Author Topic: front fork  (Read 2171 times)
Offline Butch
  • COG#: 9220
front fork
« on: July 01, 2009, 07:51:00 pm »
the correct front fork oil amount for 2001 concoursText
Offline Slybones
  • COG#: 6953
front fork
« Reply #1 on: July 01, 2009, 08:30:00 pm »
for stock springs, 170mm measured from the top of a fully compressed fork with NO spring.    If you have aftermarket springs, follow the recomended level by the spring MFG. Generally 150mm. measured from the top of a fully compressed fork w/o spring.  2003 Concours, 52K  COG #6953  IBA 28004  http://mysite.verizon.net/slybones/Concours/connieMain.htm
2003 Concours, 121K
2005 GL1800ABS, 52K
COG #6953, IBA 28004
Offline Butch
  • COG#: 9220
front fork
« Reply #2 on: July 01, 2009, 09:00:00 pm »
thanks for information, I'am been working on a friends 2001 and the service manual is pretty unclear about the amount of oil, Butch
Offline Slybones
  • COG#: 6953
front fork
« Reply #3 on: July 01, 2009, 11:11:00 pm »
just fyi for any one who doesnt know.       Measure from the top on a fully compressed fork, with no spring means....    You remove the spring, compress the fork all the way down. Partially fill the fork. Work the fork up and down some fill the passage ways at the bottom. compress fork all the way down, fill to 4 inches or so from the top of the tube. Then remove oil so that you have "170mm" of air at the top of the fork.     This is not the amount of oil you add. Its the amount of space you leave at the top of the fork. -- When the fork is fully compressed and has no spring in it.     then you lift the front end up so the forks are fully extended. now there is a lot of space in there. Add the springs, reassemble, etc.    Make sure to set the preload, by measureing the 'sag'.   http://www.sonicsprings.com/catalog/setting_sag_street_tech_article.php    Anyting else from the group?    2003 Concours, 52K  COG #6953  IBA 28004  http://mysite.verizon.net/slybones/Concours/connieMain.htm
« Last Edit: July 02, 2009, 02:12:00 am by Slybones »
2003 Concours, 121K
2005 GL1800ABS, 52K
Offline Charlie_Gary_AAD
  • COG#: 8048
front fork
« Reply #4 on: July 04, 2009, 12:05:00 pm »
Slybones asked "Anyting else from the group? "      Now that I have drain screws on my fork legs, I have every intention of writing down how much oil each fork gets the next time I change it.  I think it will be much easier for me once I know how much to measure and pour in, as opposed to setting up an oil sucker.
Later,
Charlie - NWAAD
COG# 8048
AMA# 603377
Re-defining the phrase "Rides like a grandpa"
Offline Paulie
  • COG#: 4561
front fork
« Reply #5 on: July 06, 2009, 02:57:00 pm »
I added 12oz. I figger that's ~140mm, usin Sonic 1.1s FWIW.     01 Conc, Mijami Floriduh  OTP 06: http://tinyurl.com/2vk9o2 route map: http://tinyurl.com/4p7pmd
« Last Edit: July 10, 2009, 10:03:00 am by Paulie »
