Author Topic: No stem locator dot  (Read 858 times)
Offline Marty
  • COG#: 8165
No stem locator dot
« on: June 17, 2013, 07:04:44 pm »
Got a PR3 for the front and when getting ready to mount it I could not find a valve stem location dot anywhere.  There was a very small white barcode on the sealing surface of the tire but it was molded into the tire and not a sticker.  I did put it at the valve stem but I suspect it's simply a barcode and nothing else.  I went ahead and mounted it and put it on jack stands with the axle and then spent the next 15 minutes trying to get the tire to settle in a particular spot and it appears it is perfectly balanced without the need for any weight. Could this be why there wasn't a valve stem locator dot?  The Shinko 777 I put on the rear has a dot but I haven't put it up on the stands to check the balance yet, probably tonight when I get home.
Marty
Offline turbojoe78_MA
  • COG#: 8645
Re: No stem locator dot
« Reply #1 on: June 17, 2013, 07:11:53 pm »
I just mounted a PR3 on a 17" rim I'm going to be using soon and I couldn't find a stem mounting dot either.
Offline LakeTrax
« Reply #2 on: June 17, 2013, 09:04:55 pm »
Yes, for Michelins you use the bar code as the balance dot.
Not sure where along the way I was told this, but that is what I've always done... Michelins are usually pretty good for balancing with minimal weight needed, and many times you can mount them & not need any weight at all.  :beerchug:
  • COG#: 8645
« Reply #3 on: June 17, 2013, 11:53:22 pm »
I'll remember about the bar code when I mount the rear, when the Mean Streak rim is finished being machined.  Will be using Dyna Beads for balancing.
Offline Marty
  • COG#: 8165
« Reply #4 on: June 18, 2013, 08:19:26 pm »
As I said earlier, the PR3 needed no weight to balance.  I had to put 1.5oz on the rear 777 to get it balanced which is about half what I had to put on the 890 that was removed.
Marty
Offline goatmar
  • COG#: 7957
« Reply #5 on: June 27, 2013, 11:56:55 pm »
Use Durabeads and you won't have to worry about any dots............  they auto balance.  :)  Used them for years and they work great.
