Author Topic: Inexpensive Fork Emulators?  (Read 1087 times)
« on: December 18, 2018, 04:08:14 pm »
In another discussion about Race Tech Emulators someone posted these "damper valves" as an inexpensive alternative to Emulators.
The guy, "said" they will fit in the C-10's, he installed some, and they work the same as Race Tech..
   {Trying to find his posting again}..
Has anyone used them or know anything about them?
Did a little research: I think their a Chinese copy of the Race Tech's, but they are not sold as coming from China?
                              The spring in these is compatible {in force} to the Race Tech {Blue Spring} and the Dampers seem to be a similar
                                design to the Emulators.
NOTE:  The original Ebay posting had these in the $49 range {plus shipping}.
             I found them for $39 {plus shipping}.
Original posting;
https://www.ebay.com/itm/41mm-Fork-Damper-Valve-For-Harley-Davidson/232561612278?epid=671622052&hash=item3625c095f6:g:7BoAAOSw6VRaCsDu:rk:6:pf:0
$39 Posting;
https://www.ebay.com/itm/41mm-Fork-Damper-Valves-TC-88-Softail-Touring-Dyna-FXST-FLST-FXDWG-FLT-2000-UP/172661938134?epid=671622052&hash=item28337417d6:g:q48AAOSw2GlXD-PA:rk:8:pf:0
If you own a Harley in GB $96;
https://www.ebay.com/itm/41mm-Fork-Damper-Valve-For-Harley-Davidson/232871663568?epid=9010350188&hash=item36383b97d0:g:J9EAAOSwoVNaIUnh:rk:9:pf:0
PS: Ignore the Harley part.  :rotflmao:
« Last Edit: December 19, 2018, 06:00:35 pm by connie_rider »
Offline GeorgeRYoung
Re: Inexpensive Emulators?
« Reply #1 on: December 19, 2018, 01:05:01 am »
I used the knock-offs in a Suzuki SV650, worked like a charm.
http://web.ncf.ca/ag136/SV650/forkEmulators.html
« Reply #2 on: December 19, 2018, 04:35:17 am »
Thanks George.
I just ordered a set. Will give them a try.
Any extra suggestions?
« Reply #3 on: December 19, 2018, 01:15:37 pm »
. . . Any extra suggestions? . . .
Ah, yes.
The extra damper rod holes go above the existing ones, see:
http://web.ncf.ca/ag136/forkUpgrade.htm
And a ton of extra suggestions for other modifications here:
http://web.ncf.ca/ag136/frameindex.htm
Offline m in sc
« Reply #4 on: December 19, 2018, 05:40:46 pm »
have used them in an rz350 and an rd, and a kawi triple. no complaints at all. have real racetech gold valves in another bike, cant tell the difference performance wise one bit from original to knockoff.
Re: Inexpensive Fork Emulators?
« Reply #5 on: December 19, 2018, 06:16:31 pm »
Thanks for the replies.
George, over the years I have made similar changes to my C-10's as you did.
M in SC, your reply goes a long ways in making me feel the inexpensive version is worth pursuing.
Last night I read this as I wanted to {really} understand how Emulators work.
Takes a bit of thought to understand the details of each phase,, but makes sense.
http://www.racetech.com/HTML_FILES/DampingRodForks.HTML
« Reply #6 on: December 20, 2018, 08:03:27 pm »
The Damper valves {Emulators} arrived last night.
Unfortunately they did not supply any instructions at all, so I sent a note requesting some..
It's an EZ install, so I'm using the knowledge I gained here to do the install.
ie; Drilled additional 3 holes in the disc and set the pre-load to 2 turns. {per Steve Sefsick's settings}
              Came with 1 hole and 3 turn setting.
Hope to do the actual install tomorrow.
Offline danodemotoman
  • COG#: 2877
« Reply #7 on: December 20, 2018, 10:03:19 pm »
 Made order for the V65 Sabre!
« Reply #8 on: December 21, 2018, 05:11:11 pm »
  • COG#: 2877
« Reply #9 on: December 23, 2018, 11:53:27 pm »
 Was not sure but a search shows the V65 Sabre has 41 mm forks.
« Reply #10 on: December 24, 2018, 04:20:21 pm »
Ahh, "now" I understand.
  You ordered a pair of these to install in a V65 Sabre.
The holidays slowed me down.  My forks are apart and mods made, Emulators are drilled and adjusted.
  Will put it all back together sooner or later.
« Reply #11 on: January 26, 2019, 05:59:21 pm »
Decided to post an update.
The inexpensive {$50} emulators I bought ended up being almost identical to the real deal.
Installation was EZ, but a little time consuming.
I've  done some rides with them and can feel the improvement.
Bottom line; The project worked out great...
                     I'm pretty impressed by these as they are set now..
                     But {being me}; I still have in mind doing some adjusting to see if I can get an even better ride.
