#: 6677
« Reply #58 on: July 04, 2014, 03:08:21 pm »
My failure happened in high heat - 100 degrees plus, with a full load.  I love the way the Azaro/Storm combo handles and this was my third set.  I have not found a better handling combo for the stock rims. However, I would be hesitant to use an Azaro rear tire if I knew I would be touring with a passenger.
Offline hlh1
  • COG#: 548
« Reply #59 on: July 04, 2014, 10:15:40 pm »
I've had two fail in May in 70 degree spring weather.  The third, at the National, was in 90 degree weather.
Offline goatmar
  • COG#: 7957
« Reply #60 on: July 10, 2014, 05:00:37 pm »
I had the same issue with a front tire, but it was a Roadsmart.  Delaminated and bulged out about 12" long down the center of the tire.  They claimed wrong air pressure.  I say bad tire.  Only one I had problem with, I'm still running Roadsmarts 2 though.
Offline hlh1
  • COG#: 548
« Reply #61 on: July 10, 2014, 05:03:24 pm »
I hear ya.  You hope that the problem won't reccur because you like the tire so much.
« Last Edit: July 10, 2014, 08:41:39 pm by hlh1 »
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #62 on: July 10, 2014, 07:48:09 pm »
I had a Pilot GT do the exact same thing. No way was it pressure. Even with the bulge the pressure was still correct.
Fortis non Ferox
 Shafties Can't Wheelie
Offline Douglas
  • COG#: 6426
« Reply #63 on: August 14, 2014, 10:21:05 pm »
Crap I just bought three of these :-[
ASE Certified mechanic.
Offline hlh1
  • COG#: 548
« Reply #64 on: August 15, 2014, 10:24:19 am »
Not everyone has had my problems, thank goodness.
