Author Topic: c14 shock conversion  (Read 847 times)
Online bajasam
« on: April 11, 2019, 02:28:58 pm »
So got my ebay c14 shock,getting ready for install on my c10, wondering if anyone who did the conversion and Did Not lower the rear end, if you just left it 1-2 inches higher which apparently is what the c14 shock does to your c10, did you experience any mechanical problems from the increased drive line angles, or any handling quirks from the new raised rear end orientation. this is in regards to relaxed easy cruising, Not racing or track type riding. Thx
Re: c14 shock conversion
« Reply #1 on: April 11, 2019, 03:10:15 pm »
I'm pretty sure that several did not add the lowering rocker.
But I think most also didn't add preload and did not get the high seat increase.
Makes for a softer ride/minimal angle changes, but much of the available "travel" is used up because there is more sag.
« Last Edit: April 11, 2019, 05:05:35 pm by connie_rider »
Offline Rob
« Reply #2 on: April 11, 2019, 03:48:05 pm »
I did it without the lowering link; I'm 6'-5" so I had no need as far as flat footing is concerned.  I liked the change it made in handling.
Offline bowtie39
  • COG#: 10014
« Reply #3 on: April 11, 2019, 05:15:41 pm »
Having ask about this conversion have had only comments about how it changes the way the bike rests on the side and center stands.  Great for putting up on center but may make bike less steady once on.....it's higher of course.  The same goes for the side stand as it changes that angle and less stable.  No first hand experience yet but those two issues seem possible.
Offline fred-houston
  • COG Membership Officer
  • COG#: 9066
« Reply #4 on: April 11, 2019, 06:29:54 pm »
+1
Exactly why I installed a lowering link.  Just a tiny nudge from the rear when it was on center stand was enough to push it off.  I also felt it leaned way too much on side stand.
Missouri City, TeXaS
1999 C-10 EFI (Semi Naked)
2016 Yamaha Super Tenere
Offline Pbfoot
  • COG#: 10807
« Reply #5 on: April 11, 2019, 07:03:18 pm »
I have done the conversion with no lowering rocker. Turn in is much quicker. Center stand easy peasy. No problems with the side stand. I just don't look at it.
Offline Pbfoot
  • COG#: 10807
« Reply #6 on: April 11, 2019, 07:05:20 pm »
I also made an extra sleeve for the bottom mount. If you want it PM me with your address and I will mail it to you.
« Reply #7 on: April 11, 2019, 10:00:15 pm »
If he doesn't want it, I need one for the conversion on my son's 87.
Online bajasam
« Reply #8 on: April 12, 2019, 01:08:13 am »
did noone just use the 10mm bushing from the c14 linkage rather than drilling out the c10 bolt to make a bushing, both bikes use the same bearing in that location but rather than a greaseable bolt the c14 has the 10mm bolt going thru a bushing pressed into the bearing. also does anyone have an idea how much i'll need to extend the center stand to get the rear wheel fully off the ground ?
Offline Pbfoot
  • COG#: 10807
« Reply #9 on: April 12, 2019, 01:43:31 am »
  You need a 10mm I.D by 20MM O.D x 30MM long bushing. The links from the shock to the pivot is different. C14 parts won't work. Center stand is fine.
« Last Edit: April 12, 2019, 01:23:06 pm by Pbfoot »
Online bajasam
« Reply #10 on: April 12, 2019, 02:06:10 pm »
i'll post later today when i get the old shock out, but thats the size bushing that i pulled out of the c14 shock linkage. both the c14 bushing and 10mm bolt, and the greaseable bolt on the c10 both go in the exact same part number bearing with a 20mm ID. some have reported that the centerstand will no longer lift rear wheel off of the ground,as i definately want to make sure i dont lose that ability. Thx.
Offline Pbfoot
  • COG#: 10807
« Reply #11 on: April 12, 2019, 03:45:40 pm »
Most of us put the center stand on a 1 inch thick piece of wood when we remove the rear tire. If you make a bushing the lower bolt from the C10 works fine.
Offline m in sc
    • 2strokeworld.net
  • COG#: 13057
« Reply #12 on: April 12, 2019, 04:40:46 pm »
i'll be doing this soon myself. good info for sure. I have soem ideas how to lower it in the back, will follow up when i do some measuring.  >:D
Online bajasam
« Reply #13 on: April 12, 2019, 06:05:56 pm »
PB was right, the c14 bushing was only 18mm,not 20mm, parts fiche was showing incorrect bearing apparently, i'll be drilling out my c10 greaseable bolt i reckon. m in sc,,theres quite a few c14 shocks on ebay now in the 40-50 dollar range if your looking to pick one up for future use.
Offline m in sc
    • 2strokeworld.net
  • COG#: 13057
« Reply #14 on: April 12, 2019, 06:54:38 pm »
I have one enroute, 45 shipped.  :beerchug:
Offline Pbfoot
  • COG#: 10807
« Reply #15 on: April 12, 2019, 07:26:44 pm »
I zip tied the adjuster next to the battery. Start on the lowest setting as the rear suspension geometry is different.
Online bajasam
« Reply #16 on: April 12, 2019, 10:03:42 pm »
lowest setting for both the knob and the screw?? or just the knob clicker
Offline Pbfoot
  • COG#: 10807
« Reply #17 on: April 13, 2019, 01:49:31 am »
I am only aware of the knob. Do you know something I don't? My shock came off a 09.
Online bajasam
« Reply #18 on: April 13, 2019, 02:19:03 am »
I dont have a c14 manual but from what ive read the clicker knob is for compression damping and the slotted screw at bottom of shock is rebound dampening, it has 3 turns,knob has 11 clicks.
Offline Pbfoot
  • COG#: 10807
« Reply #19 on: April 13, 2019, 09:39:56 am »
Cool.Thanks.
« Reply #20 on: April 14, 2019, 01:25:56 pm »
The klicker knob is for spring preload. (To set the sag)
The adjustment screw {at the bottom} is for rebound damping. (To set rebound)
There is not a compression damping adjustment.
Pay attention to the setting's as a C-14 shock is not intended for the C-10 with Rocker.
 (ie; Because of length/angle/etc changes; the C-10 rear suspension geometry is changed a lot from stock with this mod)
      My C-10 {has 2012 C-14 shock and 1 1/2" lowering rocker}
      I had to dial in "quite" a bit of preload to set the sag.
      I found the damping was set way too stiff/slow, and had to back the stock setting off to get the rebound the way I wanted it.
NOTE: I am NOT a suspension Guru. I'm only a rookie and passing on what I think.
          I watched many video's and talked with others to try to learn how to do the basic settings.
          I think I finally have it close.
Don't recall exact settings, but I think it's set at 18-20 clicks in and 1 or 1 1/4 turns on the damping.
« Last Edit: April 14, 2019, 02:41:54 pm by connie_rider »
Offline oldsmoboat
  • 2004 C10
  • COG#: 11969
« Reply #21 on: April 14, 2019, 02:32:18 pm »
« Last Edit: April 14, 2019, 02:36:14 pm by oldsmoboat »
