Author Topic: Lowering Link with Progressive Rear Shock  (Read 134 times)
Offline Ianz5150
« on: February 08, 2019, 08:30:55 am »
Does anyone know if the Soupy's lowering links or with the  Norm Sourcy lowering block, work with the Progressive 465 rear shock that Murph's sells? I tried to mine some intel with a search but failed.
Offline Jim Snyder
  • COG#: 7055
Re: Lowering Link with Progressive Rear Shock
« Reply #1 on: February 08, 2019, 04:54:57 pm »
If the shock is made specific for the C-10 it should work with the rocker for sure. The Soupy's links are dependent on the design of the aftermarket shock. If it looks similar to the stock shock then the Soupy's links will work.
Offline Ianz5150
« Reply #2 on: February 08, 2019, 09:52:56 pm »
Thank you for that information. I'll probably try and get my hands on a lowering block and go ahead and order a shock from Murph's place.
« Reply #3 on: February 08, 2019, 10:26:13 pm »
I do ask you to contact Norm, and discuss his link, and dimensions as applicable...
I had every "part/link" he produced, and tried them all.  I found them well made, and reliable, he made some good parts...
Offline Ianz5150
« Reply #4 on: February 08, 2019, 10:39:31 pm »
I would be happy to contact him. If you have contact information to pass to me, that would be appreciated. Otherwise I'll try to find it here. Thanks!
