Author Topic: Meanstreak rear and PR4Gt  (Read 1893 times)
Offline Bob_C_CT
« on: June 11, 2017, 12:35:53 am »
Well my Avon 160 70 17 ran out of meaningful tread after 6k miles. Just put on the 170 60 17 PR4GT today. Was a little worried that the shorter tire would leave me with a too long side stand. It didn't change by much so I'm good to go.
Offline Pbfoot
  • COG#: 10807
Re: Meanstreak rear and PR4Gt
« Reply #1 on: June 12, 2017, 02:31:10 pm »
The Dunlop Roadsmart 3 comes in a 18 front if you have not done the front mod yet. I have been running the 2's and now the 3's since I did the 17 inch conversion 3 years ago. I get 11k out of a rear. Front could go longer but I change both at the same time.  Great all weather tire. Very sticky leaned over. I run the 170 as well.
Offline WG
  • COG#: 4627
« Reply #2 on: June 12, 2017, 04:03:00 pm »
... Just put on the 170 60 17 PR4GT today. Was a little worried that the shorter tire would leave me with a too long side stand. It didn't change by much so I'm good to go.
This is the tire I run on my Meanstreak conversion as well.  I got nearly 15k out of a B-spec PR3 and around 16k (plus or minus a couple hundred miles) out of the PR4-GTs.  Note that none of these were bald / showing cords when replaced.
Wayne.
« Reply #3 on: June 12, 2017, 11:29:34 pm »
That is amazing mileage for PR3. The most I ever got was 8k down to the cords- normal for me was 5k.
2000 Red C10 1052 kit
Offline WG
  • COG#: 4627
« Reply #4 on: June 13, 2017, 01:20:14 pm »
Were you using B-spec PR3's?  My understanding is that they are constructed for heavier bikes and using the non B-spec tire on a heavier bike would get poorer mileage.
Wayne.
« Reply #5 on: June 13, 2017, 02:05:59 pm »
I never knew there was an option for B-spec.
 I now run PR4-GT's.  Good to know though.... thanks
Offline Bob_C_CT
« Reply #6 on: June 15, 2017, 01:46:45 am »
That B spec is news to me too, good info.
