Author Topic: Need someone to machine my 17in meanstreak rim  (Read 1065 times)
Offline fish
  • COG#: 11285
« on: February 08, 2018, 08:59:49 pm »
Looking for someone that can machine my 17in meanstreak rim in PA or close by
COG # 11285
CDA # 518
IBA # 47424
2003 Concours
2009 Goldwing
Offline Pbfoot
  • COG#: 10807
Re: Need someone to machine my 17in meanstreak rim
« Reply #1 on: February 09, 2018, 01:43:11 pm »
Go visit a few mom and pop shops. I am in Houston or I would do it for you.
Offline who me?
  • COG#: 11932
« Reply #2 on: February 09, 2018, 03:49:26 pm »
Print off the tech drawing and take it with you Saves a bunch of trying to explain
DAMHIK
95 C10 The Mule
02 C10 parts are parts
Offline Yamahawk
« Reply #3 on: June 03, 2018, 02:21:36 pm »
Instead of machining the rim, why not machine the Mean Streak caliper bracket instead, and use the 2 piston caliper and the larger Mean Streak rotor. You can clock the caliper to about 8:30 and make a longer caliper stay, using one side of the rear 'U' on the stay. Worked well for me, and have been running the Mean Streak rear this way for about two years.
Here is the link to what I did with pics!
http://forum.cog-online.org/concours-c10-zg1000-general-chat-and-tech/mean-streak-rear-wheel/msg476138/#msg476138
Charlie
« Last Edit: June 07, 2018, 09:46:25 am by Yamahawk »
All Things work together for good, for those who Love God, and are the Called according to His Purpose. - Romans 8:28
The Only Thing Necessary for Evil to Triumph...
Is for Good Men to do Nothing - Edmund Burke
Offline esmoojee
« Reply #4 on: June 19, 2018, 04:29:56 am »
+1 on using the mean streak rear components. I’m with Yamahawk. I just did this myself and the conversion was a snap.
Offline Yamahawk
« Reply #5 on: June 24, 2018, 11:46:27 am »
Cool!
It really is an easy conversion, and gives very good braking performance over the stock Concours rear caliper/rotor. I initially used the stock brake stay, but the caliper would hit the right saddle bag, and that made it necessary to clock it around behind the rotor, at about 8:30. I purchased another brake stay off eBay, and cut the ends off, and welded them to a longer piece of 1/2" sch40 stainless pipe, and then cut the inner ear off of the rear 'U' of the mount, and used an M12??? bolt of the proper thread pitch to attach it to the Mean Streak caliper mount. The angle of the caliper to stay is about 90 degrees, which is optimal. It saves a considerable amount of time and money, which is a plus for more farkles, too :)
Charlie
Offline lobo
  • COG#: 12853
« Reply #6 on: July 11, 2018, 03:51:45 pm »
I've been planning the same swap and have some questions for Yamahawk.
1) So you took the same .300" off the bracket instead of the wheel?
2) Do I need to clock the brake if the bags are not on the bike?
Thanks!
Offline Pbfoot
  • COG#: 10807
« Reply #7 on: July 11, 2018, 06:59:48 pm »
Thanks!
  1) You would take .181 off the axle nut side (outside)  of the bracket. The C10 is 1.003 wide at the axle on the bracket and the C14 is 1.181.  The modification is then made to the brace bar tube and bracket. 2) I can't answer this as I haven't mounted the brake caliper yet.
Offline esmoojee
« Reply #8 on: July 11, 2018, 07:36:06 pm »
I removed the .30 material from the MS bracket. I used the c10 bracket as a reference. I measured with the verner calipers. I don’t think you can clock the caliper like the stock caliper. You would probably need to weld a torque arm mount on the bottom of the swing arm. It’s easiest to just mount the way yamahawk did and fabricate a torque arm.
Offline Pbfoot
  • COG#: 10807
« Reply #9 on: July 11, 2018, 08:32:58 pm »
Did you use the wheel bearing collar from the C10 or the MS?
Offline esmoojee
« Reply #10 on: July 12, 2018, 02:59:46 am »
I used the c10 collar.  The only thing mean streak was the wheel and brake bracket.
