Author Topic: C14 shock  (Read 3412 times)
Offline Danny sparks
C14 shock
« on: August 16, 2017, 07:52:39 am »
Got myself a c14 shock.  Getting a  bush made for the bottom mount.. my question is Where Have You mounted the gas Reservoir any suggestions as I haven't had the chance to look yet...also how many.clicks do the ajustable black nob have as mine is a bit poor at turning ...a bit squeaky and stiff...cheers chaps..
Offline fred-houston
  • COG Membership Officer
  • COG#: 9066
Re: C14 shock
« Reply #1 on: August 16, 2017, 08:53:47 am »
There are several locations and areas where it can be mounted.  On my other C-10 I mounted it on the left side.  On both of them you need to make sure the bracket is far enough out so that it does not interfere with the side panel.
Missouri City, TeXaS
1999 C-10 EFI (Semi Naked)
2016 Yamaha Super Tenere
Offline Pbfoot
  • COG#: 10807
Re: C14 shock
« Reply #2 on: August 16, 2017, 11:31:54 am »
I zip tied mine to the frame on the left side under the seat.  I would start out with the shock set all the way soft which would be counterclockwise.  Ride and adjust as needed. You will be very happy. At 200lbs this shock is perfect for me.
Offline turbojoe78_MA
  • COG#: 8645
Re: C14 shock
« Reply #3 on: August 17, 2017, 08:17:12 pm »
I mounted mine on the left side to the rear foot peg mounting bracket.
At first I just used zip ties, then I made a small bracket to go behind the foot peg bracket so I could mount it with s/s hardware.
Re: C14 shock
« Reply #4 on: November 14, 2017, 03:26:33 pm »
Danny, did you complete your install?
I just finished mine.
I used one of the stock C-10 Swingarm bolts to build my lower bushing.
    (Machined off the head, cut it to length, and drilled a hole thru it)
I mounted my adjuster similar to Turbojoe's install. (On the left side)
I installed a lowering link to keep the height close to stock.
Lastly, I adjusted the preload to set the sag.
So far, it's great.
Re: C14 shock
« Reply #5 on: November 18, 2017, 09:10:31 am »
Yes mate all done ...very happy with it ...just have a problem with sag...I think the adjuster is stuck.can turn the black nob .but it has no effect on the sag...might have to open it up and have a look...is yours a early or late shock...I also have no clicks when turning the nob..
Re: C14 shock
« Reply #6 on: November 19, 2017, 10:03:21 pm »
The adjuster is known to stick on the C-14 shock.
Spray some light lubricating oil under the knob.
My C-14 shock is the early model.
My first clicks didn't seem to have much effect on the adjustment.
As I added more clicks the pressure at the adjuster knob, changed suddenly, as if had finally built up e'nuff pressure to start compressing the spring.  On my C-10, (with C-14 shock) it took 22 - 24 clicks to get the sag correct.
NOTE: I think the C-14 Preload adjustment took more clicks on my C-10 because the C-10 rocker is longer.
          {The longer length might be decreasing the effect of the spring compression?}
From the little I know about the spring on the C-14 shock, I think the spring is a bit too weak as well.
NOTE: I'm new to this. Not sure how the internals of the adjuster are built?
           My assumption is; as you turn the adjuster you move a piston down, to push hyd. fluid?
           If so, mine felt like it was low on fluid.
Hopefully those that are more knowledgeable can correct my guesses.
« Last Edit: November 20, 2017, 02:50:30 pm by connie_rider »
Offline Doc
  • COG#: 12697
Re: C14 shock
« Reply #7 on: November 19, 2017, 11:10:50 pm »
Recently placed an order for a Nitron R1 rear shock from England - will let you know once I receive and install. Planning to send the forks to Traxxion over the winter.
Offline CRocker
  • '02 C10 CDA # 416
Re: C14 shock
« Reply #8 on: December 12, 2017, 09:49:59 pm »
Not really sure what this "winter" thing is that people keep mentioning...suppose it might have something to do with the snow shovels I left in Colorado...oh well...enough time spent on wondering...I'm going for a ride... :beerchug:
Re: C14 shock
« Reply #9 on: December 14, 2017, 01:54:22 pm »
Where did Danny go? Started the discussion then disappeared.
How ya doin' CRoc?
Offline CRocker
  • '02 C10 CDA # 416
Re: C14 shock
« Reply #10 on: December 14, 2017, 03:09:49 pm »
 :motonoises: :beerchug:
in that order...
Offline Jim Snyder
  • COG#: 7055
Re: C14 shock
« Reply #11 on: December 23, 2017, 01:02:23 pm »
in that order...
Are you keeping the "Silverbullet" warm and cozy?
