Author Topic: C14 swingarm  (Read 6268 times)
Offline Wingedspirit
  • COG#: 12707
C14 swingarm
« on: December 29, 2017, 11:21:03 pm »
Has anyone tried to put one on a C10?
Offline gPink
  • MMVIII C XIV
Re: C14 swingarm
« Reply #1 on: December 29, 2017, 11:46:39 pm »
Why?
  • COG#: 12707
Re: C14 swingarm
« Reply #2 on: December 29, 2017, 11:57:11 pm »
Why?
I knew someone would ask that!   :-[   because a C14 wheel will fit on it!  :)
Offline Jim Snyder
  • COG#: 7055
Re: C14 swingarm
« Reply #3 on: December 30, 2017, 02:55:47 am »
Just do the mean streak conversion.
Offline gPink
  • MMVIII C XIV
Re: C14 swingarm
« Reply #4 on: December 30, 2017, 02:03:20 pm »
Why?
:) It had to be asked.
Offline CRocker
  • '02 C10 CDA # 416
Re: C14 swingarm
« Reply #5 on: December 30, 2017, 08:41:14 pm »
Never considered it since the wheels wouldn’t match...
Re: C14 swingarm
« Reply #6 on: December 30, 2017, 09:19:26 pm »
He actually might have a good idea.
Stranger things have happened..
If it fits, I suspect the rocker and shock would also have to fit to keep the suspension ratio's correct.
Offline CRocker
  • '02 C10 CDA # 416
Re: C14 swingarm
« Reply #7 on: December 30, 2017, 10:13:35 pm »
Well, many have adapted a C-14 shock to the C-10...so, I guess the width of the front of the swingarm would be next...heck, I guess my wheels don't match either... :-[
Offline Jim Snyder
  • COG#: 7055
Re: C14 swingarm
« Reply #8 on: December 30, 2017, 11:14:02 pm »
Yeah but your wheels are beautiful and they handle like a dream  !!!!
Other factors would be involved with the C-14 swimgarm would be the drive shaft and front coupling assembly.
Offline CRocker
  • '02 C10 CDA # 416
Re: C14 swingarm
« Reply #9 on: December 30, 2017, 11:35:33 pm »
Yeah...I think there are a lot of reasons not to try it...but, anything’s possible with enough money...and, as cheap as C-14s are...one would have to wonder...
Offline Jorge
  • COG#: 9297
Re: C14 swingarm
« Reply #10 on: December 31, 2017, 06:19:45 pm »
Intriguing...
If width is same, or close enough to adapt, the frame would need additional mods.
The C10 swingarm only has one U-joint, where the C14 has two, one near transmission, one near the hub. The C14 swingarm has extra pivots and links to eliminate shaft-jacking effect, the recipient bike would need strong support points for the links to attach.
If you decide to try it, please take lots of photos, I'm sure I'm not the only one who would like to see it.
  • COG#: 12707
Re: C14 swingarm
« Reply #11 on: December 31, 2017, 09:58:31 pm »
Thanks everyone for your input.  Yes, the measurements would have to be considered very carefully.
The swing arms are available cheaply. I haven't had much chance to do the comparison but wanted to know if it had been done.
Here is an example of what I've done with my Dad. It's an AMC Spirit. It's not a bike but a lot of engineering went into it.
Offline Jorge
  • COG#: 9297
Re: C14 swingarm
« Reply #12 on: December 31, 2017, 10:35:32 pm »
NO WAY!!!
I don't remember any AMC Spirit looking like that. I mean, they weren't a particularly ugly car for the time, maybe even ampng the nicer looking ones, especially the 4x4, but not this...
What's the mechanicals look like?
  • COG#: 12707
Re: C14 swingarm
« Reply #13 on: January 01, 2018, 01:23:35 am »
It's rear wheel drive with an AMC 401 engine. Over 800HP.  I've had lots of guys over the years say it couldn't be done... But we did.
