Author Topic: Educate me please......  (Read 14552 times)
Offline SAS Mayhem
  • COG#: 9199
« on: November 08, 2011, 04:37:31 am »
I'm looking at getting a 17" front wheel for my 06 Connie. The choices are from these bikes
Kawasaki ZR750 C1-C3 (1990-1993)
Kawasaki ZR7/ ZR7S F2/ H1-H5 (2000-2005)
Kawasaki ZX6 D1-D4 (1990-1993)
Kawasaki GPZ1100/ZX1100E (1995-1997)
question, I'm looking on ebay and I have found some wheels "but" what is the differance in the letters? C1-C2 or D1-D4 and so on? Sone of the ones that I have found don't say C1 or D4 ....etc
Cheers
Ron
« Last Edit: November 08, 2011, 07:02:19 am by SAS Mayhem »
COG & AMA Member
06 C10
09 C14
try to live a day without doing one of the 5 D’s....Deny, Defer, Deflect, Discount and Deceit...tougher than it sounds....
Offline GF-in-CA
Re: Educate me please......
« Reply #1 on: November 08, 2011, 04:46:17 am »
The letters indicate a change in the model, i.e., a ZX600C is different than a ZX600D in some way that Kawasaki thought was significant.  The numbers indicate the year of the model, i.e., C1 is the first year of the C model, C2 is the second year, etc.  The C10's are all A's, i.e., A1 thru 20.  Usually the year is good enough when you're buying parts, but some bikes, like the ZX600C and D apparently overlap around 1991, so it is better for that year if you know the letter designation.  Hopefully that makes sense.
« Last Edit: November 08, 2011, 04:53:17 am by GF-in-CA »
Gary F.
1998 ZGX1100
Central Valley California
Offline SAS Mayhem
  • COG#: 9199
« Reply #2 on: November 08, 2011, 12:03:50 pm »
Okay I got it, thanks. I just don't want to grab the wrong front wheel.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline GF-in-CA
« Reply #3 on: November 08, 2011, 02:10:03 pm »
Gary F.
1998 ZGX1100
Offline SAS Mayhem
  • COG#: 9199
« Reply #4 on: November 08, 2011, 03:47:45 pm »
I found a few available on eBay
http://www.ebay.com/itm/91-Kawasaki-ZX6-ZX-6-ZX600-ZX-600-D-Ninja-front-wheel-rim-/260884642726?hash=item3cbdefbba6&item=260884642726&pt=Motorcycles_Parts_Accessories&vxp=mtr
HTH,
Thanks this was the one I was eyeing, too and he has the speed gear too.
Are you referring to the spacer between the bearing or the spacer on the outside?  To my understanding all the spacers on the outside are the same except for the Kawasaki ZR7/ ZR7S F2/ H1-H5 (2000-2005) which has a different p/n. Is this correct?
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline GF-in-CA
« Reply #5 on: November 08, 2011, 03:57:37 pm »
That's correct, the right side spacer is different for the ZR7 wheel.  If the bearings are still in the wheel, you will likely get the center spacer, then it's a matter of finding the right side spacer.  You can buy them new for not a lot of money.
Gary F.
1998 ZGX1100
Offline Dave Scott
  • COG#: 8603
« Reply #6 on: November 08, 2011, 04:09:47 pm »
wow...them guys are pretty proud of their wheels.   :o
Ron, I'll be watching your results closely!  I've already got the 17 rear and going to a 17 front would be nice.   :beerchug:
Offline SAS Mayhem
  • COG#: 9199
« Reply #7 on: November 08, 2011, 04:11:03 pm »
Ok so, if I get the wheel that I am eyeing, then the spacers(outside) will work correct?
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline SAS Mayhem
  • COG#: 9199
« Reply #8 on: November 08, 2011, 04:13:02 pm »
Yeah!!! Ditto, some of those sellers are nuts.  Even for damaged wheel there what a arm and a leg.  I'll let you know how everything goes.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline GF-in-CA
« Reply #9 on: November 08, 2011, 05:44:01 pm »
Cheers
Ron
I'm not sure I understand your question, but if you're asking if the Concours spacer will work, then the answer is no, the ZX600 spacer is a little longer than the Concours spacer.  You will still need to get the right side spacer (and the speedo drive) for the ZX600 (or GPZ1100) for the wheel to fit.  The Kawasaki part number for the spacer is 92143-1335, and is about $11 from Ron Ayers.  With the ZX600 spacers and speedo drive, the overall width of the spacers, wheel bearings, and speedo drive is the same as the Concours.
HTH,
Gary F.