                     In all honesty though, I'm not sure I have the sensitivity to feel any little bit of improvement I might get.
  • COG#: 2877
« Reply #12 on: January 28, 2019, 06:30:21 am »
 Mine which arrived a few weeks ago but not yet installed on the V65 sabre only came with the installed spring.
 The original emulators of which I installed in a Connie several years ago came with three springs of different weight ratings.
« Reply #13 on: January 29, 2019, 01:03:04 am »
The spring on these are the same as the 40* blue spring.
I added 3 additional holes in the piston {ie; now have 4} and my emulator spring preload is set at 2 turns.
Also increased size and number of holes in lower damper rod.
Fork oil is ATF {approx. 15 wt}.  Oil level set at 6 1/4".
NOTE: Steve S. posted these settings when he installed Gold Valve Emulators on his bike.
« Last Edit: January 29, 2019, 03:34:43 pm by connie_rider »
Offline bajasam
« Reply #14 on: January 29, 2019, 02:59:24 pm »
is there going to be a diy video forthcoming on your mod/instal..........?
« Reply #15 on: January 29, 2019, 03:29:52 pm »
Sorry. Will not be a video from me. Computer illiterate...
Weather was great, so we went on a 200 mile ride yesterday.
The front springs of my bike have been cut 4" to stiffen them, and preload is set on them at about 35mm.
Replaced that 4" with a PVC Spacer.  {I later cut 3/4" from that spacer to allow for length of the Emulator body}
Even with these stiff settings, the front end absorbed the small bumps better than ever..
I think I'm going to increase my preload on the emulator's to 3 turns in. {to prevent front end dive under hard braking}
« Last Edit: January 29, 2019, 03:37:37 pm by connie_rider »
  • COG#: 2877
« Reply #16 on: January 29, 2019, 09:21:55 pm »
  Ted,
 Remind us on oil level settings.
 Forks compressed with springs out ??
« Reply #17 on: January 29, 2019, 09:31:41 pm »
Correct.
I think stock is 6 3/4", and Race Tech recommends 5.9" with the Gold Valve Emulator.
Offline bajasam
« Reply #18 on: March 13, 2019, 04:43:04 pm »
OK, I got my cheap Taiwanese gold emulators, sonic 1.2 springs,seals etc. Do you still reccomend drilling the 3 extra holes on the emulator valve(mine only has one hole currently),did you go to 3 turns in on the spring?,are you still using ATF or have you changed to 30-40w? Thx
Offline bajasam
« Reply #19 on: March 21, 2019, 02:47:51 pm »
Son of a gun, I guess I've offended someone else, so I'll answer my own question now that I'm done. Man these emulators and 1.2 sonic's give the ole c10 a newer more fit personality.If a 150 dollar investment in your bike is not overly rich,it is well worth the time and money, especially if your pulling forks for seals and bushings anyway. I did go with 4 holes in the emulators,6 holes in the dampeners,drain holes and 20w, along with gaiters.Quite the pleasant surprise now when you grab a handful of brake at 70mph, no more feeling like she's trying to buck you off over the handlebars. Thx again coggers for another great idea.
« Reply #20 on: March 21, 2019, 05:19:30 pm »
Ray, I don't think you offended anyone.  Ted just hasn't been around much lately.  Don't know what he's been up to.  Maybe he's busy with over the pond.  Or maybe  >:D  Harry is working him over with the flog-o-matic! ;D
« Reply #21 on: March 23, 2019, 11:48:24 pm »
Yupp, I've been away. Sorry for the late reply. Stupid computer!!!   :33:
Yes: I added 3 holes to the valve.
           Don't recall exact size, but slightly smaller than the original 1 hole.
       Original 2 holes in the dampner rod are now 6 (5/16" dia) holes.
       I used ATF {10-14wt}, set level at 6 1/4" from top {with forks collapsed}.
        Spring preload is still set at 2 turns.
         {Bike still dives a bit more than I want during hard braking.
                Think I will eventually change to 3 turns, or increase fluid wt to improve that}.
       Will try to find my other posts and attach here...
          NOTE: I used settings recommended by Steve Sefsick.
« Last Edit: April 03, 2019, 01:52:33 pm by connie_rider »
« Reply #22 on: April 03, 2019, 12:57:38 pm »
Bajasam, did you ever complete your install?
Offline bajasam
« Reply #23 on: April 03, 2019, 01:37:27 pm »
Yessiree, finished it a few days before you had responded,  followed your basic recipe and it made a huge improvement for the better. I also used the cheap 37 dollar emulators you recommended from ebay, they came from some small Harley shop and had made in taiwan on the package but were seemingly exact copies of the racetech's.
« Reply #24 on: April 03, 2019, 01:54:31 pm »
Great!
Others, go back and read thru this discussion if your wanting to improve your C-10's front suspension on the cheap.
It works......