Now let's get a closer look at those swing arm dimensions!
https://www.youtube.com/channel/UCYBaOU6vMsF7Rlaz5xRUJHA
Offline Jorge
  • COG#: 9297
Re: C14 swingarm
« Reply #14 on: January 01, 2018, 04:20:04 pm »
So to bring it around to the original topic... and tying in the "slightly modified" AMC Spirit... it's likely you will not be put off by the required frame modifications  :great:
Re: C14 swingarm
« Reply #15 on: January 01, 2018, 04:35:05 pm »
I just looked at ZG-1400 and ZG-1000 swingarm's on Ebay.
The driveshaft is not arranged the same.
   The 1000 is at/inside the pivot of the swingarm.
https://www.ebay.com/itm/2006-94-06-KAWASAKI-ZG1000-ZG-1000-CONCOURS-SWINGARM-DIFFERENTIAL-FINAL-DRIVE/322953301253?hash=item4b31844d05:g:n6YAAOSwHYpaPWMz&vxp=mtr
   The 1400 is above and outside the pivot of the swingarm.
https://www.ebay.com/itm/2009-Kawasaki-ZG14-ZG1400-Concours-Rear-Swingarm-Differential-End-Bra-08-14-K020/262494799314?hash=item3d1de8c5d2:g:UdcAAOSwbYZXa4wu&vxp=mtr
I think your looking at some major surgery to make this work!
« Last Edit: January 01, 2018, 04:47:56 pm by connie_rider »
  • COG#: 12707
Re: C14 swingarm
« Reply #16 on: January 02, 2018, 11:07:18 am »
Thanks Connie Rider. I've been looking at that too. Not a bolt on for sure.
Thought the project was interesting and wondered what thoughts were out there.  :beerchug:
Re: C14 swingarm
« Reply #17 on: January 02, 2018, 04:01:17 pm »
{I love a project; If someone tells me, that's impossible, or you can't do that... I double my efforts..  >:D}
I don't want to be the naysayer..
Trying to discuss your idea, not kill it...
After looking closely, I just realized the pivot bearing (left side) on both swing arms is inside the driveshaft.
and,, I think the driveshaft/engine coupling "has" to be directly forward of the pivot point.
 ie; {The curvature of the C-14 swingarm makes it look really off, but the driveshaft alignment may not be as bad as it appears.}
Bottom line..     Measurement's/fitting is the only way to determine if it's possible.
  • COG#: 12707
Re: C14 swingarm
« Reply #18 on: January 02, 2018, 10:22:50 pm »
Thanks Ted, I'm like that too.
No worries, never thought anyone was trying to kill the idea.  A swing arm needs to be available to measure and size up.  >:D
I'm really wrestling with it because of time limits but that might just happen soon!
Could always put it away until time permits.
Thanks for your assessment!
Dean
Offline Jorge
  • COG#: 9297
Re: C14 swingarm
« Reply #19 on: January 02, 2018, 11:56:59 pm »
Ted,
I think you're right (I cannot believe I just agreed with you :-[ :-[ :-[)
I think the forward U-joint has to be in a vertical line between the two forward pivots, to keep the joint from being pulled apart or compressed.
  • COG#: 12707
Re: C14 swingarm
« Reply #20 on: January 03, 2018, 02:34:49 am »
We're going to find out guys.
I just could not resist the experiment. I'll get a donor bare frame for mock up too.
Offline CRocker
  • '02 C10 CDA # 416
Re: C14 swingarm
« Reply #21 on: January 03, 2018, 02:41:28 am »
Oh Boy!!!!   ;D
No...wait!  I don't have the money for this... :))
  • COG#: 12707
Re: C14 swingarm
« Reply #22 on: January 03, 2018, 02:58:11 am »
Oh Boy!!!!   ;D
But wait... I do!  :)
Offline CRocker
  • '02 C10 CDA # 416
Re: C14 swingarm
« Reply #23 on: January 03, 2018, 04:06:50 am »
Cool...then I’ll watch!
Offline jacksdad
Re: C14 swingarm
« Reply #24 on: January 03, 2018, 05:46:58 pm »
I love projects like this! Just for the hell of it, or because someone said no, is often enough to make me try harder  :great:
