Author Topic: zx9 front forks, what years?  (Read 559 times)
Offline 2wheelrush
  • COG#: 7992
« on: June 28, 2013, 12:40:49 am »
I know the 94-97 will work but has anybody used 98 and up? same length?
Offline GF-in-CA
Re: zx9 front forks, what years?
« Reply #1 on: June 28, 2013, 02:48:47 am »
The '98 and up used conventional forks, so they are totally different than the '94-'97.  I believe they are shorter than the older '94-'97's, but I don't know that for sure.  The '98 and up didn't use a wheel mounted speedometer drive, so they would require some sort of electronic speedo.  If you decided to try to use them, you would be covering new ground, as I don't believe anyone has tried to use them on a C10.
Gary F.
1998 ZGX1100
Central Valley California
