Author Topic: Factory shock rebuild.  (Read 2492 times)
Offline Shrekster
« on: May 14, 2018, 12:07:07 pm »
Hi,
Is it possible to buy spares to rebuild the standard rear shock? Mine is leaking and the bike is now very bouncy at the rear, this would indicate it has lost some or all of it's oil.
Are there any suppliers that sell a replacement seal kit?
I realise that an aftermarket shock would be better but I'd like to keep the bike as standard as possible.
Regards,
Jim.
'93 C10 Concours, '05 Fazer 1000, '03 Goldwing 1800, '12 Honda Crosstourer.
Offline RWulf
  • COG#: 7122
Re: Factory shock rebuild.
« Reply #1 on: May 14, 2018, 12:35:23 pm »
I have not read anything about rebuilding the factory shock. I will bet
you can fine one from someone here on the forum. If you do you can
always get Murph's oil replacement kit and change the oil.
« Reply #2 on: May 14, 2018, 12:41:56 pm »
Regards,
Jim.
   Very nice thought but the oem shock was pretty limp!! Many yrs ago I went to an after market shock and never looked back!!
                  https://www.murphskits.com/product_info.php?cPath=1_97&products_id=85&osCsid=60vAzuArD6BbXADn7n3qm0
Offline Bob H
  • COG#: 788
« Reply #3 on: May 14, 2018, 12:52:03 pm »
If you are determined to fix your factory shock, try one of these, or make your own:
https://www.ebay.com/p/Motion-Pro-080356/1237253777?iid=390579426324&chn=ps
Several years ago the rear shock on my '88 started leaking. I used a piece cut from a plastic milk jug to clean the seal lip.  Been completely leak free for probably 10 years now.
Cut a piece of milk jug or other thin soft plastic about 1/8" to 1/4" wide at one end, wide enough to grip on the other end.  Insert the small end between the seal and the metal surface of the shock.  Wipe all the way around the shock a couple of times, pulling the thin end out as you go to wipe out any dust or other crud that may be holding the seal away from the metal body.
Cheap, easy, and although there's no guarantee, at least in my case, it saved the shock.
Still not a bad idea to replace it with a better aftermarket one!   ;D
 '88 one owner:
« Reply #4 on: May 14, 2018, 04:35:56 pm »
Sorry, I threw my stock one out. I didnt think anyone would actually want one of those things..
Aftermarket is so much better. When new they were not to good to begin with.
Offline antibus
  • COG#: 11339
« Reply #5 on: May 16, 2018, 04:19:44 pm »
I just had my factory shock rebuilt with RaceTech Gold Valves, re-sprung and a NTG bolt installed to make it serviceable. A guy out of Idaho did it for me. It works well.
CDA #0542
Offline worncog
  • COG#: 9584
« Reply #6 on: May 16, 2018, 04:54:24 pm »
Would that be Norwest?
RWTW, COBDR, SM 500, BVF...
Offline antibus
  • COG#: 11339
« Reply #7 on: May 17, 2018, 01:19:10 am »
It was by a guy named Jay, owner of Adventuredpowersports.uis and "sasquatch suspension??". He did a spectacular job on my Vstrom 2 years ago and after asking him about my concours we decided to give it a try. He has not worked on a concours before, and the suspension feels great (Just like my Vstrom) and I am very happy with the product.
CDA #0542
Offline Akumu
« Reply #8 on: May 17, 2018, 09:18:24 am »
How much did this service cost? Turn around time?
Offline Egodriver71
  • I'm in here somewhere
  • COG#: 8321
« Reply #9 on: May 17, 2018, 10:26:00 am »
Is this about the C10 or C14?
Thomas Mann
Jacksonville, FL
COG #8321
Offline JDSCO
  • 2016 C14
« Reply #10 on: May 17, 2018, 12:33:11 pm »
I have my 2016 C14 oem rear shock, >1year old, if your interested?
Gen James Mattis
Offline antibus
  • COG#: 11339
« Reply #11 on: May 17, 2018, 02:30:06 pm »
Good point. Mine was a 2012 C14. It cost $450 parts and labor. It took about 2 weeks because the wrong springs for the forks were initially shipped.
CDA #0542
Offline Steiny
« Reply #12 on: May 18, 2018, 02:58:23 pm »
http://daughertymotorsports.com/
 Call Daugherty Motorsports ,  He can rebuild them .
 He rebuilt and re sprung mine
Offline Shrekster
« Reply #13 on: May 23, 2018, 09:58:24 am »
OOPS! I've just realised this post is in the wrong section. It should be in the C10 suspension section. Apologies for that.
Jim.
Offline worncog
  • COG#: 9584
« Reply #14 on: May 23, 2018, 05:51:48 pm »
Sooo, this would be a shock question IRT a 93 ZG1000?  For clarification.
« Reply #15 on: May 23, 2018, 06:00:05 pm »
Why rebuild a  crappy shock when for less money you get a really good (valved shock- not an emulsion tube shock)  AND a new heavier spring.
  The stock  C10  (shock and spring) AND the C14 (shock )are cr@p. If your putting a C14 shock on a C10 the spring will be too soft and your sag too great.
