Author Topic: Shinko verge front and rear tires = marbles !?  (Read 370 times)
Offline Bearcat
    • Automatic Garage Door Services
« on: July 12, 2018, 02:24:58 pm »
Hello all.
As the title says,  Shinko verge front and rear tires = marbles  !?
Great cornering tire, good on smooth surfaces.  But very unstable on rain grooves and surface separation grooves at 70+ mph.
These tires have about 1000 miles on them.  Running stock tires pressure, rebuilt front folks with progressive springs, 40lbs air on rear shock, no Ex-tra weight or bags.  Tried lowering tire pressures with no success.
Based on my search this seems to be a problem with some of these Shinko Verge tires.    Any input or suggestions would be appreciated.
Thanks for reading my post.
Offline Neonsnow
  • COG#: 12817
Re: Shinko verge front and rear tires = marbles !?
« Reply #1 on: July 12, 2018, 04:02:26 pm »
i just had them installed on my 01. I like them, grip well nice feel but I get a wobble at 70+ on the highway. not sure if its the tires because I had a slight one before with my heavily worn out D205's. They are a great price but if it means I have a weird wobble or feel ill return em for something else.....screw that noise lol...im hoping its something else on my bike but I have only 15K on it so I don't think any bearings would be gone.
Offline CRocker
  • '02 C10 CDA # 416
« Reply #2 on: July 12, 2018, 04:34:49 pm »
The front Verge is fine...I think it’s the 16” rear people are having trouble with...
Offline Victor Salisbury
  • COG#: 3673
« Reply #3 on: July 12, 2018, 04:54:51 pm »
I've run Shinko's front and back, haven't wavered from the rear yet, alternated the front tire between brands, never an issue that I felt.
Reference tire pressure, the front tire is at least 39 -40 lbs for this heavy bike. Anything less, regardless of brand, will have my front start cupping. When the front does get lower air (sitting up for an extended time and dummy me doesn't check tire pressure pre-ride) I can feel it.
Steering head bearings need attending to also, might be worth a check.
HTH
Vic Salisbury
COG #3673
'97 Connie "The Grinch"
Sarasota, FL
www.cog-online.org
Offline Bearcat
« Reply #4 on: July 12, 2018, 05:14:29 pm »
Thanks for the response everyone.  My C-10 has 16,000 miles  or 25749 Kilometers.
I've been doing research since I posted this thread.
I found some interesting information here on this other thread.
http://forum.cog-online.org/tiressuspension-c10/pr3-front-shinko-verge-rear/
Offline Neonsnow
  • COG#: 12817
« Reply #5 on: July 12, 2018, 05:34:46 pm »
what tire pressure do you run in the rear?
Offline Bearcat
« Reply #6 on: July 12, 2018, 06:44:40 pm »
Been running what the service manual recommends.   36 psi / 250 kPa  front      41 psi / 290 kPa rear.
