Author Topic: Front end feels like riding on gravel  (Read 1081 times)
Offline m in sc
    • 2strokeworld.net
  • COG#: 13057
Re: Front end feels like riding on gravel
« Reply #25 on: June 14, 2019, 05:08:21 pm »
id fire up the dremel if i was in your boat. will take 10 minutes. even if you nick the wheel bearing surface, it wont actually hurt anything. If you were local we'd have that done yesterday for a handshake. and possibly a jelly donut.
« Reply #26 on: June 14, 2019, 05:21:45 pm »
If you choose that path, be extremely careful, wear protective gear, and face shield during process..
having Dremmel'd and cut bearing cups, cones, and races like that in the past, I can say they are extremely "brittle", and if "struck" like with a chisel, after cutting part way thru, glass like shards will penetrate skin.. bd/dt... got the scars...  :-\
be safe.