The product below is for a C10:
https://www.murphskits.com/product_info.php?cPath=1_97&products_id=85&osCsid=WvVjkHtEHnqAhTljPJxTK2
Offline who me?
  • COG#: 11932
« Reply #16 on: May 23, 2018, 11:23:29 pm »
I did this along with new progressive springs up front Straight out of the box The Mule rides/handles better than it has in years
95 C10 The Mule
02 C10 parts are parts
Offline Boomer
  • Me dwarfing Vivian
    • Boomers GTR Site
« Reply #17 on: May 24, 2018, 08:34:14 pm »
Yup, OEM shock is not worth it.
Plenty of aftermarket options out there, plus a used ZZR1200 or used C14 can be adapted to fit the C10.
Mine has the ZZR shock and it copes with my vastness admirably. :)
George "Boomer" Garratt
Wickford, UK
CDA-007
Offline worncog
  • COG#: 9584
« Reply #18 on: May 25, 2018, 01:26:58 am »
The ZZR shock is a 'good' upgrade for the price, but it is much better with a spring upgrade also. Stock rate is ~725lb/in. I was running an 800 but it was stiff for my 175 and luggage. Will be trying a 750 soon.
Offline CaffeineMan
  • In the shadow of the Valley of Death
  • COG#: 7763
« Reply #19 on: May 26, 2018, 11:11:05 pm »
Another vote for the Progressive 465 rear shock.  With that and Race Tech fork springs and emulators, my C-10 handles wayyyyy better than stock.
"You put antiseize on those, right?"
01 C-10 Sonic Blue ("Old Blue") - Touring by Sport Touring:  Progressive 465 rear shock, Race Tech emulators and 1.0 springs, EBC rotors, Nissin 4-piston calipers, Spiegler hydraulic lines, Russell Day-Long saddle, Cee Bailey windshield.
17 C-14 Candy Imperial Blue ("Baby Blue") - Sport by Sport Touring
Offline Yamahawk
« Reply #20 on: May 30, 2018, 01:48:03 pm »
I have a ZZR1200 shock adjuster on a ZX-9 shock, so I could get adjustable damping and hydraulic preload adjustment too. I need a stiffer spring, what do you think about the spring rate for the C-10 with this setup? 750 lb/in isn't how they sell springs, they do it in Kg's. What would this equate to in Kg's? I have a set of Sonic fork springs on the way 1.1 Kg. so I am thinking about re-springing the rear now.
Anyone know what the spring rate should be for the C-10 rear using this setup? Thanks!
Charlie
All Things work together for good, for those who Love God, and are the Called according to His Purpose. - Romans 8:28
The Only Thing Necessary for Evil to Triumph...
Is for Good Men to do Nothing - Edmund Burke
Offline worncog
  • COG#: 9584
« Reply #21 on: June 21, 2018, 01:34:47 pm »
Charlie
Sorry for the delay, I was riding to Alaska. Anyhow. I do agree that the typical measure is in Kg/mm, but the Eibach springs do come in lb/in ratings, as I have a 800 installed and now a 750 sitting on the bench waiting to be installed, specifically the 0800.225.0750. I don't claim to be an expert, but these are the springs I have used on both my C10 and Super Tenere.  YMMVhttps://www.amazon.com/gp/product/B000QJGVMQ/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
The 800 is a bit stiff without any load and I believe is overriding the rebound damping of the ZZR1200 shock. I think the 750 will be a better fit for me.
Offline Yamahawk
« Reply #22 on: June 25, 2018, 12:39:52 pm »
+1 on Jamie Daugherty, he is a great fellow and knows his business. I had talked to him about the stock shock, and my ZZR1200/ZX9 hybrid. He said no problem on either of them. Essentially, the ZX9 shock body is all he will re-use, and the guts will all be changed out. On the stock shock, pretty much the same, different valving, and new spring. It won't be as good as an aftermarket, but way better than when it was stock. Now, the ZX9 hybrid, WILL be WAY better than stock, and comparable to a high end aftermarket ($$$) shock. HE said he could lengthen it with a new shaft also. if needed.
Charlie
Offline Shrekster
« Reply #23 on: September 02, 2018, 09:00:58 am »
Just a wee update, I decided to go with a Wilbers rear shock. German made, all in house manufacture, very high quality, way too nice to hide away under the bike! I opted for their mid spec unit with a single adjuster that controls both the rebound and compression damping.
I emailed them 'my' spec, i.e. my weight and riding style, waited about 3 weeks for it to arrive as they are made to order.
I've covered about 1500 miles so far and my initial impression is, it's fantastic, perfect spring rate for my weight and the damping adjuster allows me to soften the rear end a little when touring on the bumpy back roads we have here in the more rural areas of Scotland. When on normal roads I can turn the adjuster back to standard and ride the bike at higher speeds in comfort.
I just need to look at doing something with the front end now.
Here's a link to the model of shock I bought- https://www.wilbers-shop.de/en/Motorcycle/Kawasaki/GTR-1000-ZGT00A-wilbers-19/shock-absorber-type-640-Road.html?manufacturer=tp0b6613ff139775672bedb42c6eadbd&year=1994&catname=50c38707c61f0f1172a38063e002187e
Slange
Jim.
