Author Topic: Emulators and fork cap????  (Read 659 times)
Offline 2qwk4u442
« on: November 07, 2018, 12:46:14 pm »
Need some help from the suspension pro's here :)
I'm rebuilding the forks on a 2000 C10, Im adding emulators & springs (1.0kg) from racetech. New bushings seals & wipers. While working out the measurements for cutting the spacers and looking over the fork cap-. I'm totally confused.
There is the threaded centerpiece that passes thru the cap, and has the marks on it. What does this do? Even in stock configuration it doesn't look to engage or touch anything inside the fork? I would have guessed this to be for preload adjustment.
Furthermore, with the new components including the spacers- it again would seemingly look to do nothing.
I attached a photo of Racetech descriptions of different style caps, what do we have on our C10's???
Re: Emulators and fork cap????
« Reply #1 on: November 07, 2018, 01:12:25 pm »
Looks to me like it's D.  The fork cap does allow for setting preload.  The threaded portion in the center pushes on the washer that sits atop the fork spring.  Hope that helps.
« Reply #2 on: November 07, 2018, 01:13:14 pm »
Fixed that for ya.
Offline GeorgeRYoung
« Reply #3 on: November 07, 2018, 01:32:47 pm »
2 cents worth on emulator install:
http://web.ncf.ca/ag136/forkUpgrade.htm
Offline 2qwk4u442
« Reply #4 on: November 07, 2018, 02:08:33 pm »
I would have thought D as well, but the "adjuster" doesn't contact the washer. They are the washers supplied with racetechs springs for this bike. The thru hole on the washer is bigger than the outside diameter of the "adjuster".
The spring & washer contact the cap as shown in version A.
Picture attached is the caps, minus the sealing o ring.
« Reply #5 on: November 07, 2018, 02:22:15 pm »
2qwk4u442, I'll agree that it's "D".
I think the washer you received with the springs,,,,   goes between the spacer and the spring.
I think the correct stack is; emulator/spring/new washer/spacer/thrust washer/cap w/adjuster...
When you removed your caps, there should have been a "thrust washer" on top of the spring that the adjuster pushes against.
It has a small hole in the center....
It has to be reused as it allow's the adjusters to "adjust" the pre load.
An EZ way to determine the correct length would be to set the new {emulator/spring/washer/spacer/thrust washer} stack beside the old spring and thrust washer.
The finished length should be the same, but DO consult Race tech for additional information..
Adjust your spacer as needed to get the correct length...
Offline 2qwk4u442
« Reply #6 on: November 07, 2018, 03:26:10 pm »
My understanding is the same  except I know nothing of a thrust washer.(emulator/spring/washer/spacer/washer/cap)
Big K diagram shows a washer as well, but I thought that one was the same as what Racetech supplied. (At work now, can't check)
Offline 2qwk4u442
« Reply #7 on: November 07, 2018, 03:28:53 pm »
That would make sense,....
Offline 2qwk4u442
« Reply #8 on: November 07, 2018, 03:38:58 pm »
Is this what the 'thrust washer' looks like???
This was not in my bikes fork.
I suppose a previous owner coulda screwed up and left it out, but everything else I've disassembled with the forks looked original and normal.
« Reply #9 on: November 07, 2018, 03:56:02 pm »
Yepp, that's it.
A substitute could be figured out if you can't get another.
Offline 2qwk4u442
« Reply #10 on: November 07, 2018, 03:58:12 pm »
Crazy that wasn't there!  I can order it from partszilla. Wow! Thanks!
« Reply #11 on: November 20, 2018, 02:53:44 pm »
Did you solve the problem?
