Author Topic: Progressive 420 install  (Read 1644 times)
Offline John_Atkinson
  • COG#: 5921
« on: September 22, 2011, 12:27:39 pm »
Anyone have any hints or tips on the install of a PS 420 rear shock?
I acquired low-mileage used unit (thanks JM!) but would welcome any suggestions regarding installation, settings, etc.
thanks in advance!
John Atkinson
Windsor, ON
CANADA
COG #5921
  • COG#: 5921
Re: Progressive 420 install
« Reply #1 on: September 27, 2011, 11:35:00 am »
nothing from anybody?
John Atkinson
Windsor, ON
CANADA
COG #5921
Offline Greg
    • Means Racing
  • COG#: 9702
« Reply #2 on: September 27, 2011, 01:38:31 pm »
Never done one, so how about you send it to me, and i'll do the dirty work, then send it back in a year or three and give you all my data.
 8) ?
 :beerchug:
Greg Means
Garden Valley, CA
98 Windsor Green Concours
40K & counting
K&N, Bar Risers, Ram Mount, 12v Power Outlet, Avons - 55/46
92 Candy Red Aspencade
32k
Stupid Happy to be riding again!
COG# 9702
Offline GF-in-CA
« Reply #3 on: September 27, 2011, 02:34:31 pm »
John,
I've never done one, but since it is made for the C10, it should be a bolt-in, so nothing special for the install.  Setup is more personalized, and depends on your weight and riding style.  There are some good suspension setup guides on the web to help, like this one:
http://www.sportrider.com/suspension_settings/suspension_setup/146_0402_suspension_setup_guide/index.html
HTH,
Edit:  Have you seen Progressive's installation instructions?  Here are the instructions for the 465 shock, which has superseded the 420, so it they should be basically the same.
http://www.progressivesuspension.com/pdfs/3082%20465%20Series%20Install%20Instr.pdf
« Last Edit: September 27, 2011, 02:49:54 pm by GFinCA »
Gary F.
1998 ZGX1100
Central Valley California
  • COG#: 5921
« Reply #4 on: September 27, 2011, 03:01:06 pm »
 8) ?
 :beerchug:
um......well, Greg, that's AWFULLY good of you to offer...... :rotflmao:
Not quite the intended result I had in mind, though..........
John Atkinson
Windsor, ON
CANADA
COG #5921
  • COG#: 5921
« Reply #5 on: September 27, 2011, 03:26:34 pm »
John,
HTH,
this is great information Gary - thanks so much!
John Atkinson
Windsor, ON
CANADA
COG #5921
