Author Topic: front end shake  (Read 807 times)
Offline Gunner
  • COG#: 11089
front end shake
« on: June 29, 2013, 07:43:56 pm »
 ??? So I just purchased a 2006 Concours with 12,000 miles and it runs well. Last evening after jamming through some tight corners on some less than pristine backroads up here in Alaska, I took my hands off the grips to shake them out as I often do and experienced a side to side almost tank slapping within a second from the bars. No clue what causes this. The machine corners fine and as soon as I apply pressure to the bars again everything is cool. I like to take my hands off briefly in a safe situation to shake them out but this was so immediately violent I do not dare. Any suggestions what to look for out there in COGLAND?
Offline VTconnie
  • COG#: 11081
Re: front end shake
« Reply #1 on: June 29, 2013, 08:08:58 pm »
I am also fairly new to Connies but that shake is from the steering stem bearings. They likely need to be tightened, I also have to do the same thing. At high speeds no problem, but the 30-40 range is a good shake with no hands on the bars. Also depends on front tire pressure, too low doesn't help
Offline Gunner
  • COG#: 11089
Re: front end shake
« Reply #2 on: June 29, 2013, 09:00:22 pm »
Where about in Vermont are you? I used to live in Peru near Manchester with many fine roads nearby. I had a 2002 Connie there and never had any problems with it in over 20,00 miles. How difficult is it to tighten steering bearings? I was hoping for just a wheel out of balance or uneven bar weight, something simple since my mechanical skills are less than optimum. ???
Offline Bur
    • Bur's Biker Blog
Re: front end shake
« Reply #3 on: June 29, 2013, 11:51:06 pm »
Had this happen once, and yeah, intense pucker factor and as close to a tank slapper as I ever want to get.  While my steering stem needs some attention I know low tire pressure and bad asphalt "gators" contributed.
Area Rep, Christian Motorcyclists Association
1986 Concours "Miss Swail" <5,000 miles to 100K
1996 Concours "Belle" 14,763
Offline ron203
  • COG#: 9847
Re: front end shake
« Reply #4 on: June 30, 2013, 12:26:19 am »
Hi guys. Lots on info on here about this. Tighten the steering head nut with a 40-42 spanner wrench, probably 1/8 turn and it will likely stop. Search for the threads. It's pretty common and easy to fix.
2014 C-14
2008 Goldwing
Offline Gunner
  • COG#: 11089
Re: front end shake
« Reply #5 on: June 30, 2013, 08:52:32 pm »
I was wondering why this shake would start so suddenly since there were no symptoms prior. It only shakes with my hands off the bars. If I just barely put some pressure on them it immediately stops. I checked the forks for looseness with weight off the front of the bike and can detect no movement. Tire pressure is within a couple pounds.
