Author Topic: Fork oil to use with Sonic 1.2kg springs  (Read 1691 times)
Re: Fork oil to use with Sonic 1.2kg springs
« Reply #25 on: December 25, 2018, 07:56:42 pm »
Thanks Mike. My assumption was the greater force of the stronger spring,,, {pushing the shock back up}, took higher weight oil to control that movement??
Sad to say but I'm just learning about Damping.   :-[
After all these years of riding, I thought I knew how to set the damping/sag...
Recent reading/study and experiments with my C-10- have been enlightening.
ie; Boy was I dumb..
For one, after a shock install, I set the sag on the rear and thought it better.
Last week I checked the rebound, and it was way off. {too much damping}
It was very slow to move up.
Took 1 full turn open to get it close to right, and I realize I'm only close.
{NOTE: My C-10 has a C-14 shock and Norm's Lowering Rocker}
Currently installing an Emulator in the forks after cutting 4" out of a Progressive {brand} spring.
With that mod, decent Sag settings are now possible.
Will find out if I'm close to the correct damping settings, after the holidays.
I have no idea what I'm doing, but I'm having fun trying...
PS: I still have no aftermarket suspension for the C-14. {Remember, I'm poor}.
      After I play more with the C-10,  I'll see if I can get any improvement on the C-14 from doing adjustments.
« Last Edit: December 27, 2018, 02:10:52 pm by connie_rider »
