Author Topic: better shock  (Read 1939 times)
Offline Danny sparks
better shock
« on: May 29, 2017, 06:35:11 am »
Looking for information on fitting a better shock .what is available and what will I have to change to make it fit.a lot of people going on about zzr shock. .is there a page on the site were I can get help..cheers
Offline mattchewn
Re: better shock
« Reply #1 on: May 29, 2017, 12:40:26 pm »
Danny,
The other option is a C14 shock as a replacement. Many folks are very happy with this swap and it can be done at a reasonable cost as well.
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Re: better shock
« Reply #2 on: May 29, 2017, 12:49:52 pm »
  Got this shock yrs ago. Still really happy with it. One of the better upgrades for my C10. :) :)
        https://www.murphskits.com/product_info.php?cPath=1_97&products_id=85
Offline fred-houston
  • COG Membership Officer
  • COG#: 9066
Re: better shock
« Reply #3 on: May 29, 2017, 03:13:12 pm »
You basically have three options, four if you count the stock shock.
ZZR1200 Shock, C-14 Shock, Progressive Shock.  I am sure there are some others out there, but most go with one the the three I mentioned.
I tried them all, and I personally like the C-14 the best, others will tell you the Progressive is the best, and even more are going to state the ZZR shock is the only way to go.
You just have to pick your poison and try one and see how it does for you.  It is fairly inexpensive to purchase the ZZR and the C-14 shock, but the Progressive is a a bit pricey.
You will need to do some minor modifications to install the ZZR and C-14 shocks, but it is not that difficult and doing a search on this forum will explain the installation.  The Progressive, is simply an install and go with no modifications.
If you are on the heavy side like me, I would go with the C-14 or Progressive.  The ZZR can be a bit soft for heavy riders, at least if was for me.
Hope this helps.
Missouri City, TeXaS
1999 C-10 EFI (Semi Naked)
2016 Yamaha Super Tenere
Offline MotoCommuter
  • Kurt Brown - SE AAD GA
  • COG#: 7115
Re: better shock
« Reply #4 on: May 29, 2017, 04:35:36 pm »
I went with the Progressive 465 shock and did not regret it. Many were going with the C14 shock as they were able to purchase them at a decent price when the C14 owners upgraded their shock.
GA Wrenching Session: Apr 6
Rally In The Valley: Apr 25-28
HSMR #6: May 3-6
Beat The Summer Heat: Jun 28-30
If it's not fun, why do it?
Re: better shock
« Reply #5 on: May 29, 2017, 05:17:06 pm »
I'm under the impression that the C-14 shock will raise the b1ke about 1" - 1 1/2".
If you aren't over 6', I think you will need to add a lowering rocker to keep the bike at approx. stock height.
Offline beaucephus
  • COG#: 12214
Re: better shock
« Reply #6 on: May 30, 2017, 12:03:22 am »
The need for a lowering rocker for the C-14 should be considered if the other options do not require this.  It does need a lowering rocker.
Re: better shock
« Reply #7 on: May 30, 2017, 04:10:37 am »
Can I use the same Bolts and fittings as c10 when I put the c14.shock on.or do I need the ones that come with the c14.shock. ...
Offline oldsmoboat
  • 2004 C10
Offline beaucephus
  • COG#: 12214
Re: better shock
« Reply #9 on: May 31, 2017, 10:24:56 am »
You need the C-14 bolts and to fabricate a bushing for the lower bolt to fit into the rocker.  Not plug and play.
Offline Pbfoot
  • COG#: 10807
Re: better shock
« Reply #10 on: May 31, 2017, 11:36:14 am »
To do the C14 rear shock you need the following: 1-10mm id x 20mm od x 30mm long bushing for the lower mount, 1 C14 lower mount bolt, grind 1mm off of each side of the upper shock bushing. I reused my top C10 bolt by using a spacer. Do it.
Re: better shock
« Reply #11 on: May 31, 2017, 02:04:43 pm »
Will a ZX-14 rear shock work on a C-10?
Only reason I ask is; the ZX shock appears to have both compression and rebound damping.
http://www.ebay.com/itm/06-11-KAWASAKI-NINJA-ZX14-REAR-SHOCK-ABSORBER-SUSPENSION-LINKAGE-LOWERING-LINK-/292105177897?hash=item4402d34b29:g:BxEAAOSwONBZChTU&vxp=mtr
NOTE: The shock I posted, also comes with a lowering Link and ZX-14 rocker...
« Last Edit: May 31, 2017, 02:11:04 pm by connie_rider »