1998 ZGX1100
Offline GF-in-CA
« Reply #10 on: November 08, 2011, 05:47:08 pm »
Just in case you're not aware of it, here's what's required to install the 17" wheel as Ron is doing.  It's a matter of getting the right wheel, and it all fits with no modifications.
http://cog-online.org/clubportal/ClubStatic.cfm?clubID=1328&pubmenuoptID=35748
Gary F.
1998 ZGX1100
Offline Dave Scott
  • COG#: 8603
« Reply #11 on: November 08, 2011, 05:59:24 pm »
Thank you, Gary!!!
Offline SAS Mayhem
  • COG#: 9199
« Reply #12 on: November 09, 2011, 02:51:59 am »
Cheers
Ron
HTH,
Super I get it now,  ;D also thanks for posting the link. I brain farted.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline GF-in-CA
« Reply #13 on: November 09, 2011, 03:12:42 am »
Cool.  If you have any more questions, let me know, otherwise, have fun!   :motonoises:
Gary F.
1998 ZGX1100
Offline SAS Mayhem
  • COG#: 9199
« Reply #14 on: November 10, 2011, 01:23:52 pm »
Thanks Gary I'll let you know if I have any other questions.  I just ordered the wheel,speed drive and spacer.  'll be ordering my tires next month, I might go with BT's, so far I'm undecided.
Sport Rider, I'll keep you in the loop too.  The main reason I'm going to 17" is availability. When I first needed to get tires for my Connie, I call every cycle shop within 50 miles of my house.  The only place that had them was a Kawasaki dealer, but they were the OEM tires, which I did'nt want.  All other places had to order them (AVON). I ended up getting them from http://www.compacc.com/index.cfm faster and cheaper than all the places I looked at .  So I thought since I ride a lot (everyday) and in the mountains it would really suck to have a cruise cut short waiting for tires. Soooo hence the reason for the 17" upgrade.  Every time I go into a cycle shop they all had 17" tires and at least 3-4 different makes.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline Dave Scott
  • COG#: 8603
« Reply #15 on: November 10, 2011, 02:22:22 pm »
Thanks Ron.  For me it's because I have a sportbike that runs 17s.  I have several tires from it that I used on the track.  Since they still have good tread for street use, I can run them on the connie, which I use as my every-day ride.
Offline GF-in-CA
« Reply #16 on: November 10, 2011, 03:50:06 pm »
Great, sounds like you're all set.  One thing I'm not aware of anyone doing yet is to mount a different fender with the 17" wheel.  The C10 fender leaves a lot of room between it and the tire, and looks a little funny.  I think a ZR7 or ZX600 fender might fit, but so far I don't think anyone has tried it.
Gary F.
1998 ZGX1100
Offline SAS Mayhem
  • COG#: 9199
« Reply #17 on: November 11, 2011, 01:20:39 pm »
Thanks for that info, I'm going to shoot the seller of the wheel I got and ask him to check. I'll keep you posted.
Cheer
Ron
COG & AMA Member
06 C10
09 C14
Offline SAS Mayhem
  • COG#: 9199
« Reply #18 on: November 16, 2011, 07:43:28 pm »
Well so far I got everything, sans the wheel.  I have a set of bearings and seals from my OEM wheel set up,(I believe that there the same size) If so I'll put them in, and I'll need to strip and paint the wheel too. I want it purty.  Next month I'll be doing the swap after I get my new tires.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline GF-in-CA
« Reply #19 on: November 16, 2011, 07:57:33 pm »
Yes, the bearings and seals are the same, so you should be good to go.  As for painting, I used Duplicolor wheel paint, and am very pleased so far.
Gary F.
1998 ZGX1100
Offline SAS Mayhem
  • COG#: 9199
« Reply #20 on: November 17, 2011, 05:05:12 am »
Thanks for that info, I really want to paint my bike Fred. But dang !!! I don't get down time on her. In the last 18 months I've put 30,000 miles on her. I do preventive maint, and roll..... she never skips a beat.  I'm praying for some serious snow and ice to get her off the road. LOL
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline Dave Scott
  • COG#: 8603
« Reply #21 on: November 17, 2011, 02:53:22 pm »
Cheers
Ron
Hold on there a minute.....let's not get carried away!!!   ???
Offline SAS Mayhem
  • COG#: 9199
« Reply #22 on: November 17, 2011, 03:17:06 pm »
LOL, I hear you my friend ....just enough to keep me off the road for 5 days, which here in NC, is about 1/32 of a inch to paralyze this state.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline Dave Scott
  • COG#: 8603
« Reply #23 on: November 17, 2011, 03:40:32 pm »
lived near Charlotte for 12 years now.  I know of what you speak!   :))
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
« Reply #24 on: November 22, 2011, 08:12:52 pm »
I am about to join the group. 17" Front wheel is on its way!
Now I have to find a 17" rear!
Is Kosman and or a mean-streak rear the only options???? anyone?
